Oil leak; what is this bolt?
Discussion in '2.5 Gen Tundras (2014-2021)' started by rmorse, Sep 11, 2024.
  1. Sep 11, 2024 at 9:50 AM
    rmorse
    rmorse [OP] New Member
    Bobby
    Bowie, MD
    2021 DC Cavalry Blue SR5 TRD Sport 4x4
    Hey guys, I just changed my oil and noticed an oil leak. What is this bolt?
    Thanks!
  2. Sep 11, 2024 at 10:08 AM
    rmorse
    Bobby
    Bowie, MD
    Ok so looks like it’s an oil cooler relief valve; I believe it opens up to let oil through if the filter gets too clogged.
    Why is it leaking though? Is that bad? Lol
  3. Sep 11, 2024 at 11:04 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Maybe the filter is too clogged?
    Are you positive it's coming from that valve and not anything above it?
    Tunrod likes this.
  4. Sep 11, 2024 at 11:12 AM
    rmorse
    Bobby
    Bowie, MD
    90% sure it's coming from that valve. I'll hit it with brake cleaner and look again.
    I just changed the oil and filter and it looked fine but i guess it could have been clogged
  5. Sep 11, 2024 at 2:19 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Oil circuit relief is on the pump? Output is cycled back to inlet I believe.
    Oil filter relief/bypass is at the base of the perforated tube inside the filter bowl... which has been changed to aluminum already.
  6. Sep 11, 2024 at 5:24 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    That is the oil cooler relief valve.
  7. Sep 13, 2024 at 5:16 AM
    rmorse
    Bobby
    Bowie, MD
    So is it an issue if it's wet?
  8. Sep 13, 2024 at 5:23 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    No leak is good. With that said, it certainly won’t damage the engine to leave it. I can get a part number for the gasket… but it’s rare for a leak to happen there.
  9. Sep 13, 2024 at 5:24 AM
    rmorse
    Bobby
    Bowie, MD
    She's still under warranty so I might just bring it in tbh
  10. Sep 13, 2024 at 5:25 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Any relief valve that has to be used is an indication of some type of issue. Relief valves (like fuses), by design, are meant to prevent a small issue from becoming a major issue. Something is causing the relief the valve to activate...or something is wrong with the valve itself. It should not be constantly wet with oil.
    If you just changed the oil, it's possible the old filter was clogged up (which is something to investigate in of itself BTW). If that's the case, I would monitor it to see if it continues. If it does continue, then it might be an indicator of an issue with the relief valve itself. Bad gasket, etc.
    My 2 cents.
    rmorse[QUOTED][OP] likes this.
  11. Sep 13, 2024 at 5:26 AM
    rmorse
    Bobby
    Bowie, MD
    Ok so it sounds like my move should be to hit it with brake cleaner and then check it after I put some miles on it and see if it's wet again before taking it in
  12. Sep 13, 2024 at 5:30 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    The relief valve/bypass operates all the time, especially when cold or at high RPM. It keeps oil volume high and prevents damage to the oil cooler.
    The gasket is not listed separately for the Tundra, but other models use and list the part number. If you are under warranty, let the dealer solve it.
    rmorse[OP] likes this.
  13. Sep 13, 2024 at 5:30 AM
    KroppDuster
    Bilstein 5100s
    If it were me, that's exactly what I would do. Clean it and put some miles on the truck. As @Jowett said, it's not going to threaten the engine. The leak is small and you're not going to lose so much oil that it would threaten the engine. If you do see it wet again after you put 30-50 miles on...then just monitor the oil level at the dip stick until you can take it to the dealer (since you said it was still under warranty). Leave it wet, don't clean it again, so the dealer can see where the issue is.
    rmorse[QUOTED][OP] and Jowett like this.
  14. Sep 13, 2024 at 5:31 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    I don't like it. Clean the area thoroughly and leak check with an inspection mirror to find out where it's coming from.
  15. Sep 13, 2024 at 5:33 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Some oil leaked from the filter housing when you were replacing the filter?
    Leo's first likes this.
  16. Sep 13, 2024 at 5:45 AM
    rmorse
    Bobby
    Bowie, MD
    Nah, it was there before I replaced the filter. Good idea though
  17. Sep 13, 2024 at 11:04 AM
    Vahret832
    Vahret832 New Member
    Rick
    Maybe check the hose and clamp shown in the picture. Toyota sells OEM replacements for that but close to 80 bucks. You can maybe reposition it to have it better fitted
  18. Sep 14, 2024 at 2:56 PM
    bonefish
    bonefish New Member
    Peter
    Treasure Coast Florida
    Wouldn't the first step be put a socket on it and see if it's Tight?
    Vahret832 likes this.
  19. Sep 14, 2024 at 3:16 PM
    Azblue
    The Dirty T ( ^_^)_且
