I have a 1,gen 2006 Tundra 4.7 4 door. Swapping my rear end problems
Discussion in 'New Member Introductions' started by Bucksbugs, Jun 22, 2023.
  1. Jun 22, 2023 at 12:27 PM
    Bucksbugs
    Bucksbugs [OP] New Member
    2006 Toyota Tundra SR5 4 Dr 2 Wd 4.7
    Rear end Swap
    I have a 2006 1st gen 4 door Tundra with a 4.7 the rear dif went out it was a 3.91 rear end with ABS. Purchased a rear end from a 2000 Tundra acces cab 4.7 without ABS got it in and hooked up disconnected the 2 fuses and still have some brake sticking plus the e brake cable seems to be way to long for the new rear end.
  2. Jun 22, 2023 at 2:23 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  3. Jun 25, 2023 at 4:50 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  4. Jun 25, 2023 at 5:07 AM
    Welcome from NY.
  5. Jun 28, 2023 at 5:18 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  6. Jun 28, 2023 at 5:24 AM
    Not sure those two rear axles are direct swappable. The AC is narrower by almost 2” I believe and May lack what a newer VSC (if equipped) system needs. Pinion flanges May also not match
