Payload Stickers?
Discussion in '3rd Gen Tundras (2022+)' started by AnalysisParalysis, Dec 10, 2021.
  1. Nov 25, 2022 at 11:03 AM
    #541
    JDSTOY
    JDSTOY New Member
    2024 GMC 2500HD, 2022 Limited 6.5, 2000 Limited
    Looking through this thread got me curious. My door label is listed at 7165 lbs gvwr. 22 crewmax limited 2WD, weighed with a full tank, black armor bedmat and bakflip mx4, drawbar, and miscellaneous gear under the rear seat and in the console. My door sticker says max payload is 1445. Based off the name plate and my weight today, I have a calculated payload capacity of 1365 lbs. If, however, I use the individual axle ratings at 100% of their rating, my available payload goes up to 2140 lbs. By the time I load up the travel trailer(750lbs tongue weight), The wife, kids and dog(650lbs), and all the crap that rides in the bed of the truck, I will be 150-250 lbs over the 1365 number easy. My 2000 tundra had payload of around 1900 lbs back then and I know it could handle much more than that. Surely theses newer, bigger trucks can handle a couple hundred over what the door label states.
  2. Nov 25, 2022 at 4:34 PM
    #542
    Insulator
    Insulator New Member
    2023 CMLB Lim TRD / 03 Tundra Lim AC
    Dual Battery
    For the limited, per Canadian Owner's manual, removing Pano and JBL should not effect GVWR. But deleting those wasn't really something I wanted to wait for. Besides, do you think GVWR is actually based on a different frame, brakes, drivetrain?
    You do! ;) Despite my truck saying 7365, I may just treat it as the 7780 which is max for the hybrid of the same size.
    You have to take the least capability as they are all MAX ratings - you can't add axle capability to develop a new max rating. If you look above, I think GVWR is scaled by truck model, which means they really care how and where you put in the weight - if you put olympic plates over each axle, you could handle way over GVWR, but if you put in a giant slide-in camper, you're going to throw off vehicle dynamics.
    :benchpress:
  3. Nov 26, 2022 at 11:10 AM
    #543
    LimitedLuck
    LimitedLuck New Member
    Rich
    2023 Limited
    2023 Tundra Limited Crew Max 4x4, (NOT hybrid). Yellow payload reduction sticker 19 lbs (includes ball hitch mount, first aid kit, all weather floor mats.)
    GVWR 7230 lbs / Payload 1400 lbs
  4. Nov 26, 2022 at 11:56 AM
    #544
    Terndrerrr
    Terndrerrr guzzling dealer repellent
    Music City
    Dual 5.7s
    TRD Fox, RAS, 285/75 DTs, dual battery, SS3 Pro
    I’m over by a few hundred pounds on a somewhat regular basis. Did Imogene Pass like that. Truck does not care at all. OEM leafs and RAS. No accelerated wear on brakes, either.
  5. Nov 27, 2022 at 8:03 AM
    #545
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    My tank was full, truck weighed 5560, gvwr 7210, payload came in at 1650. I have a sr5 cm 4wd, no
  6. Jan 25, 2023 at 9:34 PM
    #546
    HighroadTRD
    HighroadTRD New Member
    Bay Area
    23 Tundra Pro Magnetic Grey
    Retrax Bed Cover, RCI SKIDS, RCI Sliders
    The pro model has no options to change the payload, so how does toyota get away with stating 1600lbs???? My payload sticker says 1355. There are no other configurations on the pro.
  7. Jan 25, 2023 at 9:40 PM
    #547
    mass-hole
    mass-hole New Member
    Because the stickers are BS. Go weigh the truck at a cat scale empty with a full tank of fuel and you’ll probably find the payload sticker is low.
    Toyota is only putting one of around 15 possible payloads on any given truck. The 15 are in the owners manual. Your sticker will match one of them because they are nit accounting for specific options
    LimitedLuck likes this.
  8. Feb 4, 2023 at 1:18 PM
    #548
    Pttundra23
    Pttundra23 New Member
    Paul
    Base tundraSR
    I had lots of questions about tundra payload which all have been answered reading through this thread. My only question is, has anyone taken a base SR or SR5 model to the scale? And what was the actual curb weight of? Thanks.
  9. Feb 4, 2023 at 5:01 PM
    #549
    Archive
    Archive New Member Vendor
    Eric
    '22 Tundra CM 6.5' TRDOR
    Archive Garage Suspension
    in_the_mud likes this.
