Squealing sound when turning
Discussion in '2.5 Gen Tundras (2014-2021)' started by WesD., Jul 5, 2021.
  1. Jul 5, 2021 at 11:08 AM
    WesD.
    WesD. [OP] New Member
    Wes
    2016 Toyota Tundra
    I have a 2016 Tundra, with 96k miles on it. Truck is making a squealing noise when going around a curve to the right. No noise while going straight, or on a curve to the left. Makes this sound no matter if I’m on the brakes or not. Any ideas, possibly the U joint, or carrier bearing?
  2. Jul 5, 2021 at 9:08 PM
    AThomas21
    AThomas21 New Member
    Forest Grove, OR
    2015 Toyota Tundra SR5 Crew Max Magnetic Gray
    6” Rough Country Lift 18” Black Rhino Rims 35x12.5 M/T Tires A.R.E Color Matched Canopy Interior LED Canopy Lighting Side Canopy Win-Doors Yakima Rack Custom Dual Exhaust w/ Flowmaster Super 10 Muffler K&N Cold Air Intake NFab Side Step Bars Black Fender Flares Paint Matched Grill Surround / Hood Bulge Blacked Out Badges Window Tint WeatherTech Window Rain Guards Interior AJT Design Blackout Kit
    I am having the exact same issue, I have been chasing it for a couple weeks now.. I have a ‘15 with 85k miles and a 6” lift. Mine is more of a metal squeak, and only turning right, but I have to be in motion. If my truck is sitting, no squeaks when turning wheel back and forth. Mine squeaks when braking too, replaced rotors and pads a few weeks prior to the squeak starting, rechecked all the brake parts too and no fix. So now I am thinking it is bearing, bushing, ball joint related
  3. Jul 6, 2021 at 1:29 AM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Did you check the rotor backing plate to see if it's bent?
    landphil and AZBoatHauler like this.
  4. Jul 6, 2021 at 1:46 AM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    This is my guess as well.
  5. Jul 6, 2021 at 5:26 AM
    WesD.
    Wes
    2016 Toyota Tundra
    I did. Actually even pried them back a little with a screwdriver, just in case. There are no signs of any rubbing anywhere either. Shot the boots, joints, and drive shaft with some penetrating oil just to see if it lessens or eliminates the noise to tell me where the problem area was….no luck.
  6. Jul 6, 2021 at 5:33 AM
    WesD.
    Wes
    2016 Toyota Tundra
    Sounds like exactly what I’ve got going on. Does it whether braking or not. Can start hearing it if I’m going at least 15mph or more going around a curve to the right. Won’t make a squeak slow turning into a driveway. I’m to the point of thinking it’s a wheel bearing, but it just doesn’t act like any of wheel bearing issues I’ve had in the past.
  7. Jul 6, 2021 at 7:06 AM
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Jack it up and try to manually replicate it
    Truckinewbie likes this.
  8. Jul 6, 2021 at 10:14 AM
    WesD.
    Wes
    2016 Toyota Tundra
    We jacked it up but weren’t able to get it up to speed enough to replicate it.
    2mchfun[QUOTED] likes this.
  9. Jul 6, 2021 at 10:23 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Maybe sway bar bushing is shot
  10. Jul 20, 2021 at 1:57 PM
    AThomas21
    Forest Grove, OR
    Have you had any luck figuring out what the issue is / or was? I am moving on to the bearing and buying the pre pressed kit.
  11. Jul 20, 2021 at 3:04 PM
    jimbrophotodotcom
    jimbrophotodotcom New Member
    Hawaii
    2021 Lunar Rock Tundra TRD Pro
    IG: @LunaTheTundra, Coachbuilder kit and 35s soon
    Get a wheel alignment
  12. Jul 21, 2021 at 7:47 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    probably unlikely, but powersteering pumps squeal during turns when they start to fail
  13. Dec 11, 2021 at 10:40 AM
    Broncorm
    Broncorm New Member
    Vermont
    11 Rock Warrior
    Did anyone figure this out? I’ve got the same thing happening. Just need to turn slightly to the right only a high frequency squeal. No consistency sometimes first drive sometimes not, sometime doesn’t start until driving all day. I have only pulled left front wheel that where I thought it was coming from got to get motivated to look more.
