Cabin noise - windshield
Discussion in '3rd Gen Tundras (2022+)' started by Woodman427, Feb 27, 2022.
  1. Feb 27, 2022 at 2:08 PM
    Woodman427
    Woodman427 [OP] New Member
    Post-22 owner. Back to reliable Tacoma
    One of the issues I have with this new Tundra is down cabin noise. Drivers upper door needs adjusting and that will fix one but the other is evading me. Hoping someone may have experienced this that can offer up some suggestions.
    I have some noise coming from drivers front lower windshield area that is starting to drive me bonkers. Smooth roads ok but any potholes and there is this slight snapping noise. It almost seems like it is coming from the plastic shield under the wipers but hard to tell ad the sound is travelling through the glass. Hoping a quick fix to avoid yet another trip to the dealer for a month old truck.
    Anyone who is thinking about a new tundra, wait a year. Never will I get a new model after a redesign. Ever. QC on this new truck is sub par.
  2. Feb 27, 2022 at 2:32 PM
    Breathing Borla
    I have read some peoples windshield install was a little off at the base and thus having noise etc there. May want to look at the areas where it’s sealed and mounted if you. I’m not sure how that area looks as I haven’t seen one in person yet
  3. Feb 27, 2022 at 3:59 PM
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    Check the A Pillar inner plastic trim piece(under the Oh shit handle)... Mine was making a noise like you are describing. I took it up and reinstalled so it wasn't snug up against the windshield and is now silent.
  4. Mar 1, 2022 at 7:39 PM
    Woodman427
    It is the windshield. It has to come out and then reinstalled with a new seal. While driving if pushing out on windshield the noise goes away.
  5. Jan 13, 2023 at 2:13 PM
    Lou1947
    Lou1947 New Member
    Tundra 1794
    I have taken my A pillar drivers side panel and the clicking noise is still there. Definitely worse with the cold temperatures. I tend to agree that the windshield is the culprit. I took my Tundra to a facility that replaces windshields but they mentioned that if I have them remove the windshield and it breaks it’s on me. They wouldn’t touch it unless they got the Ok from Toyota. With windshields on short supply I could be without a truck for sometime. My 1794 has HUD display and that would also require calibration after the windshield is reinstalled. Is the calibration done by the dealer or by the windshield installer?
  6. Jan 13, 2023 at 2:17 PM
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    Why not start with your service center? It’s under warranty
  7. Jan 13, 2023 at 5:30 PM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    I'd take it back to Toyota have them completely disassemble it and put it back together sober this time
    gj953, Henry1jg, Buildn and 3 others like this.
  8. Jan 13, 2023 at 5:34 PM
    Breathing Borla
    lol, that was pretty good.
    Henry1jg likes this.
  9. Jan 17, 2023 at 2:25 PM
    Lou1947
    Lou1947 New Member
    Tundra 1794
    Took my Tundra to the dealer to have some TSB done to fix the sluggish starts when cold from first to second gear and for the clunk when cold start ups. They couldn’t find the culprit for the clicking noise coming from the windshield area, but as per Toyota they wanted to remove the headliner and that was going to take 2.5 hours. I didn’t want the to do that since I can tell that the sound is coming from the lower part of the windshield. My headliner does not sag and I am afraid that could become a problem once it’s removed.The noise is definitely related to the cold temperatures and it’s far worse when the the is in the thirties. I am heading for sunny Florida next week and most likely the clicking noise will disappear with warmer weather. I have looked under the hood and have sprayed silicone lubricant all around the lower rubber seal that butts up to the windshield but it hasn’t helped. I have read in this forum as well as in the Facebook forum and the clicking noise is well documented by other owners. My guess is that Toyota will eventually have a TSB with a fix.
  10. Jan 17, 2023 at 7:22 PM
    AWDDude
    AWDDude New Member
    2023 Tundra Limited - Crew Max TRD Off Road 4x4
    I took mine in for what I thought was whistling from the mirror. They said it was actually coming from the door seal. They ordered a new door seal which should arrive in a few days, but then we’ll see.
    RaleighGuy and Kap1 like this.
