Air bags for 22 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by moe.morrison, Jun 1, 2022.
  1. Jan 4, 2023 at 9:01 PM
    #91
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    @porterbc What do you think the tongue weight was and which WDH did you use? I'm hoping to get a travel trailer, maybe 7000 pounds wet and 900-1000 pounds tongue, then adding WDH to level it out. thanks.
  2. Jan 5, 2023 at 11:34 AM
    #92
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    My trailer is listed with a GVWR of 7400lb, I measured my TW with a scale. It's right at 1000lbs. I use an Eze lift WDH. It's nothing fancy, but it works great.
  3. Jan 5, 2023 at 12:09 PM
    #93
    Paul Moll
    Paul
    Idaho
    Interesting @Dfrink. So with a 1000 pound TW on a scale, then adding WDH which transfers about 300 pounds back to the trailer axle(s), you're at about 700 pounds on the Tundra, giving you 600 for passengers and gear, assuming a budget of 1300 like my 1794 4x4 CM.
    I wonder about adding air bags to the rear axle? I understand that does not increase GVWR, certainly not by Toyota standards, but would help reduce load on rear suspension. Notice I didn't say rear axle, just suspension help. It seems that adding air bags is rather cheap and easy, maybe a way to just goose up the trucks ability enough to get more comfortable with hitting the max payload rating.
  4. Jan 5, 2023 at 12:11 PM
    #94
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    WDH has problems in backing up in tight corners. In some mountain camp sites I have to disconnect my WDH to back in to camp sites, without my air bags, the rear of my 2020 tundra will drops 4" in the back. Not fun. My tongue weight a little over 800 lbs.
  5. Jan 5, 2023 at 12:17 PM
    #95
    Paul Moll
    Paul
    Idaho
    Ah, interesting point @Half track. So air bags is a good way to reduce the sag for those occasions one does not have the WDH on. I'm getting more and more sold on air bags even if they don't actually increase GVWR per Toyota.
  6. Jan 5, 2023 at 8:20 PM
    #96
    Kentucky Tundra
    Kentucky Tundra New Member
    2022 Tundra SR5 TRD Offroad 6.5ft Crewmax Super Sonic Red
    I have been following along with this this conversation, lots of great info and I appreciate it. Every solution seems to have a negative caveat. I think everyone can agree that a wdh is going to be required for anything more than say 500 to 600 lb tongue weight. I'm just wondering how a dual rate spring would work for those that are going to lift your truck around 2-3 inches anyway? Is there even dual rate spring out there that would work with our coils? For my truck, even though I don't do a lot of off roading, I do use it around the farm and would like to keep the articulation. Anyone one have any experience with dual rate springs or Timbren SES?
  7. Jan 6, 2023 at 8:23 AM
    #97
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    2022 Limited Crewmax L
    MBM - TRD Offroad
    I have a set of Timbrens on the way. I am looking forward to trying them out.
  8. Jan 6, 2023 at 7:51 PM
    #98
    Kentucky Tundra
    Great, looking forward to hear how you like them.
  9. Jan 7, 2023 at 3:54 AM
    #99
    porterbc
    porterbc New Member
    Brandon
    2022 Tundra Crewmax Limited TRD OFF-ROAD
    Sorry @Paul Moll just seeing this now.. haven’t used a scale to measure tongue weight but verify it is over 700lbs for sure..
    I use the curt 14K WDH it came with sway control but I haven’t used it yet.. might come in handy with a higher sided trailer but not for my dump trailer. I am waiting for a second set of rear springs from @GeneralSpring that will have a 1” lift and 20% payload increase over stock. So I’m going to weight for these before I add air bags.
    Don’t forget air bags do level the truck out but do nothing for transferring weight to your front wheels which is huge problem for handling and braking FYI, bags are not end all be all
  10. Jan 7, 2023 at 3:35 PM
    #100
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    After you get your spring on and get some time on them can you tell us how you like them? Curious if they make the rear and harsh when not towing. I have a 1” spacer in the rear because I lifted my front 2”. Springs May be where I go next spending on how the truck looks next time I tow.
  11. Jan 7, 2023 at 6:47 PM
    #101
    porterbc
    porterbc New Member
    Brandon
    Absolutely.. there is a dedicated post in here to follow up on the reviews of the spring they gave me.. first ones in rear were bit rough
    Dfrink[QUOTED] likes this.
