TRD shift knob QUESTION ???
Discussion in 'General Tundra Discussion' started by CJ21, Aug 15, 2017.
  1. Aug 15, 2017 at 6:25 PM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    Does anybody have an issue with their TRD shift knob Twisting all the way down without having any play In it. And if so is there anyway to fix it?
  2. Aug 15, 2017 at 7:01 PM
    Aurora CO
  3. Aug 15, 2017 at 7:04 PM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    I'm not understanding you.
    It screws on, and has no play correct? Your knob shouldn't be moving/twisting once you have it set unless if you're removing it/tightening it back down.
  4. Aug 15, 2017 at 7:07 PM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    It's screws down but even when it's screwed down all the way it's still has play where you can feel it wiggle from left to right and it will not get any tighter.
  5. Aug 15, 2017 at 7:08 PM
    Before I switched mine to the Toytec shift knob, I had the same issue.
  6. Aug 15, 2017 at 7:10 PM
    Aurora CO
    Most likely gets stripped after awhile and probably re-tapping won't help.
  7. Aug 15, 2017 at 11:09 PM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    Try some plumbers tape on the treads. Might be an easy fix. My OCD would be off the charts with a loose gear shift knob.
  8. Aug 16, 2017 at 9:03 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    When I bought my TRD shifter knob it turns out I did one to many turns when trying to tighten it down to what I thought was appropriate and it snapped/cracked the inner thread lock making it wobble. Seems to my they should screw on tighter but they don't. It's a fine line to being screwed on firmly vs just enough.
  9. Aug 16, 2017 at 9:10 AM
    Jagamov
    Jagamov New Member
    Greg
    2017 White Tundra Platinum
    Yeah, the instructions say not to over tighten it. So with my OCD, it was an issue the first time I shifted it and it turned on me.
    So my fix was to use a good amount of Blue Loctite on the threads, screw it down into position and let it sit over night.
    Problem solved.
    KnuckleHD, CJ21[OP] and trayday like this.
  10. Aug 16, 2017 at 1:53 PM
    KOZ
    KOZ New Member
    Indiana
    2008 Toyota Tundra SR5 Regular Cab
    TRD Supercharger TRD Lowering Springs TRD Front Sway Bar TRD Rear Sway Bar URD Pulley 2.345" TRD 22" Wheels SOS 2.5"/4.5" Lowering Kit StopTech Big Brakes Front & Rear JBA Headers JBA Cat Delete w/O2 Sims Dirty Deeds Budget Dump
    I've never had an issue with mine...
  11. Oct 10, 2018 at 8:17 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    how do you like that thing compared to the stock one
  12. Oct 10, 2018 at 8:23 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Mine is tight....
    dv8TRDPRO likes this.
  13. Oct 10, 2018 at 8:24 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    what did that run you? $100+?
  14. Oct 10, 2018 at 9:49 PM
    dandailey
    Dan D
    Newport News Va.
    Right at $100.
  15. Oct 11, 2018 at 4:08 AM
    Aurora CO
    Way better. Stock one sucks. ToyTec's runs around $60. Not much mark up.
    GNTundra likes this.
  16. Oct 11, 2018 at 6:24 AM
    Hunterd_22
    Hunterd_22 New Member
    Hunter
    Kentucky
    2010 Black Tundra Rock Warrior
    Does it get really hot in the sun? I have the one that comes on rock warriors and the aluminum on the sides gets really hot in the summers.
  17. Oct 11, 2018 at 6:41 AM
    Aurora CO
    I've never noticed so I guess not.
  18. Oct 11, 2018 at 7:17 AM
    buffaluphagus
    buffaluphagus —————————————
    What size nuts u got there
  19. Oct 11, 2018 at 8:01 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Proper :benchpress:
  20. Oct 11, 2018 at 12:50 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    :popcorn:Two words, Lock Tight...:popcorn:
  21. Oct 11, 2018 at 12:56 PM
    buffaluphagus
    Heck ya thanks
  22. Oct 12, 2018 at 12:33 PM
    Hunterd_22
    Hunter
    Kentucky
    Yeah I may end up trying to do that
  23. Oct 23, 2019 at 4:51 PM
    dv8TRDPRO
    dv8TRDPRO NOOGTRDPRO
    Chattanooga
    2017 Tundra Pro White
    Weather Tech mats, Stubby antenna, AJT gear shift knob, AJT keyfob, Tundra door sill protectors, Cup holder inserts, door pocket inserts, console inserts, Tundra tailgate letter, and TRD PRO bed insert. Kenwood dnx996xr 1299 with navigation, vehicle gauges, and tire pressure sensors gauges Keyless Remote CL6 app remote start 4 rolls of sound shield 1 Jl rd 900/5 2 Jl c2 650 components 2 Jl 10w1
    Where did you find this one?
  24. Sep 29, 2020 at 8:28 PM
    Crazy Marty
    Crazy Marty New Member
    Mission, British Columbia, Canada
    2015 Tundra Crewmax Limited
  25. Sep 29, 2020 at 8:31 PM
    Crazy Marty
    Well, I did the same thing. Cracked inner thread . Were you able to fix it? How? This loose TRD shifter knob is going to make me crazier!
    Inquiringone likes this.
  26. Sep 29, 2020 at 9:33 PM
    Inquiringone
    Ter
    NorCal 408
    JBWeld May work for that issue.
    Custom shifter knobs can be cumbersome some times.
    I keep fiddling with my new purchase and I think I’m there, time will tell. Sold 15.00 purchase
  27. Sep 29, 2020 at 9:40 PM
    Crazy Marty
    I need to be able to get it off in the future! I’ve got pieces coming for the console, etc...
  28. Sep 30, 2020 at 5:58 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Use some red Loctite and let it sit for a day and see if that works
  29. Sep 30, 2020 at 8:42 AM
    vl184009
    Vicky
    Southern, Ca.
    Nope, but then again I didn't try. I went to Toyota and bitch that it came that way and the guy ordered me a new one for free. I know I lied, but Toyota should give a warning to consumers to not turn to much. I mean, who would'nt keep turning until it was tight?
  30. Oct 1, 2020 at 6:22 PM
    Famof5Tundy
    Famof5Tundy New Member
    2020 MGM CM Platinum
    Just getting started
    It's one of the weaker points of the tundra is the standard shift knob. The cheap hollow plastic feel doesn't set a time of quality. Especially in the 80s when Toyota made their brand built on placing higher quality plastics/rubber in high touch areas. Then they throw this cheap hunk of plastic on here? Honestly in 2017 I would have bought a tundra, but it was such a huge turnoff that I bought a Tacoma. A few years later, bought a platinum, immediately upgraded to all black TRD shift knob and turned until it was snug...doesn't move, love it.
