UltraGauge or ScanGauge in 2nd gen?
Discussion in '2nd Gen Tundras (2007-2013)' started by DVYota, Jun 28, 2016.
  1. Jun 28, 2016 at 7:45 AM
    DVYota
    DVYota [OP] Super stock street truck
    2014 Sequoia 2021 Tacoma
    Basically stock
    Anybody running either ScanGauge or UltraGauge in a 2nd gen tundra? I want to be able to track my MPGs, read specific trans and engine temp, and more. I ran an UltraGauge in my Tacoma and should have removed it before trading the truck in. Thanks.
  2. Jun 28, 2016 at 7:51 AM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    I have a ultragauge in my tooldbox from when I had a 2009 tacoma, I'll plug it into my 2010 tundra today sometime and see what it does
    DVYota[OP] likes this.
  3. Jun 28, 2016 at 8:05 AM
    DVYota
    Basically stock
    Awesome thanks!
  4. Jun 28, 2016 at 9:27 AM
    TheBeast
    TheBeast The Beach
  5. Jun 28, 2016 at 9:54 AM
    DVYota
    Basically stock
    Waiting for the outcome too?
    TheBeast[QUOTED] likes this.
  6. Jun 28, 2016 at 9:55 AM
    TheBeast
    TheBeast The Beach
    yes, I have been looking at similar products.
  7. Jun 28, 2016 at 10:20 AM
    DVYota
    Basically stock
    I ran an UltraGauge in my 2005 Tacoma, it was amazing... Just not sure if it was compatible with tundra or what it would show. I don't have any of the MPG tracking or anything in my Tundra and want to know real time numbers and data. For the price, I feel like the UltraGauge is he best deal if it will work
  8. Jun 28, 2016 at 10:24 AM
    TheBeast
    TheBeast The Beach
    it should work in any cars if it reads OBD II data.
    NewImprovedRon likes this.
  9. Jun 28, 2016 at 11:44 AM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    Here's pics of it installed and the available gauges I got... The orange thing on my screen is some chemical I spilled on it at some point years ago...
    I did notice that the "obd/ultragauge" battery voltage is wrong/low compared to what it really is measured by a fluke and solar meters....
    IMG_4202.jpg IMG_4204.jpg IMG_4205.jpg IMG_4206.jpg IMG_4207.jpg IMG_4208.jpg IMG_4209.jpg IMG_4210.jpg IMG_4211.jpg IMG_4212.jpg IMG_4213.jpg IMG_4214.jpg IMG_4215.jpg IMG_4216.jpg IMG_4217.jpg IMG_4218.jpg IMG_4219.jpg IMG_4220.jpg IMG_4221.jpg
    Actual battery voltage:
  10. Jun 28, 2016 at 11:53 AM
    DVYota
    Basically stock
    Awesome! Thank you!
  11. Jun 28, 2016 at 4:05 PM
    2011_Limited_tundra
    2011_Limited_tundra BOOM!!!!! That just happened....
    Erik
    Bay Area
    02 Cummins
    Leveling kit 35s on 20s
    I've got one in my truck and I like it... Helps me keep track of more parameters for my truck image.jpg
    Filthyphil and DVYota[OP] like this.
  12. Jun 29, 2016 at 3:39 PM
    Aurora CO
    Very high on my list. Well worth the money.
  13. Nov 7, 2017 at 7:10 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  14. Nov 7, 2017 at 8:24 PM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    got one on my dash
    BlueBottle[QUOTED] likes this.
  15. Nov 7, 2017 at 8:34 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Post a picture of it.. what do you monitor with it?
  16. Nov 8, 2017 at 3:22 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    I run an ug. Happy with it. Wish I could get trans temp tho.
    BlueBottle likes this.
  17. Nov 9, 2017 at 9:57 AM
    2015_Nova_Taco
    2015_Nova_Taco New Member
    My Tundra has a gauge for the trans temp (not the exact number of course) and tells me the MPG from the Info button by the clock. I haven't hooked up my Scanguage as a result. Do not all Gen2 Tundras have these features? I was thinking of selling off my Scanguage.
  18. Nov 11, 2017 at 4:39 PM
    nuclearlemon
    wyoming
    2012 dc
    never changed it from where i had it set in my 95 land cruiser. av miles, realtime miles, temp and volt. someday, maybe i'll change it up ;)
  19. Nov 11, 2017 at 4:57 PM
    tts-355
    tts-355 New Member
    Tyler
    2012 Tacoma DCLB TRD Sport 4x4
    I may be wrong but I think your going to have some voltage drop from the battery to the gauge. Your voltage has to run through your battery cables to the ECU then to the OBDII port, then through that connection through the UG harness. I’d be willing to bet that a loss of a few tenths of a volt is normal. Just my thought though
  20. Nov 11, 2017 at 5:56 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks. How accurate Is the avg mpg on that compared to cluster and by hand?
  21. Nov 11, 2017 at 6:51 PM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    I think this was one of the things Toyota 'improved' with 3rd gen (or 2.5 gen). They took away transmission fluid temperature gauge.
  22. Nov 13, 2017 at 8:32 AM
    Bpowa
    Bpowa New Member
    I had one for my 4runner.. But removed it. Its somewhere in Storage. I may have it for sale if anyone is interested. Only used it for a couple months. Perfect condition when I put it away.
  23. Nov 13, 2017 at 9:14 AM
    nuclearlemon
    wyoming
    2012 dc
    haven't done hard comparison by my info, but seems close enough. i don't have the magic buttons to read the computer measurements
  24. Apr 17, 2018 at 12:25 PM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    I'm just being lazy because I know how to figure this out myself but...
    Does anyone know the TPS FuelCut# for the 5.7?
    Thanks!
  25. Apr 18, 2018 at 5:20 AM
    Tundradrenalin
    Virginia Beach, VA
    for the 5.7 Injector Cutoff, according to the throttle position sensor, is <17
    and in case anyone wants to know the 4.7 is <21
    (this is part of the ultragauge setup)
  26. Jun 24, 2020 at 11:02 AM
    Corr2626
    Corr2626 New Member
    Corey
    2014 Tundra Limited
    Still the best or reasonable option in 2020 to read the trans temp numbers in Tundras? Scan Guage that is
  27. Jun 24, 2020 at 12:10 PM
    Yes but you have to put the code in it.
    Corr2626[QUOTED] likes this.
  28. Jun 24, 2020 at 12:36 PM
    Tundradrenalin
    Virginia Beach, VA
  29. Jun 24, 2020 at 3:50 PM
    Failure2comply
    Failure2comply Master HVAC Tech
    VA
    2008 Tundra Crewmax Limited w/factory 20" wheels
    Trailer brake. Limousine tint in rear windows. Ultra Gauge "Blue". Toyota bed mat and bug deflector.
    I run the UltraGauge "Blue" in my Tundra, works like a champ. I just use and old cell phone and holder.
    Tundradrenalin likes this.
  30. Jan 2, 2021 at 8:46 PM
    RapidRoy
    RapidRoy New Member
    Roy
    2006 Tundra DC
    Rock Stock
    I have a 2006 and was able to get transmission temp. It wasn't enabled by default though. I'm racking my brain on how I did it and can't remember exactly, but I think I had to go to the site and get additional sensors. Once I did that, I have WWW Toyota Guages as an option with a number of different sensors. Some of them didn't work, but there are multiple trans sensors listed. I assume some of them were for different models... I should have said, I have the UG bluetooth unit. I believe I've read somewhere that the trans temp sensors can be made to work on the standard UG as well.
