Diamondback Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by jeffw6236, Aug 7, 2017.
  1. Mar 25, 2023 at 5:38 PM
    #901
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    2022 Limited Crewmax L
    MBM - TRD Offroad
    Got my TracRac trimmed down (took 7.5" off the uprights) and reinstalled along with my DB tie-downs. Next is the bike racks.
  2. Mar 30, 2023 at 7:16 PM
    #902
    shorenetworks
    shorenetworks New Member
    This thing is sweet I would say the last time I was this impressed was when I got my first Benchmade knife. Looking forward to rain to check on the weather tightness and also happy to have back the one feature I missed on my Ridgeline.
  3. Mar 31, 2023 at 8:43 AM
    #903
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    I predict much happiness!
  4. Mar 31, 2023 at 2:23 PM
    #904
    TheSS712
    TheSS712 New Member
    Shayne
    2022 Army Green Tundra Limited
    I get my Diamondback next week. Can't wait to rip the Bakflip MX4 off and pop the DB on. Looks good as I have the same truck/ color!
    shorenetworks likes this.
  5. Mar 31, 2023 at 3:08 PM
    #905
    Beckusmc
    Beckusmc New Member
    Black Tundra Platinum
    I was working on installing my diamondback cover. I found that there is a drain channel at the very top with a bracket and the channel for the accessories right below it. I am assuming i just need to take the bracket off and reinstall the channel for the tie down in the original holes at the top. Has anyone else come across this problem?? Not sure what the drain channel was there for i always had water in my truck bed.
  6. Apr 1, 2023 at 2:38 PM
    #906
    Beckusmc
    Beckusmc New Member
    Installed my Diamondback HD today!
  7. Apr 1, 2023 at 2:47 PM
    #907
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    Did you put the small rectangular spacers underneath the center section of the bed caps? I didn’t because the night before I silicone sealed the caps, had no idea it came with those to put on :anonymous:
    I get a little water dripping down on the wheel wells in the center. Just wondering if I should pull up the caps and put those spacers on there are re-seal them and maybe that’ll fix the leak
  8. Apr 1, 2023 at 2:49 PM
    #908
    RegGex
    Oregon
    2021 TRD Pro CM
    This is just priceless. Leaky feels :rofl:
  9. Apr 1, 2023 at 4:05 PM
    #909
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Yes I put them on and I don't get any leaks except near the top of the tailgate where it opens and only if I'm parked nose down on a hill and it's a downpour but I can't seal the tailgate gaps 100% so no biggy. I would definitely put them on.
    Is it leaking from the center section of the diamondback or from under the caps? Silicone won't help if the caps get deformed.
  10. Apr 16, 2023 at 8:30 PM
    #910
    chuckfinley
    chuckfinley New Member
    2021 LR Tundra TRD Pro
    2021 LR Sequoia TRD Pro
    I love my diamondback, but a PSA. DO recheck your tension on your mounting clamps (as the installation directions state so to do). Mine had loosened enough that one was in the bed, one on the other side about to fall off, and the remaining 2 were down to roughly hand tight.
  11. Apr 16, 2023 at 8:45 PM
    #911
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    I didn’t put any spacers or butyl tape when I installed mine. It has been pretty dry with all our rain and lots of snow this year.
    You can tighten it up by pulling the covers down and adjusting the locking bars.
  12. Apr 16, 2023 at 10:33 PM
    #912
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I think you need to flip the center section around, they put the black seal around the whole cover then cut the seal at the hinges, so the seal may not match when the center section is flip front to back.
  13. Apr 19, 2023 at 2:04 PM
    #913
    spigatelli
    spigatelli New Member
    DFW, Texas
    2023 Limited Hybrid CrewMax 6.5 in Army Green
    I just read through this entire thread and only saw 1 truck with the 270 cover. I ordered a 270 from the outlet. Should be here in a few days. FYI, there are a few Tundra covers in the outlet, right now.
    Soupbean77 and PBNB like this.
  14. Apr 19, 2023 at 2:46 PM
    #914
    NewImprovedRon
    Ron
    NW Arkansas
    Not sure why the 270 isn't more prolific. I like the split front panel as well as the SE I have. In fact, the 270 may be more efficient to use.
    Soupbean77 likes this.
