LED headlight bulbs fog lights not working
Discussion in 'Lighting' started by 2005Tundra1986, Jan 13, 2017.
  1. Jan 13, 2017 at 6:07 PM
    2005Tundra1986
    2005Tundra1986 [OP] New Member
    Oscar
    Hi guys I'm new to this forum I have an issue with my 2005 Toyota tundra I just installed OPT 7 LED flux beam on my headlights but now my fog lights don't work when I turn my fog lights on the highbeams come on instead and when I put my highbeams on they turn on but the icon on the dash to let you know your highbeams are on does not turn on even though the highbeams are on anybody has a solution thank you
  2. Jan 13, 2017 at 6:10 PM
    2005Tundra1986
    Oscar
    And by the way forgot to mention I took the LED bulbs out and put back in The factory halogen bulbs and the fog light started working again the way they're supposed to
  3. Jan 13, 2017 at 6:12 PM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    This is extremely difficult to decipher because the lack of punctuation. Are you saying that when you turn on your fog lights, the high beams come on instead?
  4. Jan 13, 2017 at 6:13 PM
    2005Tundra1986
    Oscar
  5. Jan 13, 2017 at 6:18 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    I would have to look at a wiring diagram to know for sure but generally, LED's have a much lower power draw (resistance) than halogen. A lot of times you need to put a ballast resistor in parallel with the LED in order to make up for it. I would just put the stock ones back and leave it alone unless you want to look at a wiring diagram and possibly adding electrical components.
    LED bulbs in a reflector housing are usually no bueno regardless because they scatter light into the eyes of oncoming drivers.
    Pudge and NewImprovedRon like this.
  6. Jan 13, 2017 at 6:22 PM
    2005Tundra1986
    Oscar
    OK thank you for your time
    BlueFalconActual likes this.
  7. Sep 11, 2017 at 11:38 AM
    98tacoma27
    98tacoma27 Moderator Staff Member
    Ben
    2005 SR5 Tundra
  8. Sep 13, 2018 at 3:12 PM
    flyer581
    flyer581 New Member
    2005 Tundra Double Cab
  9. Sep 13, 2018 at 5:54 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    This^
  10. Oct 26, 2019 at 9:41 AM
    mandi wilkerson
    mandi wilkerson New Member
    mandi
    06 tundra sr5
  11. Nov 4, 2019 at 10:32 AM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore, My Factory Skid Plate Was Stolen
    Or get bulbs with the resisters built in. That's what mine are. My fogs are LED to help see better in foul weather, and they do a pretty good job at it.
  12. Nov 4, 2019 at 10:39 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1 another. If you are going to use LEDs then do it right otherwise you are just wasting your money and blinding other drivers.
    Pudge[QUOTED] likes this.
  13. Jun 11, 2021 at 2:58 PM
    RalphKaz
    RalphKaz New Member
    can you point me to the LEDs that have built in resistors?
    LuckyLainey likes this.
  14. Jun 11, 2021 at 3:30 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You don’t need resistors when using leds for headlights, fog lights, brake lights, dome lights, map lights, marker lights.
  15. Jun 11, 2021 at 3:36 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Perhaps on a newer truck, but on our first gen tundras you need resistors on the headlights because they "talk" to the computer via resistance saying "hey, my high beams are on. Turn on the High beam light on the dash!" This also engages, and disengages the fog light relay.
  16. Jun 11, 2021 at 3:37 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Also...
    received_307565297195417.jpg received_249503956190461.jpg received_361211895247149.jpg
    Taco-Spike and bmf4069 like this.
  17. Jun 11, 2021 at 3:46 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  18. Jun 11, 2021 at 6:28 PM
    bmf4069 Yup, that's car parts in a dishwasher
    Taco-Spike and Tundra2[QUOTED] like this.
  19. Sep 3, 2021 at 1:18 PM
    swivilposter
    swivilposter New Member
    Steven
    2004 Toyota Tundra SR5 DC
