New Member with 06 Limited Double Cab
Discussion in 'New Member Introductions' started by gmucoolman, May 11, 2023.
  1. May 11, 2023 at 12:01 AM
    gmucoolman
    gmucoolman [OP] New Member
    2006 Red DC limited
    Non Yet
    New member saying hello from VA. Just got my FGT 2 weeks ago and have been browsing this forum and discovering a wealth of knowledge. Looking to do some mods on the tuck but want to keep it pretty stock as well as restore it where it needs maintenance etc.
    Rig is in pretty good shape 158,000 miles, 1 owner before me, no accident, some rust and a small frame repair, documentation of timing belt and water pump being done @~90K, Taupe interior and all original books and window sticker.
    List of first mods/maintenance is:
    1. New tires
    2. Paint correction
    3. Replace moon roof gasket ( looks like squirrels got to it)
    4. Bell crank replacement Driver side seized up
    5. back up cam with auto dim mirror and lcd screen (need some help/guidance here, confirmed it has been wired for Auto dimming)
    6. maybe some suspension work LBJs and alignment not sure how I feel about a lift
    Any advice would be welcome. thx!
  2. May 11, 2023 at 3:31 AM
    1stGtundra06
    1stGtundra06 New Member
    06 DC White Tundra
    Bilstein 6112 7/5 clip Front/5100 rear; 255/80r17 Toyo R/T Trail
    Welcome from CA! Nice to see another 06 DC. Didn't find too many threads about this but on the 06, if you're looking for larger tire size without too much work, 255/80r17 on stock rims fit well. Do have Bilstein 6112 1.6" lift in the front and have only seen light rubbing on driver side frame after off-roading (did not see evidence before off-roading). UCAs and LCAs are stock and haven't had any other issues.
  3. May 11, 2023 at 3:34 AM
    1stGtundra06
    06 DC White Tundra
    In addition to the LBJs (OEM of course), would recommend checking out the LCA bushings, was one of the items I had to fix after purchasing my truck but it was in an accident before so maybe that had something to do with it?
  4. May 11, 2023 at 4:26 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  5. May 11, 2023 at 4:53 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  6. May 11, 2023 at 5:48 AM
    Welcome from NY.
  7. May 11, 2023 at 7:07 AM
    gmucoolman
    2006 Red DC limited
    Non Yet
    Thanks all for, and the advice DC is the perfect size truck for my uses somewhere between current gen taco and later gen tundras