  10. Feb 5, 2023 at 10:44 AM
    #550
    Pttundra23
    Paul
    Base tundraSR
    Got it. Thank you. It would be great if someone, more tech savvy than I, would put together a list of all available trims weighed at the catscales, (empty with topped off fluids) and their respective GVWR’s. Then we can all have all the trims actual payload.
    I’m thinking I will probably go with an SR5 DC, 6.5 foot bed with minimum bells so I can get the maximum payload. I’m even thinking the smaller of the 2 gas tanks. I’ll just carry a 5 gallon security gas can in the camper’s cargo carrier. I really would love 1800 lbs for how I want to load that donkey for my camping needs.
    I wonder if the base SR weighs less. My camper’s GVWR is only 5400lbs, which be close to that when I’m done. So the SR should pull it fine. Any thoughts on that?
  11. Feb 5, 2023 at 12:22 PM
    #551
    TRD-JP
    TRD-JP New Member
    Winnipeg, Canada
    2023 Tundra CM Limited TRD OR Midnight Black
    My 2 cents:
    1. Don't get the smaller gas tank if you have the option for the big one. Lots of people on here swear by the larger tank, especially if you are towing.
    2. Stick with the SR5 or higher - doesn't the base SR only have the 348hp engine? You don't want that... Get the better engine - you are towing!
    3. 5400 GVWR camping is about a hitch weight of say 800 lbs at very most (15% of GVWR), probably closer to 700lbs on most days. I wouldn't worry about the payload game too much because that's a pretty low hitch weight. Get a truck you want with the features you want. 5400 GVWR is a very modest size trailer for the 3rd Gen Tundra.
    Archive and OnThaLake like this.
  12. Feb 5, 2023 at 12:50 PM
    #552
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    I agree with what TRD-JP said. I think the dry weight of my trailer is about 5400 lbs and my second gen does fine with it in the Rockies.
    Terndrerrr likes this.
  13. Feb 5, 2023 at 11:08 PM
    #553
    mass-hole
    Get the bigger tank, just dont fill it all the way if you’re worried about payload
    Archive likes this.
  14. Feb 6, 2023 at 7:10 AM
    #554
    Archive
    Eric
    No, the base SR really doesn't weigh any less, so forget that, the base SR5 I weighed in post #409 is virtually what a 4x4 SR weighs.
    SR also has drawbacks like reduced engine power, reduced towing (only ~8,300lbs), only comes with the tiny 22gal fuel tank.
    I'd recommend you look at an SR5 DC 6.5', a 4x4 model should have ~1,700lbs actual payload before adding accessories, without a spray in liner
    -SR detuned Twin-Turbo V6 per build detail sheet: 358 hp @ 5200 rpm, 406 lb.-ft. @ 2000 rpm
    Cpl_Punishment likes this.
  15. Feb 7, 2023 at 4:35 PM
    #555
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    I have a SR5, 4x4, CM. No TRD, or other options. It’s a great truck. My test drive was to the scale. It weighs 5560 with full tank. GVWR = 7210. Payload = 1650. My Coleman TT has a GVWR of 7600 lbs. Truck tow’s like a dream! I wouldn’t go any larger, and I’m careful with how I load it, but the results have been really impressive!
    TRD-JP, Archive and Leo's first like this.
  16. Feb 8, 2023 at 6:47 AM
    #556
    Pttundra23
    Paul
    Base tundraSR
    Appreciate the help gents. Ok SR is out. I will definitely go SR5 with a bigger tank, low on the options so it stays a light as possible. I saw a DC in person in Lowe’s a couple days ago. Yeah the back seats are tight but it’s only 2 of us and we basically use the back for storage. I have a tongue weight scale, my tongue weight is only 600 lbs when the trailer is loaded. When I get the truck I will take it to the scales and post results.
  17. Feb 8, 2023 at 12:06 PM
    #557
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Good choice on the larger tank. Probably my biggest complaint of this truck (which overall is my favorite truck I've ever owned) is that the stated tank size is 32 gallons. That got me stoked for towing, until I realized it shows empty at 26 gallons. I've read that's due to cooling the pump, not really sure. I just fill up before I get to E. If you do the same you will essentially be using a tow vehicle with a 26 gallon tank. Not nearly as impressive for towing distance. Overall I still love this truck!
    Archive likes this.
  18. Feb 8, 2023 at 7:42 PM
    #558
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    I'll say the same thing I've said on every page of the 38 gallon thread: if you want to put more fuel in the tank when you fill up, drive farther between fill ups.
    OnThaLake likes this.
  19. Feb 9, 2023 at 8:05 AM
    #559
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    It won't hurt anything? That's an honest question. I can't figure out why Toyota would show the truck being completely empty when it still has 6 gallons. I would be happy to run another 50-60 miles per tank when towing.
