Vsc off and trac control only lights on, help please- NO Check Engine light however
Discussion in 'New Member Introductions' started by Bert13, Apr 27, 2023.
  1. Apr 27, 2023 at 9:07 AM
    Bert13
    Bert13 [OP] New Member
    I have a 2008 Tundra 5.7L 2wd. I have a flashing: "VSC OFF" light & the "Traction Control" light ( staying on while driving for about 6 months now. Thankfully, NO Check engine light ,happening. Any idea how I can get these lights off while driving and get Traction control back??-- Thank you again for your help.
  2. Apr 27, 2023 at 8:25 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  3. Apr 27, 2023 at 8:34 PM
    Blasterrr
    Blasterrr New Member
    Abs light on? Might be a speed sensor/abs sensor issue.
    KNABORES likes this.
  4. Apr 28, 2023 at 10:08 AM
    Bert13
    Already disconnected battery numerous times for long periods of time and no luck fixing it. No other lights are on the dash other than a low tire pressure light which I attribute to a bad expensive tmps sensor. -very strange. Any other thoughts anybody? thanks
  5. Apr 28, 2023 at 5:54 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Try the link I posted above. The guys in that thread are a mix of retired Toyota mechs and other knowledgeable folks.
  6. Apr 28, 2023 at 6:09 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Probably wants a zero point calibration. Need a slighly more advanced obd2 reader to read ABS codes. This way you can clear it, I don't think disconnecting the battery will work.
  7. Apr 28, 2023 at 6:17 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Have a mechanic check your ABS Control Module.
  8. May 1, 2023 at 3:45 AM
    Welcome from NY.
