Total chaos UCA's
Discussion in 'Suspension' started by Tundra_mike89, Aug 17, 2017.
  1. Aug 17, 2017 at 5:20 PM
    Tundra_mike89
    Tundra_mike89 [OP] New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    i am about to grease my bushings on my total chaos uca's. Do I need to jack up the truck to do this or can I do it while the truck is on the ground? Thanks
  2. Aug 17, 2017 at 5:49 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You can do it with the truck on the ground. Clean but don't lube the uniball.
  3. Aug 17, 2017 at 5:50 PM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Ok just so i understand, grease the bushings then use dry ptfe spray on the uniball? Right
    Sefferston likes this.
  4. Aug 17, 2017 at 5:52 PM
    TheBeast
    TheBeast The Beach
  5. Aug 17, 2017 at 5:54 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The uniball, from what my fab guy tells me and from what I know about plastics, doesn't need to be lubed at all. The ball is in contact with ptfe inside the cup. If you lube it, you'll attract more dirt. At least that's what I've been told... It might be a topic that is passionately debated too.
  6. Aug 17, 2017 at 5:57 PM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Ok. Just as long as I can lube the uca's while under load of the vehicles weight. They were making noise on the way to work. So I was gonna take my lunch break to go grease them up. But I don't have a floor jack
  7. Aug 17, 2017 at 6:05 PM
    Per Toytec-
    If you're greasing the bushings you need to loosen the nut on the long bolt that runs through the UCA
    The pressure from the grease gun can tear the poly bushings and will need to re- torque the nut afterwards
  8. Aug 17, 2017 at 6:37 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    This exactly. You can do it with the truck on the ground but its way easier with the wheel off so you can get to the bolt
    T-Rex266[QUOTED] likes this.
  9. Aug 17, 2017 at 6:44 PM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Ok I just got done greasing them. I'm at work and I don't have access to a torque wrench. I tightened down pretty good on the bolt after greasing them. The torque setting for that is 85 ft lbs. so I got down pretty good on it. I'll be at sears tomorrow to get a torque wrench
    T-Rex266 likes this.
  10. Aug 17, 2017 at 6:53 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    The through bolt torque spec is 173 ft lbs. The bolt that connects the uni-ball to spindle is 100 ft lbs
    831Tun and T-Rex266 like this.
  11. Aug 17, 2017 at 6:57 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    The upper A-arm long bolt is 85 ft/lbs. Are you maybe thinking of the larger lower a-arm bolt Kris ?
  12. Aug 17, 2017 at 7:00 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Maybe for stock but not with TC uppers. I'm running these and always torque to 175. See in red from TC install guide:
    831Tun likes this.
  13. Aug 17, 2017 at 7:02 PM
    CM-LENNY
    San Diego, CA
    I stand corrected Kris. They say that's the 1st step, admit defeat.....:rofl:Good call by you!
  14. Aug 17, 2017 at 7:04 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Haha. I did a double take when I read that too. Actually called SDHQ to verify all the torque specs lol
    831Tun and CM-LENNY[QUOTED] like this.
  15. Aug 17, 2017 at 7:19 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Tundra_mike89[OP] and boardude like this.
  16. Aug 17, 2017 at 7:21 PM
    CM-LENNY
    San Diego, CA
    boardude likes this.
  17. Aug 17, 2017 at 7:43 PM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    O wow thank y'all!! I need to go tighten down a little more before I leave work. Y'all may have saved my life!!!
