2018 Cold Start Problems
Discussion in '2.5 Gen Tundras (2014-2021)' started by MatD13, Jan 24, 2023.
  1. Jan 24, 2023 at 2:50 PM
    MatD13
    MatD13 [OP] New Member
    2018 Limited Cement Crewmax 4x4
    Looking for suggestions...
    This morning in NW Florida it was a grueling 42° F; the truck took 4 times to start.
    This happened about this time last year, searched the forum and found the TSB-0166-19, Extended crank... Took it to the stealership, showed them the TSB, and they dropped the tank, replaced the fuel pump, reflashed ECU, etc... Started fine for a bit.
    A few months back, it started showing the same symptoms as last winter but it would always start. Earlier this month, with about the same temperature, the truck took four times to start. Brought it to the dealership, and they were unable to find anything wrong after it sat for several days there. They said it might be a leaking fuel injector but were unsure and also reflashed the ECU. This past month, the truck hasn't displayed any codes or had anything stored in the ECU like last year.
    My battery was replaced last March and still checks good through Advance Auto's tester. The truck starts fine when the engine is warm.
    Has anybody experienced something similar and been able to pinpoint what could be causing my truck not to start?
    Truck has 86,XXX miles on it.
    https://youtube.com/shorts/ntZ7xsgeUJA?feature=share
  2. Jan 24, 2023 at 2:53 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Sounds like a fuel pump problem.
    mountainpete and Rocko9999 like this.
  3. Feb 28, 2023 at 1:33 PM
    WDE21
    WDE21 New Member
    2018 White Tundra XP
    MatD13, I’m having the same issue very intermittently. Were you able to find a fix that has worked for you? I’d like to not have to replace a fuel pump and everything only to find out that’s not the problem since I do all the work myself.
  4. Feb 28, 2023 at 2:13 PM
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    Is your truck a flex fuel?
    MatD13[OP] likes this.
  5. Mar 2, 2023 at 7:16 PM
    BOBFROMKTOWN
    BOBFROMKTOWN New Member
    Bob
    2018 SR5
    Undercover tonneau, Luverne grille guard
    My 2018 had the hard start problem at about 50,000 miles. Happened after some brutally cold weather. It was the fuel pump. And my truck wasn't part of the recall.
  6. Mar 4, 2023 at 5:12 PM
    MatD13
    Negative. There's another thread floating around with some people having the same issue. Frustrating and still happening.
  7. Mar 4, 2023 at 5:14 PM
    MatD13
    My truck wasn't part of the recall either, but after I showed the dealership the TSB I initially stated in my first post, they dropped the tank and replaced the pump
    Terndrerrr likes this.
  8. Mar 5, 2023 at 10:43 AM
    WDE21
    WDE21 New Member
    My truck is a flex fuel yes. Does that bring up any ideas? I normally just use 87 unleaded in it. Nothing crazy.
  9. Mar 5, 2023 at 4:23 PM
    MatD13
    Mines flex too. Wonder if non ethanol has would make a difference
  10. Mar 8, 2023 at 9:39 AM
    ZPMAN
    Minnesota
  11. Mar 8, 2023 at 3:06 PM
    Ebrperk
    Ebrperk New Member
    2016 SR5 4wd Crewmax
    Factory LED headlights with ihacker harness, Bilstein 6112,s at 2" lift and 5100 in back, SABM, rear diff breather mod, Firestone Destinations AT2, metal oil filter mod, fumoto oil drain, stock skidplate mod to access oil filter
    I wonder if, when they replaced the fuel pump, they checked how tight the connections were. If the connections weren't tight it would cause the same symptoms as a bad fuel pump. Eric O on South Main Auto ran into this on a tundra.
    https://youtu.be/miNUy43Qy48
  12. Mar 11, 2023 at 6:26 PM
    daylorb
    daylorb New Member
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    Same issue here in Austin when it is below 40....
  13. Mar 13, 2023 at 10:43 AM
    MatD13
    Found the issue, at least with my truck. I put non ethanol gas in last week and it’s been firing up great ever since
  14. Mar 14, 2023 at 5:28 AM
    Ebrperk
    Ebrperk New Member
    NICE!! Hopefully that has solved the problem
  15. Mar 24, 2023 at 6:59 AM
    Sdaukes
    Sdaukes New Member
    2018 Toyota Tundra SR
    So my 2018 seems to have had started having similar issue this week. Takes 2-3 start cycles after sitting overnight or long periods of time to get started. Just over 30 degrees this morning outside.
