SPC upper control arms
Discussion in 'Suspension' started by Phillipk98, Jun 11, 2017.
  1. Jul 31, 2017 at 7:13 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Our kits will not come with new spindles.
    The Diff Drop kit will help decrease the angles of your CV Axles (if you are 4WD). The UCA's are going to be what helps you with aligning your vehicle properly.
    -David
  2. Jul 31, 2017 at 6:24 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    So they wouldnt help with your front alingment?? I'll probably need some UCA'S then...
  3. Aug 1, 2017 at 8:42 AM
    Toytec Lifts
    Denver, CO.
    The diff drop will not help anything when it comes to alignment, the UCA's will.
    -David
  4. Aug 1, 2017 at 6:20 PM
    Tundra_mike89
    Tundra_mike89 New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    What are the benefits of spending the extra 250 dollars for the total chaos? And how much lift does the toytec boss lift the front end? Sorry to hijack
  5. Aug 2, 2017 at 2:37 AM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    Ball joint vs uniball design, and name to back it up.
    Uniballs can yield more adjustability and travel than ball joints, but they require a little more attention.
  6. Aug 2, 2017 at 2:43 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    By more attention you mean grease them often?
  7. Aug 2, 2017 at 3:17 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    And make sure they're clean
    Sefferston likes this.
  8. Aug 2, 2017 at 9:13 AM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    I'd do uniball if you like to go off-roading. If your aim is more mall crawler then I'd stick to ball joint.
  9. Aug 2, 2017 at 9:29 AM
    Toytec Lifts
    Denver, CO.
    Total Chaos control arms are a "fixed" style control arm that offers a full tubular design with reinforced trussed mounting points, poly bushings, greaseable zerks for those poly bushings, and a 1'' stainless steel uniball, they will offer proper caster specs that are built into the control arm.
    The SPC control arms are a factory style control arm with a factory style ball joint, the ball joint is made to be adjustable to insure the proper alignment the first time without any issues. The ball joint does come with a greaseable zerk that we recommend pumping with grease every oil change.
    If you are going to be doing "harder" style off roading I would recommend going with the Chaos arms to insure proper flow of the suspension, the reason being is if you are going to be cycling the suspension more times than not you will have a higher chance of separating the ball joint on the UCA.
    -David
  10. Aug 2, 2017 at 9:40 AM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    ^ that
    Toytec Lifts likes this.
  11. Aug 2, 2017 at 10:45 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    I ordered the uniball. I'm at the dunes every weekend and sometimes the front wheels come off the ground. Figured that extra travel would help. Thanks everybody for the help
  12. Aug 2, 2017 at 11:56 AM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    Next step is long travel :anonymous:
  13. Mar 9, 2018 at 9:44 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    is the joint on these (SPC) easily replaceable if it wears out ?
  14. Mar 9, 2018 at 9:45 AM
    Toytec Lifts
    Denver, CO.
    Yes they are!
    Les7311 likes this.
  15. Feb 3, 2021 at 12:38 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 limited hybrid offroad
    what is the likelihood that an SPC ball joint will ever wear out? For 99% of us who do street, or light trailriding to a mtb spot and/or fire roads, are the SPC as good as it gets from a reliability and noise standpoint? Didn't they just update their balljoint following this post too?
