Icon RXT spring squeaking
Discussion in 'Suspension' started by IgotSR5onit, Dec 5, 2022.
  1. Dec 5, 2022 at 9:46 AM
    IgotSR5onit
    IgotSR5onit [OP] New Member
    I installed the Icon RXT leaf packs 6-700 miles ago on the 2nd option and I developed some squeaking in the them as of yesterday. All was quiet until then. I was wondering if I was suppose to grease the leaf bushings on install. The directions didn’t call for it and I didn’t see anyone in any videos doing it. Haven’t been able to get under is for the rain, but it sounds like possibly the coming from the bushings.
  2. Dec 5, 2022 at 10:08 AM
    thumper_racer
    thumper_racer Not a New Member
    TN
    2012 MGM Rock Warrior
    Once some grime gets between the leafs, they will start to squeak. Clean them and it should go away for a little while. I did read someone sprayed some chain grease on them and that seemed to help too.
    IgotSR5onit[OP] likes this.
  3. Dec 5, 2022 at 10:28 AM
    IgotSR5onit
    yeah, I read someone using chain wax and that seemed like a good idea. I’ve had trucks with squeaky springs, but never this soon after putting new springs on. I’m going to Retorque and possibly drop the springs and grease the bushings. I didn’t know if I was suppose to grease them beforehand?
  4. Dec 5, 2022 at 10:39 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Urethane bushings (if you have 'em) do get lubed with Sil-Glyde or similar urethane compatible lube.
  5. Dec 5, 2022 at 10:50 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    This is my squeak solver...
  6. May 29, 2023 at 5:10 AM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Has this stopped the squeak for you ? I tried pressure washing. Nope. Tried silicon lube. Stopped for a day then nope. This white lithium is my 3rd attempt at squeak solving.
  7. May 30, 2023 at 2:17 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    It has.
    Regular maintenance thing for me and easy to do with my lift.
    My semi annual undercarriage maintenance consists of:
    pressure wash, WD-40, wipe down, lithium all pivot points.
    When assembling leafs for option #3, I shot lithium between them all before tightening the center pin.
    Squeak free with about 4k mi since suspension swap.
