For the Ones who Like Mobile 1
Discussion in 'General Tundra Discussion' started by CJ21, Nov 28, 2017.
  1. Nov 28, 2017 at 6:00 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
  2. Nov 28, 2017 at 6:21 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I haven't changed the oil yet in the tundra, but good to know 0w-20 and 7.9 freaking qts....holy smokes.
    geno0506, Metro14536 and RoVASr5 like this.
  3. Nov 28, 2017 at 6:25 AM
    0W-20 full synthetic and Toyota oem oil filter
    Y0TA PR0, BakNBlk2014 and RoVASr5 like this.
  4. Nov 28, 2017 at 6:34 AM
    RoVASr5
    RoVASr5 New Member
    Daniel
    Lynchburg, VA
    '14 Tundra CM MGM
    Gibson Metal Mulisha Exhaust BDS Suspension Lift - 7 Inch Icon Dynamic 2.5 coilover reservoirs 18 "Moto Metal 18x9 +18 37x12.5R18 Federal Couragia MTs DV8 Front Bumper
    I use 0w-20 advanced fuel economy and will switch to high mileage once I hit 75k. I change every 10k and use Toyota OEM filters.
    CJ21[OP] likes this.
  5. Nov 28, 2017 at 6:45 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    I USE [​IMG] But Change It Every 5K:hattip:
    Metro14536 likes this.
  6. Nov 28, 2017 at 6:53 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    This is what I use along with Toyota filters. I compared the specs of this (which I've been using for years) and the new Annual Protection and didn't see any thing that justifies the big price increase of new oil over Extended Performance. I will stick with this one.
  7. Nov 28, 2017 at 6:57 AM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    Hey CJ. Big fan of your truck. I'm just on a wee 4.5 BDS.
    Is there a reason you change every 5k. My first experience with full synthetic was on a BMW 5 in 2014. Of course I did some investigation because 15k just seemed like way to many miles. The info I came up with was that 15k is legit for full syn. I only do about 6 or 7 a year so once a year changes for me. Don't think I would ever go past 10k regardless. Just curious if I missed something when fact finding not questioning your process. Thanks.
  8. Nov 28, 2017 at 7:16 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    Thank you Very Much! From what I was told and the research I did.. I do medium to light weight towing and hauling Not all the time and when you have the trucks lifted so high with the wider wheels and tires causes a lot of Drag on your Truck and Motor. To take off some of the stress off the motor thats way I change so often. ..The only way to help that is to Change the Gears so your motor will not have to work as hard. That I am having done here soon..Maybe I am a Little :der: Also..LOL
    BakNBlk2014 likes this.
  9. Nov 28, 2017 at 7:27 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    17ED1A25-58C4-4DFF-8527-B99710F9FD6D.jpg EB785F85-FE5C-48D7-9BC9-A8B963A806E1.jpgFrom Center Hub to wheel well I think I am 9” or so above factory. Plus the 20x12 wheels Do not help at all. With The Drag.. so in theory that should help the motors stress level changing the oil that much. Or I am making Walmart even more wealthier than they are.. LOL
  10. Nov 28, 2017 at 7:44 AM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    this is the only oil I ever use
  11. Nov 28, 2017 at 9:41 AM
    BakNBlk2014
    Donald
    Virginia Beach VA
    Hey, you love your truck and are doing what you can to take care of it. We are all a little obsessive on here. Towing lifted like that has got to be tough on things.
    CJ21[QUOTED][OP] likes this.
  12. Nov 28, 2017 at 10:57 AM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    Anyone in here ever gone with the Annual? I just.. I don’t know if I could do it. I just feels wrong.
    And what about the filter? Do they make an annual filter also?
    kenomouth64 likes this.
  13. Nov 28, 2017 at 11:09 AM
    1794TRD
    1794TRD It is, what it is!
    Little Rock, AR
    2015 Super White II TUNDRA 1794
    TRD EXHAUST TRD INTAKE Lift 3” front 1.5” rear TRD SKIDPLATE UNIFLEX TRIFOLD BED COVER UNIFLEX SWINGBOX POP & LOCK POWER TAILGATE LOCK TUNDRA BED LIGHTS LED HEADLIGHTS / FOG LIGHTS / PUDDLE LIGHTS / INTERIOR LIGHTS WHITE DOOR HANDLES WHITE MIRROR COVERS TOYTEC BOSS REAR SHOCKS CRUX AVITY-01 VIDEO INTERFACE AJT KEY FOB COVER
    I bet if you read the fine print on annual protection...it states you still need filter changes at regular intervals. In return, you will need to buy another quart at that time to replace what was drained in the filter housing...:pccoffee:. technically, they can say a full replacement is only needed every year, because you have strained it through a refreshed filter every 5k and rejuvenated it with a fresh quart... I ain’t buying it....
    CJ21[OP] and TundraTss[QUOTED] like this.
  14. Nov 28, 2017 at 11:10 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    Royal Purple is what I always used up until this truck. Excellent oil but I don't think it's worth the extra cost. At ~$10 per qt and with this truck taking almost 9qts per change I just couldn't justify the cost anymore. Mobil1 Advanced is what I use now like most the others.
  15. Nov 28, 2017 at 11:15 AM
    TundraTss
    Brandon
    2019 TRD SR5
    Right. That was my other question, how someone’s gonna change the filter without spilling oil, and then having to replace said spilled oil, and the oil in the filter itself..
    Seems sketchy. :crazy:
  16. Nov 28, 2017 at 11:27 AM
    1794TRD
    Little Rock, AR
    I my memory serves me well, Mobile 1 synthetic perfomed this test when it was first introducing quality possibilities of annual protection back in the 90’s. Every 3-5k miles, only the filter was changed and an oil sample was sent for testing. The result after a year was that regular filter changes and a quart refresh at regular intervals was sufficient enough to sustain lubricating properties in the oil to protect moving parts... how well was never clarified. Question is... are you willing to chance this with a $50,000 investment. I am sure there are some out there, but not me. Just my opinion...:goingcrazy:
    TundraTss[QUOTED] likes this.
  17. Nov 28, 2017 at 11:35 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Because it is so wrong!
  18. Nov 28, 2017 at 11:36 AM
    1794TRD
    Little Rock, AR
  19. Nov 28, 2017 at 12:57 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Did first oil change this last Saturday ya a jug plus mobile 1 extended oops I used a mobile oil filter
  20. Dec 1, 2017 at 12:46 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I am a big Mobil1 fan, it goes in my Chevelle and my wife's BMW. The Tundra will get Toyota full synthetic oil and a Toyota oil filter as long as it is under Toyota care and since I have a FFV engine I get an oil change every 5000 miles.
  21. Dec 1, 2017 at 8:18 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    I put Mobile 1 in before the second tank of gas was gone because it does get that cold up here
  22. Dec 1, 2017 at 10:19 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’m pretty sure its the same down there in ‘Merica, but up here in Canada (eh), “Toyota” 0W20 oil is Mobil 1 advanced fuel economy, in Toyota sprcific packaging for retail sale. 45gal barrels have the Mobil 1 labeling painted on with a Toyota decal.
    I used to have a contact at the local bulk distributor.
    So once your “free” services are up, don’t hesitate.
    71_340[QUOTED] likes this.
  23. Dec 2, 2017 at 12:02 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Even better. Now I get free oil changes with my preferred brand of oil, can't beat it!
