Tundra Lowered Honey-D WideBody
Discussion in '2.5 Gen Builds (2014-2021)' started by DPT007, Sep 28, 2017.
  1. Sep 28, 2017 at 5:17 PM
    DPT007
    DPT007 [OP] New Member
    Ben
    2016 Tundra Plantinum
    Tint
    Whats up guys!
    A few of you have asked for me to make an "Official" Build Thread on my current project.
    HERE IT IS!
    Project Truck (2016 Toyota Tundra CrewMax Platinum) Color: White)
    Honey-D wide Body kit has been Received, currently working on project plan and deployment. Pictures to come with descriptions.
    Here is a Projected List of Upgrades and work that is to be Completed:
    1.)Bakflip MX4 trifold Bed Cover (Installed)
    2.)Bakflip Bedrug 5'6" Crewmax Bed. (installed)
    3. Honey-D 4" Widebody Kit (Includes Fenders and Front Bumper)
    4. Rims (?) Size: 22x12 with -44offset
    5. Tires Probably Toyo Open Country 325/50 R22
    6. Vehicle Wrap: Color (?) its a surprise!! ;)
    7. Lowering the Truck (not sure on how much, want to get the kit and wheels on to see the deficit and make that decision there. I don't want to slam the truck but close in on the gaps and level it.
    8. Rear Seating Entertainment, and upgraded sound system
    9. Supercharger/Tune?!?
    10. Exhaust
    So Far I couldn't be happier with the result. Pictures to come shortly.
  2. Sep 28, 2017 at 6:27 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    In for pics
    :popcorn:
  3. Sep 28, 2017 at 6:30 PM
  4. Sep 28, 2017 at 6:40 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I don't know how to go the imoji things but I'm curious to see how it looks too.
  5. Sep 29, 2017 at 3:54 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I wanna see!
  6. Sep 29, 2017 at 9:18 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    in for pics!
    4x4_Angel likes this.
  7. Sep 29, 2017 at 9:25 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    patiently waiting impatiently:D
  8. Sep 29, 2017 at 10:09 AM
    DPT007
    Ben
    Tint
    Backflip MX4 bed cover installed
    Bakflip Bedrug installed
    Swing cases x2 installed
    Completely happy with the install
    Process bedrug and bed cover install took maybe 2 hours to figure it all out and install clean. Swing cases went in today took maybe 30min from unboxxing to installed with 6 self tapping metal screw each for the harness. They swing out and are completely removeable if u need the bed.
    JC303, Tacotundra, blue16 and 2 others like this.
  9. Sep 29, 2017 at 10:14 AM
    niru316
    niru316 New Member
    2017 Tundra TRD Pro CrewMax
  10. Oct 5, 2017 at 11:33 AM
    DPT007
    Ben
    Tint
    So looks like we have some work to do to the fender and bumper before application. The fiberglass edge is rough (needs smoothing) the holes need to be drilled where we will be bolting to the truck.8F143BE1-64F6-48A3-A590-B715D3120927.jpg25681241-6CFC-4FB4-8310-6E315FBE2471.jpg5B5B7751-B039-42B6-9FBB-150FFFA32E86.jpg
    We used blue tape to help see the surface area where the bolts will be mounted to help center each drilled hole. Drill bit purchased that’ll help to pilot hole drill then reach the desired hole size. The bolts are 3/8 in thick
  11. Oct 29, 2017 at 2:07 PM
    DPT007
    Ben
    Tint
    B1EA7686-B4E5-4D31-9EB7-DCA4D117274C.jpg 21A24E1C-8F01-4655-AEE9-7F9401007440.jpg A68410AF-2B8E-4037-930A-647F5B1C20F8.jpg 9EBA0774-81EA-441B-AD2A-E071D4CF1FD9.jpg 97AA8613-13F0-495C-BDD7-6644E3E0C845.jpg B1EA7686-B4E5-4D31-9EB7-DCA4D117274C.jpg 21A24E1C-8F01-4655-AEE9-7F9401007440.jpg Well a week before the SEMA show here in Vegas and my wheels and tires FINALLY arrive! Glad I didn’t make arrangements for the show .
    Went ahead with the Rockstars RS3
    22x12.5 with a -44 offset
    For rubber I purchased the Toyo Open Country AT2 325/50 r22
    And these are MASSIVE!!
    The way they sit on the truck and the aggressive pattern is amazing. They fill the wheel area perfectly. When turning they hit the front bumper and rear fender so some modification is in order.