  15. Apr 19, 2023 at 2:55 PM
    #915
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    I like the 180 and 270 designs for access to the contents of your box. I had to settle on the SE because of the racks that are one mine. The little boxes that they made are nice to organize stuff.
  16. Apr 20, 2023 at 8:42 AM
    #916
    spigatelli
    DFW, Texas
    I want to try and put a rack that fits in the middle and then closer to the rear. We'll see what I can come up with.
  17. Apr 21, 2023 at 2:24 AM
    #917
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    Any pics of your 270…?
  18. Apr 21, 2023 at 5:59 AM
    #918
    NewImprovedRon
    Ron
    NW Arkansas
    I've got the SE model.
    This came off the Diamondback web site...
  19. Apr 21, 2023 at 1:13 PM
    #919
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I think they require a HD for racks
  20. Apr 21, 2023 at 1:19 PM
    #920
    spigatelli
    DFW, Texas
  21. Apr 27, 2023 at 1:08 PM
    #921
    spigatelli
    DFW, Texas
    The 270 arrived today. I love this thing!
    NWFLATundra, ChiefG, WoodyOne and 7 others like this.
  22. Apr 27, 2023 at 3:14 PM
    #922
    MadMaxCanon
    Looks awesome, how was the install?
  23. Apr 27, 2023 at 3:57 PM
    #923
    spigatelli
    DFW, Texas
    Not too bad. I had a buddy swing by to give me a hand and it took less than 30 minutes with his help.
    MadMaxCanon and NewImprovedRon like this.
  24. Apr 27, 2023 at 5:10 PM
    #924
    NewImprovedRon
    Ron
    NW Arkansas
    Looks great!
    spigatelli[QUOTED] likes this.
  25. May 4, 2023 at 4:16 PM
    #925
    Outbound
    Outbound SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    I gotta talk up Diamondback's customer service for a minute.
    I forgot to order 4 spare cleats for my cover when I originally bought it so I went to order them yesterday. The cleats were $84 CAD and shipping was $73. That shipping charge seemed nuts for such small pieces, so I emailed Diamondback to see if there was a cheaper way to ship.
    Their customer service rep Ben replied with an invoice he put together with a $20 shipping charge, making the total a much more reasonable $107 CAD when the dust settles. That's awesome service and they get top marks in my book for being flexible enough and willing to work with a customer.
    Way to go Diamondback!
  26. May 5, 2023 at 3:33 PM
    #926
    WoodyOne
    WoodyOne New Member
    Spring, TX
    2023 1794 Blueprint 4x4
    Ordered a SD 6.5' can't wait for it to arrive
  27. May 26, 2023 at 10:36 AM
    #927
    ScottW714
    ScottW714 New Member
    Ordered on a Wednesday, in Houston Monday, and in my garage on Thursday, on truck 8 days after I ordered. I was expecting 3-4 weeks.
    Took a solid 8 hours to add the the tracks. I wanted them perfect, so spend about 5 hours measuring.
    Trying to space the tracks and keep them parallel to a trapezoid with round corners is no easy feat, but it came out perfect.
    I had the core bars and towers from my 2016, I might get HD bars. Really wish Yakima sold the Trim HD bars in the US.
  28. Jul 10, 2023 at 6:32 PM
    #928
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    2023 Limited L TRD OR MBM
    Picked up and installed a DiamondBack SE today. I was going back and forth between DB and Retrax... and a Canopy too. Hopefully will serve me well and I won't need to switch to a canopy.
    As a bonus a six foot step ladder fits under it - it wouldn't with any other "flat" tonneau cover :thumbsup: Very happy with the quality and simplicity of the install.
    IMG_4782.HEIC.jpg IMG_4784.HEIC.jpg IMG_4785.HEIC.jpg IMG_4786.HEIC.jpg IMG_4787.HEIC.jpg IMG_4788.HEIC.jpg IMG_4790.HEIC.jpg
  29. Jul 10, 2023 at 6:39 PM
    #929
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    In the mud, now you need a bedrug to keep all that stuff from sliding around in that expanse called a bed! ;)
    NewImprovedRon and in_the_mud like this.
  30. Jul 10, 2023 at 6:49 PM
    #930
    in_the_mud
    in_the_mud GSD
    Raph
    Calgary, AB
    True. I am waiting for a bed mat (backordered) cause everything is running around in there now.