  20. Feb 9, 2023 at 8:18 AM
    #560
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    Because their computer is very conservative.
    Dfrink[QUOTED] likes this.
  21. Feb 9, 2023 at 8:34 AM
    #561
    Markysharky
    Markysharky New Member
    I have a 2023 sr 2wd small cab. Payload sticker is still lower than the 1940 lbs the manual says it should be. I think they put the low number on every truck. Cause in theory a 2wd non crew cab SR model should be the highest.
    Archive and Dfrink like this.
  22. Feb 13, 2023 at 6:23 AM
    #562
    Pttundra23
    Paul
    Base tundraSR
    That would be a great truck to take to the scales. Post numbers when you do please.
    Archive and Terndrerrr like this.
  23. Mar 14, 2023 at 4:39 AM
    #563
    SR4x4DC
    SR4x4DC New Member
    I have the SR double cab and my payload is only 1500 according to the sticker. Not sure why when it should be closer to the 1940 payload
  24. Mar 14, 2023 at 4:56 AM
    #564
    Markysharky
    My sticker says the same 1500lbs, the brochure says it is the 1940lbs. Mine had no options and is two wheel drive so it should be the max amount. My guess Toyota just slaps the same door sticker on most of them.
    LimitedLuck and SR4x4DC like this.
  25. Mar 14, 2023 at 4:57 AM
    #565
    Terndrerrr
    Music City
    Dual 5.7s
    @Markysharky @SR4x4DC if you take your bone stock truck to the CAT scale with a full tank of fuel (edit: with you out!) and subtract your scale ticket axle weights from the GVWR printed on your door jamb, that will give you your true payload rating. Lots of ‘22 and ‘23 owners are finding out that they have more payload than what is written on the door jamb.
    We’re all very curious since you have the trucks that should have the highest payload (especially the 2wd). Let us know if you go conduct this experiment for your Tundras.com brethren.
  26. Mar 14, 2023 at 5:07 AM
    #566
    Mattedfred
    Mattedfred Toyota Fan Boy Since ‘04
    Ted
    Cambridge, Ontario Canada
    2023 SR5 TRD Sport DC 4X4 in MGM
    TRD Skid Plate/Running Boards, Bison Soft Rollup Tonneau, Thule Canoe Rack, Bedmat, Tailgate Black Insert Badge, Northwest Seat Covers Neoprene Custom Fit Front Row Seat Covers. Tailgate Mat
    @Markysharky & @SR4x4DC I feel your pain. Toyota may advertise 1940 as the max payload but neither lists such a model in their owners manual or permits the buyer to order one with such a payload.
    The max is 1580 and that’s for a 2WD DC 8’ bed.
    I can only assume that they are legally permitted to advertise a maximum payload that not a single buyer is able to achieve.
    That said, I second @Terndrerrr advice. If GVWR, axle and tire ratings are your concern then you will be able to get yourself up to a few 100 lbs extra.
  27. Mar 14, 2023 at 5:08 AM
    #567
    Archive
    Eric
    @Markysharky @SR4x4DC Yes please scale your truck, full tank, minus your body weight or step out of truck.
    Easy 1st step is posting a pic of the door jam sticker with your GVWR on it.
    I weighed 2 Tundras in post #409 and 449
    Toyota plays games with the GVWR, moving it up and down so the payload allowable per GVWR sticker hangs around 1600lbs actual
  28. Mar 14, 2023 at 10:17 AM
    #568
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    My sticker says 1350 but I weighed the truck and it was 5800 (SR5, 4x4, crew max, 6.5 ft bed) with me in it so I have about 1500 lbs of cargo weight to play with before I hit the GVWR. This is with 1400 lbs of wood pellets in the back and I'm obviously not in the truck which you can subtract 200 lbs for that. So it's 300 lbs below the GVWR and it's sitting pretty darn low in the rear end. They are definitely soft in the rear end even without going over GVWR.
    Archive likes this.
  29. Mar 14, 2023 at 10:48 AM
    #569
    Archive
    Eric
    Every single Toyota truck is soft in the rear, that is their design methodology.
  30. Mar 14, 2023 at 10:49 AM
    #570
    Coasty
    Coasty New Member
    Pat
    Oregon
    I believe that and as long as a person has realistic expectations of their truck's capacity they'll be good. It's folks who in reality should have a 3/4 ton that expects any 1/2 ton to do what they need it to do that have issues.
    GODZILLA, Cpl_Punishment and Archive like this.
