Platinum's Club! Post em!
Discussion in 'General Tundra Discussion' started by BlueBottle, Apr 11, 2017.
  1. Oct 8, 2017 at 4:02 PM
    #91
    Ben_onewise
    Ben_onewise New Member
    2016 Tundra CM Platinum 4x4
  2. Oct 8, 2017 at 8:46 PM
    #92
    geno0506
    geno0506 New Member
    Michael
    Looks awesome!
    Ben_onewise[QUOTED] likes this.
  3. Oct 14, 2017 at 7:17 PM
    #93
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
  4. Oct 14, 2017 at 11:11 PM
    #94
    Patriot
    Patriot Member
    Western NC, “Boondocks”
  5. Oct 14, 2017 at 11:45 PM
    #95
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Those flares look good
    Patriot[QUOTED] likes this.
  6. Oct 17, 2017 at 4:01 PM
    #96
    kkim124
    kkim124 New Member
    Torrance, CA
    2016 Tundra Platunum 4x4
  7. Oct 17, 2017 at 4:06 PM
    #97
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
  8. Oct 17, 2017 at 4:44 PM
    #98
    BlueBottle
    '16 Platinum 4x4
    See fine print
    damn looking good on those 20" tE's!!! what offset are they? First time I seen 20" TE's on the Tundra
    clean as always! how do you keep the side of the truck that clean with that setup!!!
    :mudding:
    1SassyShan and kkim124[QUOTED] like this.
  9. Oct 17, 2017 at 4:49 PM
    #99
    kkim124
    kkim124 New Member
    Torrance, CA
    Thanks. 20 x9.5 +0 offset. There was some rubbing but a bmc took care of that.
  10. Oct 17, 2017 at 5:00 PM
    #100
    1UPPER
    TEXAS
    Flux capacitor!
    It's actually dirty most of the time. I drive 30k miles in one year and I use it for work everyday. I use my pressure washer and foam cannon to clean it before a meet up. IMG_6487.jpg
    Prostar 190, CJ21, TheBeast and 2 others like this.
  11. Oct 28, 2017 at 12:11 PM
    #101
    Medging
    Medging New Member
    2016 silver sky metallic platinum
    18inch fuel wheel, nfab step bars
    2016 platinum
  12. Oct 28, 2017 at 1:12 PM
    #102
    JRPro
    JRPro Snappin’ necks & cashin’ checks
    Rich
    Austin, TX
    17 TRD Pro CM Cement
    I need that spare tire carrier! Is that a custom jobber?
  13. Oct 28, 2017 at 1:41 PM
    #103
    EduardMusatov
    EduardMusatov New Member
    Eduard Musatov
    Lynden, WA.
    2017 toyota tundra crewmax
    Trd exhaust, Trd intake, sway bar, amp running boards, tunnel cover, paint match handles and mirror caps, aftermarket remote start, 2018 head light,
  14. Oct 28, 2017 at 3:43 PM
    #104
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
  15. Oct 28, 2017 at 7:51 PM
    #105
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
  16. Oct 28, 2017 at 7:52 PM
    #106
    CJ21
    CJ21 CJ-21
    DELAWARE
  17. Oct 28, 2017 at 8:08 PM
    #107
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Very clean! How do you like them weathertechs? Did you notice it’s harder for your motors to close the windows ? I’m torn between those and avs low pros.
    CJ21 likes this.
  18. Oct 29, 2017 at 10:18 AM
    #108
    Omohundro
    Jody
    McMinnville TN
    I don’t like them.The windows sound awful when closing and they rattle like crazy when the windows are down.
  19. Oct 29, 2017 at 11:46 AM
    #109
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks for the honest feedback!
    Omohundro[QUOTED] likes this.
  20. Oct 29, 2017 at 2:48 PM
    #110
    EduardMusatov
    Eduard Musatov
    Lynden, WA.
    Patriot, OR18TRD, Tundra1078 and 7 others like this.
  21. Nov 1, 2017 at 4:29 PM
    #111
    AxelsHumanDad
    AxelsHumanDad I am Groot
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Some LEDs in the freshly falling snow-
  22. Nov 1, 2017 at 5:29 PM
    #112
    butters1975
    butters1975 New Member
    Clarksville TN
    '20 MGM Pro
  23. Nov 7, 2017 at 4:26 PM
    #113
    Medging
    Medging New Member
    Are those led puddle lamps?
  24. Nov 7, 2017 at 4:29 PM
    #114
    Yes they are Drive Bright led puddles.
  25. Nov 7, 2017 at 4:31 PM
    #115
    Medging
    Medging New Member
    Thank you!
  26. Nov 7, 2017 at 4:32 PM
    #116
    Sure I put the same one's in mine they are awesome!! :thumbsup:
    Medging[QUOTED] likes this.
  27. Nov 7, 2017 at 4:44 PM
    #117
    Patriot
    Patriot Member
    My Tundra in the wild kingdom lol...actually where I deer hunt.
  28. Nov 7, 2017 at 6:14 PM
    #118
    AxelsHumanDad
    2015 CM Platinum
    Yes they are.
  29. Nov 7, 2017 at 6:15 PM
    #119
    AxelsHumanDad
    2015 CM Platinum
    Thanks for answering for me! :p
  30. Nov 7, 2017 at 6:20 PM
    #120
    I was on here and knew the answer so just told him. Hope I wasn't stepping on toes.:rolleyes:
    Lol
