General Supercharger Thread
  1. Aug 7, 2025 at 9:08 AM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Completely agree!! and I know it sucks right now but come Sunday morning when I'm finally home and waking up in my own bed it won't see nearly as bad as it is now. bummer but could be way worse as well
  2. Aug 7, 2025 at 9:17 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    All of your electrical gremlins are on the green harness pictured below, MAF, SAIS, O2, Trans...
    Check the connections in the driver's side relay/fuse box as well as the connections in the passenger side junction box (pull connectors out and visually inspect pins for damage or debris)
    Check any other connections along the harness (pull connectors out and visually inspect pins for damage or debris)
    While you are doing that, look for any damage to the harness that could indicate a problem.
    HulkSmurf14, reywcms, Wynnded and 5 others like this.
  3. Aug 7, 2025 at 9:50 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Thanks, after verifying all you suggested, I am back to only no MAF voltage, I believe that's D53 & I see no issues there.
    Pins 9,10 & 11 which are for the sensors ( I think) are ok, I have power at 7&8 also.
    I'm plugging away at it.
  4. Aug 7, 2025 at 10:27 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    YES = 7/8/9/10/11 = +B battery power
    16/17/19/20/21/22 are all shielded grounds at D2, passenger valve cove at the rear.
    HulkSmurf14, reywcms, Mdl and 3 others like this.
  5. Aug 7, 2025 at 12:00 PM
    e30cabrio
    Thanks, I looked at the back of the passenger valve cover & didn't see a ground so added one, no voltage. :(
    I appreciate the verification on the harness & pins,
  6. Aug 7, 2025 at 12:14 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Adding a ground I don't think will help, it sounds like the issue might be that harness is not grounded---not the valve cover lacking a ground.
  7. Aug 7, 2025 at 12:32 PM
    e30cabrio
    Is there an easy way to ground it & see?
  8. Aug 7, 2025 at 12:41 PM
    snivilous
    SW UT
    Not really, find the harness wires (they're probably floating somewhere) and hook them up. I've only been half paying attention to this thread, but if I followed what @mustang67408 was saying, it's these two ground points. I remember them from Reys engine since there's about a thousand wires that tie into two ground tabs. If these are not connected on your head that's probably a lot if not all the issues.
    armyoffoo, Wynnded, AZTundra and 5 others like this.
  9. Aug 7, 2025 at 12:49 PM
    e30cabrio
    Thanks!
    It's difficult to see there. Wheeeeeeee
    AZTundra, HulkSmurf14 and Mdl like this.
  10. Aug 7, 2025 at 1:19 PM
    mustang67408
    Victor
    YES, those are the ones
  11. Aug 7, 2025 at 1:25 PM
    e30cabrio
    I looked, from the top, can't see. Damn heater tree & firewall are right there. Tried from the bottom, don't see it but also nothing loose I can see. I need to pull the tire to try from that angle but...
    Mdl, nobodyintexas and mustang67408 like this.
  12. Aug 7, 2025 at 2:21 PM
    mustang67408
    Victor
    I feel you it's 112 here
    e30cabrio[QUOTED] likes this.
  13. Aug 7, 2025 at 3:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'll stop complaining about 85-90. I can't even fathom it. Although I've been stuck in some 100 degree engine rooms when I was younger.
  14. Aug 7, 2025 at 3:21 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I was done after yardwork in 84* full sun today. Some of y'all are just crazy for choosing that level of summer heat
    Mdl, e30cabrio and mustang67408 like this.
  15. Aug 7, 2025 at 5:37 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Well...went up to Seattle yesterday and noticed when I accelerated, in 6th, it would disengage TC Rev up 500rpm then normal acceleration. I usually don't have it in D and limit it to 5th as 6th gear, S3, was given me issues in traffic. I knew better and should of kept it in 5th! Made it home after 1.5 hour drive up and back. 1 mile from my house throttle wouldn't increase rpm, limp mode.
    No MIL but codes p0761, p0894 and p2714 which I've had before except the p0894.
    I had a spare speed sensor and threw that on for the output and will be testing the S3 and SLT solenoid. Fluid is pretty good. I've got both but knew this time was coming.
    @reywcms will probably have to swing by soon. Send trans out or maybe tackle the rebuild after the move. Real Estate market has been crazy around here. Just sucks as I'm trying to get ready to list my house before the rainy season sets in.
    HulkSmurf14 and e30cabrio like this.
  16. Aug 7, 2025 at 5:47 PM
    e30cabrio
    Sorry MDL no fun.
    Am I looking for something like this?
  17. Aug 7, 2025 at 5:51 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Yes, it will be two small bundles of wires with ring terminals.
  18. Aug 7, 2025 at 6:49 PM
    nags
    nags New Member
    So, more awesome news from my side of the world. Shop was replacing the timing belt on my Lexus and grenaded the motor.
    They're ordering me a remanufactured motor with warranty tomorrow. :annoyed:
  19. Aug 7, 2025 at 6:52 PM
    e30cabrio
    That sucks, sorry.
    How the fuck does that happen?
    What Lexus/motor?
