2014 toyota tundra JBL radio black screen but back up camera works any fix? Or any fuse to check
Discussion in 'Audio & Video' started by Asalinas4, Mar 16, 2023.
  1. Mar 16, 2023 at 5:10 PM
    Asalinas4
    Asalinas4 [OP] New Member
    Adriel
    2014 Toyota Tundra 1794 edition
    2014 toyota tundra JBL radio black screen but back up camera works any fix? Or any fuseto check or replace, has anyone had this issue it was working normal while driving black screen ... then back up camera turns on while going in drive.
  2. Apr 27, 2023 at 4:17 PM
    MrBOOBOO
    MrBOOBOO New Member
    Vehicle Modifications:
    I have a 2014 Tundra platinum and I have the same thing. Black screen but the backup cam works. I have tried fuses and no luck.
  3. Apr 28, 2023 at 2:53 AM
    Asalinas4
    Adriel
    Yes, I found the issue it was the battery all along the guy in auto parts store sold me a battery that had 700 amps. The correct battery is 1200 to 1400 amps asp per the user manual that solved the issue. Hope it solves your issue.
  4. Aug 22, 2023 at 9:06 AM
    mental midget77
    mental midget77 New Member
    Paul
    2014 Grey Tundra Crew Max
    Lifted, bumpers, brakes, wheels.
    I have the same problem. Have there been any solutions,
    Asalinas4[OP] likes this.
  5. Aug 22, 2023 at 10:28 AM
    Asalinas4
    Adriel
    Yes, on my situation I bought the wrong battery for the truck the battery that caused it was a 700 Amp and the correct battery was between 1200 to 1400 amps after I got the correct battery it work normally no more issues. Hope it helps
  6. Sep 10, 2023 at 8:41 AM
    curboys465
    curboys465 New Member
    North Richland Hills, Texas
    2017 Platinum Tundra - Black
    None
    I have the same issue with my JBL Entune radio/gps on a 2017 Tundra Platinum. Worked fine on 9/8/2023, but wasn't working yesterday morning. My back-up camera is working though.
    I see mentioned where an incorrect sized battery was the issue. My battery was replaced by a toyota dealer a few months ago so I have doubt that would be the cause of my issue. Would think that they use the proper amp battery.
    Any other solutions ?
