How often do you replace your brakes?
Discussion in 'General Tundra Discussion' started by Tondra, Nov 15, 2017.
  1. Nov 15, 2017 at 8:46 PM
    Tondra
    Tondra [OP] New Member
    2018 Magnetic Gray Metallic SR5
    How often do you guys replace your brakes assuming you guys drive your truck everyday?
  2. Nov 15, 2017 at 8:59 PM
    LML 3500HD
    I have seen people go 20k to 100k on brakes.
    This all depends on useage. I could have went 70k on my fronts. Never changed my rear and looked great when I sold it at 89k miles.
    I towed a lot, so I’m sure if my tow duties were less and no mountain driving, 80-100k would have been a good estimate.
  3. Nov 15, 2017 at 9:15 PM
    Tondra
    Wow really that long and you tow too. That's amazing I didn't know Toyota brakes can last that long.
    4x4_Angel likes this.
  4. Nov 15, 2017 at 10:10 PM
    TheBeast
    TheBeast The Beach
    on my 2nd set of brakes at 60K....
  5. Nov 15, 2017 at 10:45 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I made it to 112k with my first set of brakes. I started having the shakes around 80k should of done it then probably. But I started losing braking power around 110k. Stealership charged me around 600 for front and rear. I did my trailer brakes last month, but that's irrelevant to this just another set of brakes I had to deal with.
    Patriot likes this.
  6. Nov 16, 2017 at 12:04 AM
    Tondra
    Some of you guys have brakes lasting well over 80K miles. I'm assuming you guys are still using the stock rims right? I read that if you install bigger rims let's say 20 inch your brakes wear out faster is that right?
  7. Nov 16, 2017 at 3:22 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    My 07 cm limited came stock with 20” wheels new brakes at 94k
  8. Nov 16, 2017 at 4:40 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Really depends on usage, 10k in the city is a lot more taxing than 30k on the highway.
    I typically get anywhere from 50-70k out of mine.
    BOBONTUESDAY likes this.
  9. Nov 16, 2017 at 4:55 AM
    War Machine
    War Machine SSEM # 5 3MW
    I guess it’s the way I drive, but I blow through them. Don’t know mileage, but it seems like every year I’m having to do it.
  10. Nov 16, 2017 at 10:17 AM
    BOBONTUESDAY
    2016 Limited Trd
    I agree. Mine is mostly highway.
    My old man always said, drive like you've got no brakes.
    Waterboy45661 likes this.
  11. Nov 16, 2017 at 10:22 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    I have 2900 miles on mine and they are squaking already..lets see what the dealershiphas to say
  12. Nov 16, 2017 at 10:53 AM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    My previous Ford Explorer had 3 sets of brakes 90k. Rubbish
    Tundra has far superior brakes
  13. Nov 16, 2017 at 10:55 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    Dealership wants to charge me $500+ for front and rear brakes and “resurfacing rotors” next time I go in at 60k. Is all of that necessary already or are they just trying to get me? First I have had to deal with brakes so far.
  14. Nov 16, 2017 at 10:57 AM
    n2deep
    n2deep Pavement Princess
    i went 55k on my first set of brakes and just replaced pads again at 105K
    Using Hawk LTS pads on stock rotors
  15. Nov 16, 2017 at 11:10 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I just changed my front and rear pads at 35k for the first time. The dealership wanted 600+ just to changed them. So I did it myself. Took about 2 hours but I am meticulas and took my time. Saved 600 for mods.....
    1UPPER, TheBeast and T500 like this.
  16. Nov 17, 2017 at 4:26 AM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    I really think it depends just as much on how you drive as it does the brakes themselves. I average ~75k for a set of brakes but I don't ride mine like I see a lot of people do. My ex averaged 40-50k for a set. Cheap aftermarket pads and rotors obviously don't last as long either.
    CMB likes this.
  17. Nov 17, 2017 at 5:04 AM
    Leo's first
    Groton ma
    Ya brakes on wife’s pos Chrysler average once a year grade doesn’t seem to matter much obviously not the cheapest but not much difference between mid or top grade besides $$
  18. Nov 17, 2017 at 7:09 AM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    I changed at 28K...:mudding:
  19. Nov 17, 2017 at 7:55 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    Just had my 70K mile service done and the brakes are still good to go. I'm roughly 90% highway driving, so they don't get a whole lot of use. I'll likely get well over 100K on the original pads.
  20. Sep 14, 2019 at 3:29 AM
    mdrake58
    mdrake58 New Member
    2014 Tundra
    step bars, crash bar
    Just finished 100k mile service, dealership told me I need brake service, they are charging 189.00 for the front two wheels, which really need it. Had the Tundra for 5 years before I needed it. I had them checked a couple of times while I get oil changes, but was not needed until now. This dealership service department is a good one, so no jacking up fees for this kind of work. There are other dealerships though, that are not that good and charge a lot more than necessary for the work. Check out their ratings or try a local mom and pop service place others have gone to and trust.
    Patriot and T500 like this.
  21. Sep 19, 2019 at 1:09 PM
    Jack Burton
    Little China
    2013 DC 5.7L TRD/OR
    Just made an appt to get my fronts replaced tomorrow. 106K+ miles. I have enough pad left to keep going for probably a couple thousand more miles, but I'm doing a 1500 mile road trip with a trailer in a week or so. Better to go ahead and get them taken care of beforehand.
    Patriot and OR18TRD like this.
  22. Sep 19, 2019 at 6:35 PM
    cmb46
    cmb46 New Member
    2008 Tundra
    I just ordered new pads and rotors for mine. I hope they last a long time.
  23. Sep 20, 2019 at 1:40 PM
    Jack Burton
    Little China
    2013 DC 5.7L TRD/OR
    Update to what I said earlier:
    When I took the truck in for new brakes this morning, the tech let me know that the '2mm remaining' figure their tire monkey gave me after my last rotation, was wrong. I actually still have a solid 4mm remaining, so I should be able to go another 5-10K miles (truck gets mostly highway, so more likely 10) before needing to get them done. Works for me!
  24. Sep 20, 2019 at 1:52 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    My wife can destroy a set of pads and rotors within 20K:eek2:
    Tundyfundy and Jack Burton like this.
  25. Sep 20, 2019 at 3:12 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Every two years I replace everything if they are needed or not.
    With rock auto it isn't expensive.
    So brakes, rotors and calipers every 30,000 miles
  26. Sep 20, 2019 at 3:24 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    My daughter got 99,800 miles on her Toyota Corolla S.when she traded it in. They were the original brake pads.we bought it for her for her college graduation with 13,450 miles on it.She drives like my wife and me so I was very surprised.
  27. Sep 20, 2019 at 5:32 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Find a good hill. Point upward. Tranny to neutral. Roll backwards. Jamb on brakes. Repeat several times. Report back on squeaking.
  28. Sep 23, 2019 at 5:34 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    82k and just now needing to consider brakes on the front. Rear are ok.
    Dealer says $200 front $200 rear. I will get them both replaced while it’s in.
    Any sooner is burning through cash and/or riding your brakes and wasting $$$.
    ColoradoTJ likes this.