    Is there a TSB for the fuel pump on my truck? Is there a free place to look TSBs or would I have to pay a subscription on a site to get that access?
  16. Nov 12, 2023 at 11:59 PM
    Big Swede
    Big Swede New Member
  17. Nov 13, 2023 at 12:02 AM
    Big Swede
    Same issue here in upper Michigan. Started last January cold at hell 0 degrees. Fuel pump was on back order 3 months at the time. By time it came in it warmed up and issue was resolved. Now it’s cold again and it’s back. Just had new fuel pump installed and still the same. Was slightly better for few days. Only on cold starts does this happen. The stealership said it was the fuel pump the first time. They claimed it was like sipping gas thinking it was e-85 whatever that means vs pumping it. So it’s a smart fuel pump or a special needs fuel pump. Idk but still dealing with it. Need to fix
  18. Dec 6, 2023 at 12:43 PM
    Chris720
    Chris720 New Member
    Been having the same problem for awhile. I just got back from the dealer for the same issue. I knew they wouldn’t be able to duplicate it so every time my truck did this(2018 SR5) I took a video with my phone.
    When explaining the problem to the service manager of course they had no idea what I was talking about and basically told me if there’s no code there’s nothing they can do.
    Knowing that would be their answer I pulled out the TSB that I printed and brought with me and emailed her all the videos of my truck taking three attempts to start.
    They called me an hour later and told me they’re ordering all the parts that the TSB lists and will change at no cost to me. Also they will flash the ECU.
    I was actually shocked especially since my truck has 71k miles on it.
    This is the service bulletin
    https://static.nhtsa.gov/odi/tsbs/2019/MC-10170730-9999.pdf
  19. Dec 6, 2023 at 2:24 PM
    reneaux
    reneaux New Member
    2017 SR5 CM 4x4
    If you are having issues with the dealer - get a cheap OBD reader, mine is bluetooth. Download Torque or similar app then check the Fuel Alcohol %. Mine was up near 80% when my truck started having a rough start. I downloaded techstream (ih8mud write up I followed) and then did a Fuel Alcohol Relearn. Fixed the issue so far, alcohol % is still at 0. I'd at least start there to rule out the alcohol issue. Truck also started getting better MPG and had more pep.
  20. Feb 12, 2024 at 1:46 PM
    Tachdave
    Tachdave New Member
    South Cay
    2018 Toyota Tundra Platnium
    Leveled
    I’m in Aiken,SC. I’m dealing with the same issue. Replaced the fuel pump in 2023 under warranty. Now I’m dealing with infrequent Cold crank starts on my 2018 Tundra. Dealer was able to replicate the issue. They are going to reset the ECM. Sounds like this is a temporary fix. Has anyone found a permanent fix?
  21. Feb 13, 2024 at 7:34 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    E85 burns different so if computer thinks you have e85 but you really have normal gas, the mix is wrong in cylinders and you end up basically flooding it. You may smell strong gas smell after cranking due to this.
    If you have an obd2 device like Scangage, you can read % alcohol and long term fuel trims to confirm if ethanol reading it out of whack.
    https://www.tundras.com/threads/info-for-flex-fuel-hard-start-alcohol-density-issues-owners.100347/
    https://www.tundras.com/threads/res...ge-level-with-bidirectional-scan-tool.123799/
    https://www.tundras.com/threads/will-bd-tuner-fix-the-dreaded-5-7-ffv-ethanol-gas-issue.84154/
  22. Feb 20, 2024 at 3:56 PM
    ToyotainAiken
    ToyotainAiken New Member
    Amy
    2018 Toyota Tundra SRS 4 X 4
    My 2018 Toyota Tundra SRS with 40,000 miles is having the very same issue that all in this forum have described. A cold start issue when temps drop at or below 40 degrees. My brother had a tester and it revealed that the 87 octane I was running contained 67% Ethanol and I thought I had filled my tank with bad gas so I ran the tank to half and added dry gas and Non Ethanol gas and the problem seemed resolved for a short while but it seems the problem has resurfaced. My truck is currently at the Toyota Dealership being looked at. From my understanding there’s a class action lawsuit on the fuel pump but the dealer is trying to tell me that my fuel pump is not included. Sounds like I’ll need a new fuel pump from what all of you are also experiencing.
