LaFawnda - 2015 TRD CM
Discussion in '2.5 Gen Builds (2014-2021)' started by IndyTundra, Jul 1, 2015.
  1. Jul 1, 2015 at 9:12 AM
    IndyTundra
    IndyTundra [OP] Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    Current set up:
    Interior:
    TRD Pro shifter
    Driver side grab handle
    Husky Weatherbeater mats
    Salex console organizer w/holster mod
    OneTigris molle seat back panel
    Exterior:
    Linex'd hood bulge
    Havoc Offroad HS2 steps
    Rhino liner
    Access Laredo roll-up tonneau
    Tundra tailgate insert
    debaged
    20% tint front windows
    6 3/4" stubby antenna
    Lighting:
    Baja Designs Squadron Sport (Amber combo lenses)
    Baja Designs fog light kit
    KC Hilights 30" light bar (behind grill)
    JDM reverse LEDs
    Suspension/Brakes/Exhaust:
    Toytec/Radflo 2.5 Coilovers set at 2"
    JBA UCAs
    Wheeler's Superbumps
    Bilstein 5100 rear shocks
    MBRP 3" dumped after axle w/MBRP resonator (to kill drone)
    Wheels/Tires:
    Mickey Thompson Deegan 38 Pro2 18x9 +18
    Nitto Ridge Grappler 285/70-18
    Misc:
    Relentless CMC
    RCI front skid (steel)
    Rear Diff breather mod
    Elevated Suspension tow hook brackets
    SDHQ ABS guards
    Coming soon:
    Elevated Suspension bumper spacers
    R1 Concepts Slotted rotors and pads
    2018 pictures: Nfab rsp bumper, Linex grill, baja designs and kc lights, Mickey Thompson Deegan 38 Pro2, 33 BFG KO2s, Toytec/Radflo COs, JBA UCAs.
    2017 pictures: Nfab rsp bumper, Linex grill, baja designs and kc lights, Mickey Thompson Deegan 38 Pro2, 33 BFG KO2s.
    2016 picture: Nfab rsp bumper, baja designs and kc lights, bora wheel spacers, trd wheel caps, 33 BFG KO2s.
    Here it is the day I brought it home
    blue16, zcarpenter92 and Black Wolf like this.
  2. Jul 1, 2015 at 9:15 AM
    15max
    15max New Member
    Cole
    15 SR5 TSS 4x
    3/1 lift level, 35" Toyo Trail Grapplers
    Looks great! Here is 3/1 lift with 35's on stock TSS wheels.
  3. Jul 1, 2015 at 12:25 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    3/1 with 35s is my preference
    15max likes this.
  4. Jul 1, 2015 at 2:16 PM
  5. Jul 6, 2015 at 8:52 AM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Got the TRD exhaust, bed liner sprayed in, and I added the Tundra inserts to the tailgate this weekend.
    Exhaust is much louder but not annoying. Quite at idle but it gets decently loud at 2000+ rpm. No drone on the highway.
    Spray in Rhino liner
    Tundra Tailgate inserts. Adds a decent amount of color to the tailgate.
    Black Wolf and Relentless like this.
  6. Jul 6, 2015 at 8:53 AM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Very nice! What lift did you use?
  7. Jul 6, 2015 at 10:05 AM
    15max
    15max New Member
    Cole
    15 SR5 TSS 4x
    Honestly couldn't tell you. I just went to my local truck shop, purchased it and had it installed there. Its just blocks with longer shackles in the rear and a strut spacer in the front.
  8. Jul 10, 2015 at 7:52 PM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Toytec leveling kit ordered yesterday. Should be here early next week. Will make an appointment for install when it arrives.
    T-Rex266 likes this.
  9. Jul 11, 2015 at 1:49 PM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Front windows tinted at 15% to match the back. Got a strip across the windshield to match but not sure if I like it or not. I'm sort of tall and the transition is almost in my line of sight. I'll wait to see if the lift changes it up any at all before I do anything to it.
    Black Wolf likes this.
  10. Jul 29, 2015 at 10:44 AM
    tacouser
    tacouser New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    Does anyone know what head light lamp/bulb size is used in a 2015 SR5. Im not home to check for myself. Thanks
  11. Jul 29, 2015 at 2:14 PM
    here is think link.
  12. Jul 29, 2015 at 3:23 PM
    Flobrandx
    Flobrandx New Member
    Brandon
    2015 TRD PRO
    Working on them now...
    Build is looking good. What wheel and tire combo you going with?
  13. Jul 29, 2015 at 4:20 PM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Thanks. Not sure yet. I might use the stock wheels but I really like the Method NVs. Tires will probably be either Goodyear Duratrac or BFG KO2 in 275/70-18.
  14. Jul 29, 2015 at 6:03 PM
    Flobrandx
    Brandon
    2015 TRD PRO
    Great choice! I have the NV's on order myself and waiting for their arrival.
  15. Aug 2, 2015 at 10:03 AM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Installed my TRD Pro grill and dipped my hood bulge. I think I will dip the outside of the grill and probably the bumper ends as well. Also got my Toytec level kit on. Need to decide on tires but those will be a while.
  16. Aug 2, 2015 at 1:05 PM
    Flobrandx
    Brandon
    2015 TRD PRO
    that will look good to complete the look with the outside grille and bumper ends done
  17. Aug 2, 2015 at 2:29 PM
    Aurora CO
    Looking even better!
  18. Aug 6, 2016 at 9:42 AM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Been a while since I've updated the truck. Added the nfab bumper with baja designs squadron r lights controlled by the fog switch. The KC lightbar is on a stand alone switch on the lower left of the dash. Tons of light with the wide cornering squadrons and spot/flood bar. The BORA spacers pushed the wheels out just enough to look good. Debating on switching from thd TRD Pro exhaust to an after axle dumped MagnaFlow set up.
    Can't forget the tundras.com sticker!
    zcarpenter92 likes this.
  19. Aug 6, 2016 at 10:26 AM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Lookin good man! Can't go wrong with either KO2s or Duratracs imo.
  20. Aug 6, 2016 at 11:06 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    I too think she looks great. But looks like you went back to the stock grill ... I'd pop out the gray insert and put in the pro insert.
    <---Check out my avatar. I think the chrome trim works well with the clear headlamps.
  21. Aug 6, 2016 at 1:11 PM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Yes, the black grill started peeling so I took it off to decide what to do with it. I sort of like the chrome surround with the black bumper so I might switch the centers like you suggested.
    r4z0r51o[QUOTED] likes this.
  22. Dec 18, 2017 at 12:37 PM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Haven't updated this post in a while. New set-up and current pics are in first post. Suspension upgrades will be coming soon. Probably Radflo 2.5 COs with Bilstein 5100s in the rear.
  23. Dec 18, 2017 at 5:24 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Truck is looking sharp
    IndyTundra[OP] likes this.
  24. Dec 18, 2017 at 6:19 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Looking good!
  25. Mar 30, 2018 at 1:59 PM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Front suspension upgrades complete. Toytec/Radflo 2.5 coilovers (set at 2" of lift) and JBA UCAs. The new coilovers ride much better than my old set up of TRD shocks and toytec 2" leveling kit. Hope to get my new rear shocks installed soon. Rain kept me from getting them finished.
    T-Rex266, RustyPNW and zcarpenter92 like this.
  26. Mar 30, 2018 at 2:22 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    She’s lookin good Ronnie!
  27. Mar 30, 2018 at 2:24 PM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Thanks! Slow work in progress.