  12. Jan 9, 2023 at 9:24 AM
    #102
    Newtonfb
    Newtonfb New Member
    So I got a TT thats 4600 dry with a WDH. We will never run it filled with fluids as we wont be dry camping much so I suspect it would be 5500 load max when everything is loaded, maybe a 6000 at worse. With the WDH the Tundra was level but I could feel it being a little bouncy, which could mean I just need to tune my WDH a little better. Overall it towed it great. With all that being said, do I need or should I get airbags (Loadlifter 5000) installed? Curious if it will make a difference or if they are just overkill and the WDH is enough?
    TundraLtdCO likes this.
  13. Jan 9, 2023 at 9:50 AM
    #103
    Paul Moll
    Paul
    Idaho
    Pumping up air bags will negate some or all of the WDH transfer of weight back to trailer axles.
    I would plan to use air bags only when WDH bars are removed such as difficult backing or rugged off road. IMHO
  14. Jan 10, 2023 at 6:49 AM
    #104
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    My trailer is listed at a 7400lb GVWR. I don't need bags to tow it. Hope that helps.
  15. Jan 10, 2023 at 7:59 AM
    #105
    Newtonfb
    Newtonfb New Member
    Good to know so it would just be overkill it sounds like
  16. Jan 17, 2023 at 11:11 AM
    #106
    Tiger85
    Tiger85 New Member
    2016 Mag Gray SR5 TRD Off-Road
    Air bags don't effect the wdh. Setup the wdh first then air up the bags but don't raise the truck with the bags.
  17. Jan 17, 2023 at 7:46 PM
    #107
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    I installed my Timbrens today. Super easy. The wheels stayed on but I used my jack just to give a bit more clearance to the bolts.
    I took it for a spin unloaded and the gap was about 1/2” between the SES and the axle. You can feel the little road defects. This is the suspension moving and hitting the SES rubber. I imagine that once I load up the truck, the rubber will start to work and get a bit more pliable. They are 6” long and the space pr gap is supposed to be 1 1/2” to 1/2” unloaded.
    I imagine the this would be like running airbags at maximum pressure with an empty truck!upload_2023-1-17_19-43-15.jpgupload_2023-1-17_19-43-52.jpg
    Kap1 likes this.
  18. Jan 17, 2023 at 8:02 PM
    #108
    Kap1
    Kap1 New Member
    San Francisco, CA
    Let us know how it'll feel when loaded
  19. Jan 21, 2023 at 10:02 AM
    #109
    FrozenTundra2023
    FrozenTundra2023 New Member
    2023 Hybrid Limited TRD
    Rhino Slim 20 running boards Retrax Tonneau
    Did you go with the 6000lb or 7000lb load capacity set?
    Timbren site has Severe rating for 7k.
  20. Jan 21, 2023 at 10:10 AM
    #110
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    Mine are the 6000 lbs SES units? I am thinking that the off road model might have been a better choice for all around improvement while providing some comfort. I haven't tried them under load yet. Too much else going on to hook up the trailer.
  21. Apr 24, 2023 at 1:18 PM
    #111
    Scruffy_Nerf
    Scruffy_Nerf New Member
    2022 Toyota Tundra SR5
    After about 6 months running a slide-in camper with Timbrens, I'm incredibly pleased with them. I have very little sag and very little body roll. The install was super easy and their customer service department has been very quick to answer my questions about the various versions of the SES kits and recommend torque specs when installing. With that said, I do think I would feel differently if I frequently took the camper off the truck. The Timbrens significantly reduce your effective suspension travel and I could imagine the ride getting really harsh off road.
  22. Apr 27, 2023 at 6:30 PM
    #112
    Ketterus
    Ketterus New Member
    I have the Air Lift 5000 Ultimate with compressor. Whe you have an empty truck the bags have only 5psi and you can't tell they are even there. I actually like to run mine with 7-10psi and I feel it smooths out the bumps (my opinion). I can tell you "I Love my Airlift Bags"
    samschwarzlose and Cdunner like this.
  23. May 13, 2023 at 6:33 AM
    #113
    Cdunner
    Cdunner New Member
    2023 White Sequoia SR5 TRD Off-road
    Can a fellow 2022+ stock suspension tundra with the air lift owner help me out. I’m looking for the distance in the picture. I just installed a 2022+ tundra air lift ultimate rear bags on my 2023 sequoia. My eyes says it’s a little cramped here. I’m just checking dimensions to see if I need a rear spacer or not (have a cornfed 1” spacer on hand). FYI for anyone doing this there is some slight mods required via band saw but it did bolt on without too much effort. Thanks in advance!
  24. May 13, 2023 at 7:12 AM
    #114
    pwpblue
    pwpblue No loaner no owner F ford!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
