Front sway bar end links and King coilovers
Discussion in 'Suspension' started by TheBeast, Sep 23, 2017.
  1. Sep 23, 2017 at 3:01 PM
    TheBeast
    TheBeast [OP] The Beach
    Hi,
    after getting alignment today I noticed the sway bar end links are pretty close to the King coilovers. They are not touching but pretty close. How close can they be ?
    thanks
  2. Sep 23, 2017 at 3:46 PM
    TheBeast
    Driver side:
    Passenger side:
  3. Sep 23, 2017 at 4:03 PM
    TheBeast
  4. Sep 23, 2017 at 4:06 PM
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    mine are about the same. they didn't touch at all when i was out in the dirt last weekend. you should be okay.
    trayday and TheBeast[OP] like this.
  5. Sep 23, 2017 at 8:23 PM
    Tacotundra
    Tacotundra New Member
    Vegas
    2017 Tundra
    Pull that sway bar out bro!!! I took mine off after I installed my coils. Works great.
    831Tun, crochetjohn, lionix and 2 others like this.
  6. Sep 23, 2017 at 9:28 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I 2nd removing the sway bar.
    831Tun and Tacotundra like this.
  7. Sep 23, 2017 at 9:36 PM
    stefan702
    stefan702 IG: 702stefan_
    Randy
    Las Vegas
    2015 Tundra TRD Offroad
    IG: 702stefan_
    Yea ditch that thing! You'll be much happier
    831Tun, 14burrito and Tacotundra like this.
  8. Sep 24, 2017 at 9:06 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS, ADS front and rear, Total Chaos UCA's, CB tie rods
    I'm contemplating putting my front sway bar back. Handles better on the road, more of a sportier feel especially around corners. If i can't fix the sway with the secondaries, it'll be back on.
    equin and stefan702 like this.
  9. Sep 24, 2017 at 9:07 AM
    stefan702
    Randy
    Las Vegas
    IG: 702stefan_
    Definitely handles better on road with them on!!
    equin and trayday[QUOTED] like this.
  10. Sep 24, 2017 at 9:30 AM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    You should be fine. The shock and sway link all bolt to the lower a-arm and will travel basically on the same plane. Find a tall curb and drive on it with one tire to simulate a full stuff, and use a jack up front to lift the frame and simulate full droop. Should give you a pretty good visual. Good luck
    equin, trayday and 831Tun like this.
  11. Sep 24, 2017 at 10:20 AM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Here’s a dirty pic of mine...
    I was worried when I first did the install also but zero problems! Seems to be normal! I have never removed my sway bar.
    equin likes this.
  12. Sep 24, 2017 at 10:22 AM
    TheBeast
    thanks guys !
    831Tun likes this.
  13. Sep 24, 2017 at 2:04 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Sway bars are for cars!. I still have both front and rear sways, gonna put them on if I decide to tow but with both off it feels so much better, rides better articulates like a goats legs on imperfections on and off road
    Tacotundra likes this.
  14. Sep 25, 2017 at 9:31 PM
    VegasTundra
    VegasTundra New Member
    Henderson, NV
    I was thinking of replacing my front sway bar with a Heftier one from a Sequioa to help with body roll.
    I may be in the minority here... so maybe I could get feedback on "Urban Assault" Street driving aside form the fun off road...
    Driving in Vegas is Nuts. Out of sheer Luck, I survived some ass hat crossing in front of me. I almost went OVER. Luckily for me, I looked down when my phone rang & ended up unintentially slowing Way down without really meaning to. I was able to do basically do an uncontrolled Drift without Rolling Over.
    Seems to happen here a ton here in Vegas, so I was wondering how to have a much better "Car" type handling for the Unexpected.
    Has anybody done the Sequoia Sway Bay Mod on a Tundra with King Adjustable Shocks set to Full Soft ?
    If so, is it worth the Cost to get some "Urban Handling" and not rolling our Rigs because of some Ass Hat crossing in front of us ?
    equin likes this.
  15. Sep 25, 2017 at 10:32 PM
    TheBeast
    I'm keeping mine on for now. I will monitor it to see if it rubs or hits the coilovers but from all the pictures I found online, they are all about the same. Even Fox or some TRD pro coilovers.
  16. Apr 27, 2018 at 5:35 PM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    i got my kings on and alignment done this week thought all was well until i went to turn into a parking spot.
    that is the first time i made a sharp turn and i heard a loud noise. i got under the truck to see what it was and there are 2 scratches on the bottom of the coilover from where the end of the sway bar hit it. is that some thing that can be fixed with another alignment ? or do i need to cut some of the sway bar off ? i was going to put my 35's on day after tomorrow and cut the cab mounts, i can cut some of the sway also. i would really like to leave it on.
  17. Apr 27, 2018 at 7:19 PM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    I have Kings with 295/70/18 and the front sway bar on. I have no problems with this set up. Sway bar doesn't hit at all.
  18. Apr 28, 2018 at 3:45 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    i did a bunch of google searching and i couldn't find anything. so i assume it could be fixed with an alignment (i have spc uppers), since i am the only one that has the issue. i will check and make sure it is tight when i mess with my tires, i have 35x12.5x17 on icon speed six ready to put on. i just told the shop i would put them on when i did the alignment cause i knew i would have to cut the cab mounts, and mess with the liner. i might just go ahead and trim the sway bar down some, if it is not loose.
  19. Apr 29, 2018 at 1:38 PM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    i put my 35's on today and can tell just by looking at the tires, when turned straight, that the bottom of the tire is angled in about 1/2" to 1" more on the bottom than the top. not straight vertically, i will take it back tomorrow and get them to do another alignment. i din't mess with trimming the ends of my swaybar, hopefully they will get it right. i did cut the cab mounts, and re-positioned the front bumper liner, and appear to have clearance, at least as far as i can turn it without the swaybar issue, lol.
  20. Sep 12, 2018 at 12:39 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    Did your issue get fixed? My shop is getting sway bar extensions or something to help with the hitting of the kings. But I have a 7in BDS lift, I wanna try to take the sway bar off when I off road to see how it is. I'm concered since im lifted so high, it wont be good
  21. Sep 12, 2018 at 1:41 PM
    TheBeast
    @anthonygan
    I ended up rounding the angles of the sway bar with a grinder. Gave me a bit more clearance. so far so good.
    Similar to the TRD sport front sway bar.
    equin and anthonygan like this.
  22. Sep 13, 2018 at 7:36 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    this is what we did on mine also
    anthonygan likes this.
  23. Sep 13, 2018 at 7:55 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    sorry i was late replying, we got a hurricane coming, been trying to get my ducks in a row. lol
    TheBeast[OP] and anthonygan like this.
  24. Sep 13, 2018 at 8:00 AM
    anthonygan
    2017 Cement TRD PRO
    Stay safe!!!
  25. Sep 13, 2018 at 8:43 AM
    TheBeast
    stay safe ! protect the Tundra at all cost ;)
  26. Sep 13, 2018 at 8:47 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    will do it is getting garaged over my camry for sure, lol
    TheBeast[QUOTED][OP] likes this.
  27. Jan 22, 2021 at 8:52 AM
    Jfisher
    Jfisher New Member
    Hey I'm having that very same issues right now with the same kit. What parts are those for the extension and can you please post a picture or dm what it looks like???? thank you in advance!
