General Supercharger Thread
  1. Jul 19, 2025 at 12:18 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    ...by the EPA? :confused:
    Mdl likes this.
  2. Jul 19, 2025 at 12:19 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Possible to find out if anyone left them out and what temps were? Failures or positive effects?
  3. Jul 19, 2025 at 12:20 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    So, for those of us that run hotter, and don't have emissions testing, could we just remove the spacers for cooler temps?
    HulkSmurf14, snivilous[OP] and Mdl like this.
  4. Jul 19, 2025 at 12:20 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    Ill ask someone at Toyota next week.
    Wynnded, HulkSmurf14, reywcms and 2 others like this.
  5. Jul 19, 2025 at 12:22 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Hmm might be adding “remove coolant jacket” from my future built 5.7 project, once my current one plays 52 piston pickup on the side of the road haha.
  6. Jul 19, 2025 at 12:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ha! Run 0w-20 oil, flex lock etc etc to gain an extra mpg or be part of the climate cash cow.
    Wynnded and HulkSmurf14[QUOTED] like this.
  7. Jul 19, 2025 at 12:23 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    My thinking too!
    HulkSmurf14 likes this.
  8. Jul 19, 2025 at 12:25 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Definitely don’t want to leave them out. Keeping bore temps equal is great for not only a clean burn through the entire stroke, but longevity of the cylinder/pistons/rings will surely be better. These jacket spacers are spec’d for the heat load generated by a NA engine… but they are likely one of the causes, or at the minimum, a significant contributor, to piston failure. They might just need a trim for boost.
  9. Jul 19, 2025 at 12:37 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  10. Jul 19, 2025 at 12:47 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I wouldn't worry about it, rings haven't fully seated yet. I would check the catch can often, it'll probably fill up fast too.
    Wynnded, HulkSmurf14, reywcms and 3 others like this.
  11. Jul 19, 2025 at 12:52 PM
    e30cabrio
    Thanks, it's stock right now, no catch can.
  12. Jul 19, 2025 at 1:08 PM
    centex
    centex New Member
    Gonna show some ignorance here but would dropping to a 180* t-stat be a good idea?
  13. Jul 19, 2025 at 1:08 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks! Just wanted to see what the exact need is. Good clarification on the spacer.
    e30cabrio and HulkSmurf14 like this.
  14. Jul 19, 2025 at 1:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I've read it either way but more pro to keep it stock. I kept the 185 t-stat.
    bflooks, e30cabrio and HulkSmurf14 like this.
  15. Jul 19, 2025 at 1:11 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I would hook up the catch can, with bigger ring gaps you might experience more blow-by and would be better to catch that than let it coat your intake and valves.
  16. Jul 19, 2025 at 1:16 PM
    mustang67408
    Victor
    The first Gen tundra went to a cooler T-Stat 180*, but it didn't have an intercooler. They also had the water jacket spacer. Those never Broke/Melted pistons, usually the rods failed. I have my own opinion on why and it wasn't the rod....
  17. Jul 19, 2025 at 1:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Starting to box up and clean out garage of parts etc. At a minimum before moving going to install lexus driver side windshield washer and do the 3x7.5 intake opening mod. Oh and decide where to move to...:eek:
    ZPhilip, Wynnded, e30cabrio and 4 others like this.
  18. Jul 19, 2025 at 1:52 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I still have your trans here lol
  19. Jul 19, 2025 at 1:57 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Oh man! I was supposed to head to Portland a few times but stuff kept coming up. Either I'll be down when I move or have my brother grab it, should fit in the back seat of his Audi. :rolleyes:
  20. Jul 19, 2025 at 2:15 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    Finished the thermal blanket, didn't receive any paper instructions on the installation, but I was mainly looking for the boost fitting location so I can install the barb.. what size tubing are you guys using 1/8 ID?
    Is there a pdf somewhere, I looked on Whipple's site associated with my year and only the tune installation is available on pdf.
  21. Jul 19, 2025 at 2:47 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Haha no rush it’s not in the way or anything just making sure you don’t forget about it
    Mdl[QUOTED] and e30cabrio like this.
  22. Jul 19, 2025 at 2:48 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Wouldn’t be install instructions from them for the boost gauge. I did mine driver-side manifold. Right below the 3 vacuum lines there’s a spot 1/8 is correct I believe
  23. Jul 19, 2025 at 3:01 PM
    LILTRD
    LILTRD New Member
    2013 Tundra RCSB
    Ok, so pretty much any of the manifold ports not in use.
    Now, where do I get that matching braided hose that I can't unsee...?haha thanks!
  24. Jul 19, 2025 at 3:21 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You could use hydraulic hose sleeves, or the nylon heat shrink braid covering. They have some different types on Amazon etc.
    HulkSmurf14 and LILTRD[QUOTED] like this.
  25. Jul 19, 2025 at 3:24 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Aren't the nipples pre-rotor? Would they see boost?
    Mdl likes this.
  26. Jul 19, 2025 at 3:26 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    This spot should get you boost reference
  27. Jul 19, 2025 at 3:35 PM
    bflooks
    bflooks New Member
    Metrowest MA
    XAT appears to add the plastic back.
    Not seen:
    Seen (right before heads went on):
  28. Jul 19, 2025 at 3:35 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Yeah...had the boost gauge in my Tacoma and to be honest I havent even thought about it for the Magnuson until this thread.
    Would like to get the interior pillar piece to mount the boost gauge as well as some other gauges.
    They have different models with your choice of the number of gauges you want
  29. Jul 19, 2025 at 3:42 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    I remember it being a Bitch to get the boost gauge tube through the firewall and connected without crimping it.
    Mdl and mustang67408 like this.
  30. Jul 19, 2025 at 3:46 PM
    LILTRD
    LILTRD New Member
    2013 Tundra RCSB
    Are you talking about this nipple?
