Too much airflow? Acceleration issues.
Discussion in '2nd Gen Tundras (2007-2013)' started by alaska_dude, Nov 19, 2017.
  1. Nov 19, 2017 at 1:27 PM
    alaska_dude
    alaska_dude [OP] New Member
    Corey
    2012 Tundra 4x4
    35" Nitto Grappler 6" lift Magnaflow AFE intake Smitty built M1 bumpers all around
    I have a 2012 tundra. 5.6 liter.
    I installed an AFE cold air intake with a dry filter.
    Since then I have notice a decrease in acceleration. Slower shifting, etc.
    When I unplug the battery and reset the ECU it runs strong for about 4 days then bogs down again.
    I think that maybe I am getting too much airflow and the MAS is compensating by telling the ECU to add more fuel.
    Anyone else run into this? Solutions?
  2. Nov 19, 2017 at 1:29 PM
    TheBeast
    TheBeast The Beach
    did you try cleaning the MAF ? I had the exact same setup and no issues. same year too. Are all the hoses attached properly ?
  3. Nov 19, 2017 at 1:48 PM
    You have a 5.7 ;-)
    Nissan has the 5.6
  4. Nov 19, 2017 at 1:57 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    He has a dry filter so no issues with over oiling if thats where you were headed.
    Not sure how lethargic its gotten but the larger diameter intake will slightly hinder liw end torque due to airflow velocity being "slower". Smaller diameter usually better for low end and larger is all up top HP.
    Id say take it off and see how the truck responds. Still the same way, there is an issue. Id not, keep the intake off and just do a drop in AFE dry filter and call it a day...after all factory is already CAI.
    TheBeast[QUOTED] and T-Rex266 like this.
  5. Nov 19, 2017 at 2:00 PM
    Factory is best for these trucks
    TheBeast likes this.
  6. Nov 19, 2017 at 2:32 PM
    alaska_dude
    Corey
    2012 Tundra 4x4
    Cleaned the airflow sensor. It helps but same effect after about a week it bogs down.
    Hoses are tight.
    I think I’ll try the stock air box and see what happens after a week or so.
    Sean66 I’ve heard many people say that stock is best before.
    T-Rex266 likes this.
  7. Nov 19, 2017 at 3:31 PM
    TheBeast
    TheBeast The Beach
    fyi I went back to stock and an AFE drop in dry filter. Best of both worlds.
    14burrito likes this.
  8. Nov 19, 2017 at 4:31 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Same setup here. I also removed tye charcoal filter from the top of the airbox...for whatever thats worth lol
  9. Nov 19, 2017 at 4:36 PM
    TheBeast
    TheBeast The Beach
    though my buddy has one of the throttle body spacer and CAI, he swears by them..:notsure::notsure:
  10. Nov 22, 2017 at 1:14 PM
    Mysticwolf
    Mysticwolf New Member
    Craig
    2011 Red SR5
    Toytec leveling kit, Magnum front and rear bumpers, PIAA fog & running lights, 20" Cree light bar, Cree 4" backup light in rear bumper, Gear 18X9 wheels 265X65X18 Master Craft tires. SABM.
    Your stock airbox is the best, its a true CAI. Do a SABM and add a K&N, take out the filter in the top of the stock box, and call it a day.
    DalTee likes this.