  11. Jan 17, 2023 at 7:58 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Please keep us posted! Same issue here
  12. Jan 17, 2023 at 9:54 PM
    dowdydl
    dowdydl New Member
    I have a nagging noise that comes from my AC. It doesn't happen all the time, but when it does, it is very annoying. I was able to stop the noise by turning the AC off, but it would come back when I turn it back on. Again, it doesn't happen every time. I have a 2023 Platinum Hybrid.
  13. Jan 30, 2023 at 7:03 AM
    Markysharky
    Markysharky New Member
    My 2023 SR has bad wind noise about 50-60mph near the driver mirror area. I’ve tried adding weather stripping to the window. And adjusting the mirror. The noise isn’t related the the driver mirror or the driver window seal itself. Starting the think the corner of the front windshield isn’t fully sealed.
  14. Jan 30, 2023 at 7:16 AM
    Rick1984
    Rick1984 New Member
    Rick
    2023 TRD Off Road
    I had a noise that was fixed by the dealer. Similar ticking noise that was coming from under the headliner that did get worse in the cold. They had to drop the headliner and said it was something from manufacturing tapping the glass. It had to go in twice but they did fix it. I had a small camera up there from the pillar and the glasses holder and could not see anything.
  15. Jan 30, 2023 at 1:15 PM
    Lou1947
    Lou1947 New Member
    Tundra 1794
    Drove from Illinois down to Miami and the clicking noise is totally gone . It quit ticking as soon as the outside temp got to 70. Let’s see what happens when I get back to the cold.
  16. Jan 30, 2023 at 1:26 PM
    nodak67
    nodak67 New Member
    JR
  17. Jan 30, 2023 at 2:31 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 limited hybrid offroad
    Toyota build quality!
  18. Feb 1, 2023 at 12:13 AM
    AWDDude
    AWDDude New Member
    my Tacoma did this, it was soooo annoying and loud. I put some felt in there which helped.
  19. Feb 1, 2023 at 12:14 AM
    AWDDude
    AWDDude New Member
    BTW, the door seal is on back order. Supposed to show up in late February. I’ll post again when it’s installed.
  20. Feb 4, 2023 at 12:07 AM
    AWDDude
    AWDDude New Member
    FYI for all interested, they finally received the replacement drivers side door seals yesterday, and installed them today. The noise is completely gone.
  21. Jan 10, 2024 at 5:51 PM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    you ever get to the bottom of it? My new tundra is making a clicking sound like you mention since it’s gotten cold.
    https://youtube.com/shorts/owwgKcaa13k?si=1IOCsQU9MixbZFp4
  22. Jan 11, 2024 at 7:21 AM
    graf_von_tundra
    graf_von_tundra Not so new
    Central Texas
    2023 Tundra 1794 4x4 Black
  23. Jan 11, 2024 at 11:18 AM
    Northern Toyota
    Tires and bilstein
  24. Jan 11, 2024 at 5:55 PM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    I have the same “clicking” noise. It just real cold here, and tons of snow so,when I hit some bumpy/rough snow pack the click is there. Smooth roads, and it’s gone.
    can’t seem to figure it out
  25. Jan 11, 2024 at 6:18 PM
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    I have a buzzing noise LOL, typically over 70MPH or lower depending on wind, just start a few months ago. I think it is the metal trim outside running top to bottom of the window. It’s awesome ;), guessing none has had this one LOL
    https://youtu.be/Tg1TfAVrPCs?si=GbcxDBGhTNaLspqN
  26. Jan 11, 2024 at 7:09 PM
    Northern Toyota
    Tires and bilstein
    if I didn’t drive on back roads for work it would almost be tolerable. It’s a struggle to narrow down where it’s coming from and I’m dreading taking it to my dealer as I’ll likely end up more irritated after they try and “help” me.
    graf_von_tundra likes this.
  27. Jan 11, 2024 at 7:10 PM
    Northern Toyota
    Tires and bilstein
    That sounds very annoying, sounds like a high frequency vibration of something.
  28. Jan 11, 2024 at 9:57 PM
    graf_von_tundra
    Central Texas
    Take a look at the door seal between front fender and door. It’s supposed to seal the gap between the two. Mine is loose and flaps in the wind with a similar noise. Dealership is looking at it tomorrow.