    Let me know what you think
  12. Oct 29, 2017 at 2:14 PM
    DPT007
    Ben
    Tint
    I owned these rims on a tacoma with size
    18x9.5 and
    These look waaaaay better when large and in charge 22s
    The inserts are a fun way to mix up the look. Discount tire was awesome enough to give me all the different inserts for free check them out
    I like the bare rim look as well as the white split spoke ones as my favorite
    The ring insert is on the way as well
    4x4_Angel, 1UPPER, Tundra Fan and 2 others like this.
  13. Nov 9, 2017 at 10:21 PM
    DPT007
    Ben
    Tint
    Trying to figure out what we are going to do with the front fender rear section the tires are rubing on a tight turn.
    I think we are going to cut the section of the original fender that’s rubing.
    Tacotundra and 4x4_Angel like this.
  14. Nov 9, 2017 at 11:47 PM
    DPT007
    Ben
    Tint
    This ended up being the tape line we used to trim the back of the front fenders.
    JC303 and 4x4_Angel like this.
  15. Nov 10, 2017 at 12:34 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  16. Nov 10, 2017 at 5:40 AM
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i'm kinda looking forward to seeing how this goes. looks like a great start.
    Eclipsed & Floating likes this.
  17. Nov 10, 2017 at 5:48 AM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
  18. Nov 10, 2017 at 7:13 AM
    DPT007
    Ben
    Tint
    Thanks guys also need to make a bracket to displace the front bumper forward 1” on top and 2.5” below. This will prevent the tire to turning into it. It’s kinda nice I like the look having a front shelf with the bumper forward. The way the bumper is molded it still tucks in like it belongs.
    Pics coming soon
  19. Dec 10, 2017 at 6:39 AM
    myk1013
    myk1013 New Member
    Myk
    2017 CM * MGM * TRD
    this looks like its gonna be good.
    in for the updates.
  20. Dec 10, 2017 at 7:35 AM
    bryanpwatson
    bryanpwatson New Member
    2017 Grey Tundra XS-P
    None to date but coming!
  21. Dec 10, 2017 at 10:05 AM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
  22. Dec 28, 2017 at 7:02 AM
    DPT007
    Ben
    Tint
    8849CB28-9560-4857-8885-1AE0B50F8A2B.jpg 96E60540-DB03-44DC-92B9-A5A52B5939CF.jpg 02DF28E6-A91C-45C9-926F-17BBEFE19B6F.jpg F2223240-FCD7-4F4A-A903-CB380350EEB9.jpg 26123622-ACD5-46D0-A92F-9642746EB6C0.jpg B870D749-43AD-4186-B64F-F77CFC7E6514.jpg Happy Holidays everyone! Had quite the interesting few weeks. Delayed a few weeks after getting size swiped by a car while visiting California and disneyland.
    Just got the truck back from the repair shop and finished installing the bumper extension and brackets. Found some ore-drill stainless steel plates at Lowe’s, cut them down to 1.5” holes for the extension.
  23. Dec 28, 2017 at 7:20 AM
    Hasteen
    Hasteen To be continued...
    Justin
    Providence, RI
    2004 DC SR5 Texas edition 2016 CM 1794 edition
    1ST GEN Toytec 3/1 lift kenda 33s on 17x9 RockTrix RT107 BruteForceFab front bumper ----------------------------------- 3RD GEN rough country 6" Toyo 35's on 22x10 Fuel Assault TRDPro Grille
    I've been trying to get my hands on the Honey D kit, how did you order?
  24. Dec 28, 2017 at 8:21 AM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    cant wait to see how it all looks those wheels go perfect with this set up
  25. Dec 28, 2017 at 8:26 AM
    DPT007
    Ben
    Tint
    I just emailed them from their official website, Hiro contacted me and I placed my order. Everything was done via PayPal and shipped from Cali. They offer pickup if ur local to avoid $300 shipping
  26. Dec 28, 2017 at 8:34 AM
    15whtrd
    15whtrd Mr. Blonde
  27. Dec 28, 2017 at 9:04 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
  28. Dec 29, 2017 at 8:32 AM
    Hasteen
    Justin
    Providence, RI
    I’m completely on the other side of the country. Lol 300 is not bad. I also emailed them about cutting and drilling they said none was required on a lifted set up. I asked for an order form and never received a reply. I guess I’ll ask again. Thanks!
  29. Dec 29, 2017 at 9:59 AM
    DPT007
    Ben
    Tint
    Yes I would. They aren’t the best at immediate responses. Also don’t be mislead. I’m not lifting my truck plus every setup with this kit lowered we’re with 20” rims and 33” tires. I am doing 22” Rims and 35” tires on a lowered setup. Requiring some modification
  30. Dec 29, 2017 at 8:44 PM
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    @DPT007 Looks like the total forward movement provided by your brackets was more than 1"?
    Was it exactly 1.25 inches (as stated in your previous reply)?
    You only had to move the bumper shell out but not down?
