Help identifying this topper for 2017 doublecab
Discussion in 'Tonneau Covers, Caps and Shells' started by TXDrifter, Aug 19, 2017.
  1. Aug 19, 2017 at 5:05 PM
    TXDrifter
    TXDrifter [OP] BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    I am looking into buying a topper for my 2017 double cab and ran across a guy selling one off of his 2016 double cab. The color seems to match my Metallic gray but after examining the pictures I am not 100% certain its for a Tundra. Owner believes its a century.
    00N0N_2dnIxLQWhaZ_1200x900.jpg 00t0t_bVb5SHI8mw5_1200x900.jpg 00U0U_5DyTkKnrA9m_1200x900.jpg
    I appreciate any information you all may have.
    Thanks
    Jeff
  2. Aug 19, 2017 at 5:08 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    This part right here doesn't look right. I'm assuming it's for the third brake light, but normally I don't see 'em with that gap for a light. Could you drive to where he is and have him help you install it before you give him $$?
  3. Aug 19, 2017 at 5:59 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    If it's a Century it should have a small shield shaped emblem on each side that says CTC. The contour strip at the bottom of the rear door looks correct for a Tundra. If you have a pic straight on from the side I can tell you with 99% certainty what it fits.
  4. Aug 19, 2017 at 6:02 PM
    TXDrifter
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    This is the best I can get until seller gets home from work and gives more info.
  5. Aug 19, 2017 at 6:03 PM
    TXDrifter
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    That is exactly what concerned me as well. I cant drive up and see because he is a 5 hour drive one way. I wanted to identify before the trip.
  6. Aug 19, 2017 at 6:23 PM
    duece292
    Greg
    Green Bay, WI
    Unfortunately the roof doesn't tell me much...other than the rails are Yakima. If he can get you a shot straight on of the whole side, I'm looking for the angle of the front and if it hooks forward at the bottom. I wouldn't be concerned with the third brake notch, most caps are that way, the manufacturers over compensate for clearance around the light because the caps fit so tight to the cab of the truck.