  14. Dec 11, 2021 at 10:51 AM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    x2 for checking the power steering. One of these belt/pulley/bearing.
  15. Dec 12, 2021 at 3:10 AM
    Broncorm
    Broncorm New Member
    Vermont
    11 Rock Warrior
    Its only turning right, would think power steering would do it in both directions. It’s going to be Monday project
  16. Dec 12, 2021 at 7:03 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Does it sound like belt squeal?
    Do you have a trd pro skid?
  17. Dec 12, 2021 at 10:30 AM
    Broncorm
    Broncorm New Member
    Vermont
    11 Rock Warrior
    No does not sound like a belt. I’ve only pulled left front rotor. Thought that’s where it was coming from but didn’t see anything. Cleaned it up but no change so inconsistent on when it happens
  18. Dec 12, 2021 at 10:53 AM
    MadMaxCanon
  19. Dec 12, 2021 at 1:18 PM
    Broncorm
    Broncorm New Member
    Vermont
    11 Rock Warrior
    No just the regular sheet metal skid plate
  20. Dec 12, 2021 at 1:29 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    The power steering pump will also squeal if the fluid is low.
    HulkSmurf14 likes this.
  21. Dec 19, 2021 at 3:48 AM
    Broncorm
    Broncorm New Member
    Vermont
    11 Rock Warrior
    Turned out to be right front backing plate being rusty and rubbing on the machined surface of the rotor which explained the high pitch squeal instead on a scraping noise. As expected it was the last rotor I pulled off
    Rocko9999 and Oey12 like this.
  22. Jan 16, 2023 at 4:42 AM
    jham101
    jham101 New Member
    I’m having a similar issue. I’m getting a groaning noise when I turn at low speeds. Also I have noticed a slight squeal from my belt when I start truck. I do have a RCI aftermarket skid plate. Any thoughts on what’s wrong?
  23. Jan 16, 2023 at 6:49 AM
    AZBoatHauler
    So.Arizona
    Get any coolant on your belt? What year is your truck and how many miles?
  24. Jan 16, 2023 at 9:52 AM
    jham101
    jham101 New Member
    I don’t think I have any coolant on the belt. It started about a week ago and have not added coolant. The truck is a 2012 tundra crewmax TRD with about 180k miles
  25. Jan 16, 2023 at 10:00 AM
    AZBoatHauler
    So.Arizona
    Has the belt, tensioner, or idler pulley ever been touched? If so when? Can you hear where it’s squealing?
    The groan sounds like power steering pump - has the oil in that system ever been changed?
  26. Jan 16, 2023 at 2:41 PM
    jham101
    jham101 New Member
    It hasn’t been changed. I just watched a video on changing it and it seems very straight forward. The other components you mentioned have never been touched. I’ll work on swapping fluid today or tomorrow and see if that clears any if this up. Thanks for the help on this!
  27. Jan 16, 2023 at 4:39 PM
    jham101
    jham101 New Member
    So I have isolated it down to a squeaky upper ball joint bushing. Thanks for the help!
    Johnemi1 likes this.
  28. Jul 9, 2023 at 8:21 AM
    Johnemi1
    Johnemi1 New Member
    Emily
    2014 black tundra
    2014 Tundra. Same problem for 2 years. Changed front rotors, pads and calipers. New rear brakes. Have to be going at some speed. Started on left. Dealer and other mechanics don't know. Has anyone figured this out?
  29. Jul 9, 2023 at 10:00 AM
    jham101
    jham101 New Member
    So I had an aftermarket ball joint installed at some point. That ball joint needed to be greased. Greasing It immediately solved the issue for me.
  30. Jul 9, 2023 at 10:31 AM
    Johnemi1
    Johnemi1 New Member
    Emily
    2014 black tundra
    I'll try that! Thanks.
    jham101 likes this.
