Rear view mirror upgrade?
Discussion in '3rd Gen Tundras (2022+)' started by -Mike-, Mar 19, 2022.
  1. Jan 17, 2023 at 6:47 AM
    Spdfreak91
    Spdfreak91 New Member
    nope where the sunglass holder is , one side has tabbed pins (front if i remember correct) rear has two stationary tabs that go under headliner. You'll see it clipped alone by itself not connected.
    colekbod likes this.
  2. Jan 17, 2023 at 9:29 AM
    vegask
    vegask New Member
    Kurt
    Northern NV
    2023 Tundra SR5 Premium
    Sorry a little off topic. Just looked at my spec sheet and I see no mention of homelink. Does "digital rearview mirror" imply that?
  3. Jan 17, 2023 at 9:42 AM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    There are 3 different rearview mirrors in the Gen3 Tundra.
    Regular rearview
    Homelink rearview
    Homelink on Digital rearview (with SPA)
  4. Jan 23, 2023 at 7:38 AM
    colekbod
    colekbod New Member
    2023 SR5 Sport Lunar Rock
    @Spdfreak91 The GR 86 mirror you installed seems pretty similar to the Gentex one I was looking at, but better price. I think I'll go that route.
    My only question now, is that mirror a smaller width than the OEM Tundra mirror? Since the GR 86 is a small car, I don't want my mirror to be smaller than the current one, which is barely wide enough.
  5. Jan 23, 2023 at 9:56 AM
    Spdfreak91
    I thought it may have been as well but the frameless GR 86 mirror is just a tad bigger than the mechanical dimming one that was in there I THINK, I also included the wiring diagram from MEMORY, so make sure you check your wiring before attempting this, and if not people do sell the wiring with connectors already on, this was just my way to save a buck and make it work.
  6. Jan 23, 2023 at 10:00 AM
    colekbod
    colekbod New Member
    Awesome. I appreciate your help!
  7. Jan 23, 2023 at 10:04 AM
    Spdfreak91
    they also make a battery powered Homelink mirror " PT374-00210 Toyota Frameless Homelink Rear View Mirror . If thats all you want and dont want to mess with wiring.
  8. Feb 2, 2023 at 9:49 AM
    colekbod
    colekbod New Member
    @Spdfreak91
    I got this far and soldered the wires, now I just need to put the pins back in the black connector that connects to the trucks upper console harness. Do you remember which of these four wires from the actual mirror is 12v key, constant, and ground?
  9. Feb 2, 2023 at 10:48 AM
    Spdfreak91
  10. Feb 2, 2023 at 10:51 AM
    colekbod
    colekbod New Member
    Nice! Thank you!
  11. Feb 3, 2023 at 9:20 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If anyone is looking for a auto dim, homelike and compass mirror I have a couple I plan on selling. I ordered three of these because I got them at a very good price. I would sell them for $100 each shipped to the continental US. I'll post more pictures if there is an interest.
    rwsessions likes this.
  12. Feb 4, 2023 at 9:19 AM
    colekbod
    colekbod New Member
    @Spdfreak91
    Did you even connect the grey wire from the mirror to anything?
    I’m assuming green and white are together to constant power, black is ground, and grey is ignition power?
  13. Feb 4, 2023 at 10:22 AM
    Spdfreak91
    yeah, that way the homelink only works when the truck is on
  14. Mar 9, 2023 at 8:35 PM
    jkk001
    jkk001 New Member
    @colekbod @Spdfreak91
    Is this correct? I’m trying to follow along and this is what I ended up with:
    3 pin mini harness from mirror to 5 pin tundra optional/cam plug. I have green and white to 12v, gray to key, and black to ground?
    Thanks!
  15. Mar 10, 2023 at 6:17 AM
    colekbod
    colekbod New Member
    @jkk001 I have green and white to ignition power, black to ground, and I didn't connect gray at all. Mirror works great and only when the ignition is on.
  16. Mar 10, 2023 at 7:31 AM
    jkk001
    jkk001 New Member
    Thank you, yea I thought it wasn’t correct when I was able to use homelink with car off. Thanks for the clarification and more info for future reference.
  17. May 22, 2023 at 1:27 PM
    SlimSeville
    SlimSeville New Member
    2022 Tundra SR5 XP
    If anyone is wonder if the OEM frameless mirror with homelink (part number: PT374-00210) works, it does! Even though the Toyota website states that it doesn't fit the 2022+ Tundras it actually does. It's a little bit bigger than the basic mirror too. The buttons are located underneath. I got it from the parts.toyota.com site for $129.
    rwsessions and Yoda-Fan45 like this.
  18. May 22, 2023 at 1:41 PM
    nodak67
    nodak67 New Member
    JR
    thats weird. my 2014 4runner you can use the homelink button w/o vehicle being on from the factory. i ususally push the door open before i even push the PTS button..
  19. Aug 11, 2023 at 12:08 PM
    rwsessions
    rwsessions New Member
    2023 Silver SR5
    Was that part number plug and play, or did you have to perform a little electrical sorcery as well?
  20. Aug 12, 2023 at 6:15 AM
    #50
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    I'm running that mirror in my Tundra as well. It's battery powered, so no wiring necessary. They say the battery should last 10-15 years. Range on home link is great, looks so much better than the factory mirror. All positives in my mind!
    rwsessions[QUOTED] likes this.
  21. Aug 13, 2023 at 1:00 PM
    #51
    rwsessions
    2023 Silver SR5
    Very nice!! I think I’ll be pulling the trigger on this sooner than later. Thanks for blazing the trail, Dustin!
    DMackler[QUOTED] likes this.
  22. Aug 13, 2023 at 1:08 PM
    #52
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    I think you'll be very happy with it for the price and ease of installation!
  23. Aug 13, 2023 at 1:39 PM
    #53
    rwsessions
    2023 Silver SR5
    I think I will be too. I don’t like a lot of unnecessary clutter, so I’m excited to be able to get rid of my normal garage door opener from the visor.
  24. Aug 13, 2023 at 4:12 PM
    #54
    SupaCoopa
    SupaCoopa New Member
    2022 Tundra 4x4 Crewmax
    Man - I love my camera rear view - i use it all the time (unless my back window is down, in which case the reflection makes it hard to see)
  25. Dec 26, 2023 at 10:06 AM
    #55
    Goobax
    Goobax New Member
    Just got one of these for Christmas and not able to get my mirror and the OEM dash cam working simultaneously. I used their option of (have 5 pin connector and it’s occupied) so they included a jumper harness but only the mirror powers on and works and now the dash came doesn’t.
    Sent an email to the company to see if this is known or what happened but just as an FYi if anyone goes down this route.
    Looks like it was pinned out correctly so wondering what went wrong but hasn’t been my week for electrical stuff and the truck lol
