Towing with my tundra for first time
Discussion in '3rd Gen Tundras (2022+)' started by AustinTexas, Dec 5, 2022.
  1. Dec 5, 2022 at 10:23 AM
    AustinTexas
    AustinTexas [OP] New Member
    Question:
    When I tow for the first time, is just hook up the trailer and plug in the bracket light and off I go
    Or do I need to push any buttons or settings up front to activate the brake light connection?
    thanks
  2. Dec 5, 2022 at 11:02 AM
    Breathing Borla
    I think the biggest one is to turn off the parking sensor auto brake thing
    it looks like a car hitting a cone or something, otherwise when you back up it will hit the brakes, etc on you
    and then tow mode or tow more + depending on your trailer weight. if you have trailer brakes you'll also need to set that up
    I would read your manual , lots of good stuff in there
    ColoradoTJ and GODZILLA like this.
  3. Dec 5, 2022 at 11:06 AM
    DJyrjn
    DJyrjn New Member
    D
    If this is your first time towing, you should also consider practizing backing up the trailer. Of the all things you need to do, that will be the most difficult.
    ColoradoTJ and Tundrafarm like this.
  4. Dec 5, 2022 at 11:36 AM
    Breathing Borla
    and that will be really hard if you don't disable the auto brakes, LOL
    aj350925 likes this.
  5. Dec 5, 2022 at 11:38 AM
    Terndrerrr
    Terndrerrr guzzling dealer repellent
    Music City
    Dual 5.7s
    TRD Fox, RAS, 285/75 DTs, dual battery, SS3 Pro
    This. A million times this.
    Nm6300'asl likes this.
  6. Dec 5, 2022 at 12:29 PM
    mass-hole
    mass-hole New Member
    Depends on what you are towing. A harbor freight cargo trailer will tow very different than a 9000 lb travel trailer :rofl:
  7. Dec 5, 2022 at 12:31 PM
    mass-hole
    And, oddly, the shorter trailers are the hardest to back up. I can put my 8' wide 24' long travel trailer in some ridiculous places but the 4'x8' trailer I rented to bring home a sod cutter ended up being parked 10' from where I actually intended it. I just gave up.
    Kap1, Leo's first and PERRY1060 like this.
  8. Dec 5, 2022 at 12:42 PM
    Boats N TRDs
    Boats N TRDs New Member
    Travis
    2022 Tundra Limited HV TRD OR
    Chrome delete
    To activate the lights, you only need to plug it in. There's no button to activate. But you should turn on your parking lights + your hazard lights and walk all the way around the trailer to make sure all lights are doing what they're supposed to do. Wiring on trailer lights are notoriously troublesome.
    RookieEP and 22PlatWCP like this.
  9. Dec 5, 2022 at 12:57 PM
    CTundraForMe
    CTundraForMe New Member
    I suggest reading the many other posts on this.
    Towing is a serious thing.
    Medic343 likes this.
  10. Dec 5, 2022 at 1:15 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    Go really slow the first time. The rear camera view of the bumper and hitch was a little weird to get used to. I ran the trailer tongue into the bumper my first time because small truck movements advance quickly on the screen. I guess it was good to get my first blemish out of the way:frusty:
  11. Dec 5, 2022 at 1:23 PM
    SES378
    SES378 New Member
    2015 Toyota Limited TRD Offroad 2WD
    Bilstein 6112/5160, Total Chaos UCA, Coachbuilder Shackles, Toyo AT2 295/70/18 tires
    Read the stickies in the Towing and Hauling Thread on this forum.
  12. Dec 5, 2022 at 2:07 PM
    Breathing Borla
    for you new towers also
    never underestimate the value of the outside gas pump dispenser at a larger station, lol
    you get into those middle pumps at a larger station, it can get ugly, especially if its busy
    509Yota and Terndrerrr like this.
  13. Dec 5, 2022 at 2:51 PM
    tbrady
    tbrady New Member
    Southern Idaho
    2022 DC LTD Army Green
    Leer Canopy, TRD Steps
    Read the owners manual. When you plug it in, the truck detects the trailer if you connect the 7 pin connector. I had no problem with the parking support system braking the truck when hooking up either of my two trailers. Once the 7 pin connector is hooked up, the parking support system is disabled.
  14. Dec 5, 2022 at 3:01 PM
    Breathing Borla
    they must have updated the software for that then, before you had to hit the button that looked like a cone otherwise CF.
    does it do it for a 4 pin as well automatically or just the 7 pin?
  15. Dec 5, 2022 at 3:20 PM
    SupaCoopa
    SupaCoopa New Member
    2022 Tundra 4x4 Crewmax
    Only with the 7 pin.
  16. Dec 5, 2022 at 4:04 PM
    Breathing Borla
    lol , maybe they will adjust that on a upcoming patch
    so if you tow with a 4 pin, remember to turn off the auto brake deal. Mental note
    cephasiii likes this.
  17. Dec 5, 2022 at 4:22 PM
    tbrady
    tbrady New Member
    Southern Idaho
    Thinking about it, I wonder if the truck couldn’t detect the trailer tongue or propane tanks. The radar sensor may be looking for a better return than comes off the angled tongue or plastic tank cover. I have a stealth front on my trailer.
  18. Dec 5, 2022 at 8:33 PM
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    2022 Limited Crewmax L
    MBM - TRD Offroad
    My parking rear sensor turns itself off when the trailer is plugged in.
    Setting up your trailer in the system is easy. Just follow along and have your details ready. That info gets saved so you don’t have to do it again.
    You can set the gain on the brake controller and then test it by sliding the right lever to the left while moving forward slowly. The trailer brakes should activate and stop your combo. You can adjust this until your trailer slows comfortably.
  19. Dec 6, 2022 at 4:29 AM
    aj350925
    aj350925 New Member
    I have had some trailers where it automatically turned itself off, and some where it didn't. I don't know what triggers it to shutoff or not.
  20. Dec 6, 2022 at 4:53 AM
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    This matters a lot!
    Here’s the things I’d recommend but I’m no expert
    - Read the manual as others have said
    - Watch a few YouTube videos about towing and trailer leveling
    - Use an adjustable hitch ball to help with trailer leveling
    - Test trailer lights after plugging in (seems obvious but I see trailers everyday without working brake lights, mostly landscapers)
    Truck side
    - Start the truck and press the Tow Haul button
    - Shift from drive to S4
    - Drive around the block in S4 as a shake down test, recheck stuff
    - Drive in S4 on local streets, between S4 and S5 on highway
    - Stay about 65mph on highway
    This may be overkill for a really lite trailer. Good luck
  21. Dec 6, 2022 at 5:01 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I did this with all my other Tundras to check lights. In the 22's there's an option for testing. It will flash each light in a certain order.
    Once my cargo trailer is connected (7pin) it is disabled. I can't remember if it always done automatically or not. For some reason I think it would beep at me with my utility trailer (4pin) hooked up
