2017 Headlight Level?
Discussion in 'Lighting' started by Buildn, Jul 20, 2017.
  1. Jul 20, 2017 at 8:13 AM
    Buildn
    Buildn [OP] 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    So how do you level the headlights? I know I can just dial them down but my 0 setting seems high. How do I know that 0 is correct?
    I did swap out hologens to hid but I did that on my 2008 with no light beam probs.
    I worked into the night last night and I had people moving over! lol
    plus you would have thought my beams were bug light zappers lol
    Once I have the correct low beam height can I manually crank down the light? So that I know 0 is per state or factory setting?
    Or is my headlight already correct?
  2. Jul 20, 2017 at 12:11 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    You can manually adjust your headlights down but those HID bulbs are meant for an HID projector or reflector bowl, you can't achieve a proper beam pattern with your setup.
    On the back of the housing there is a small white bolt, you turn that to manually adjust.
    Backslider and Tundraplatinum like this.
  3. Jul 20, 2017 at 12:18 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Aiming HIDs in reflector housings is like swatting a fly with a stick.
  4. Jul 20, 2017 at 2:06 PM
    Buildn
    Medina, Ohio
    Ok thanks Moto
    MotoTundra likes this.
  5. Jul 20, 2017 at 2:12 PM
    Buildn
    Medina, Ohio
    I think I'll just turn the knob down a couple degrees from the dash button. I don't want to knock em out of factory setting. At 25 feet I should be 42" and I'm at 46" which according to State of Ohio I can't exceed 5" so I'm thinking I'm in compliance? But when I'm behind cars I light them up big time and they are pulling over.
    But on coming traffic does not flash me. Should I lower anyway? For the people I am behind?
  6. Jul 20, 2017 at 2:14 PM
    Buildn
    Medina, Ohio
    I didn't have this problem with my 2008 Tundra and I am using same hid system
  7. Jul 20, 2017 at 2:16 PM
    Buildn
    Medina, Ohio
    Thanks for the help. I'm thinking I'll just keep them where I'm at and if I get pulled over I have the facts per State of Ohio code
  8. Jul 20, 2017 at 3:53 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    The legit fix is to get retrofitted headlights with proper HID projectors.
    Its hard to say this without sounding rude, I am not trying to sound rude though, haha, but you are basically high beaming everyone.
    MTwiford likes this.
  9. Jul 20, 2017 at 4:15 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    Agreed - your reflectors are just scattering all that white light all over the place like a massive flood light. To get a better idea you should turn your lights on tonight and then look at them from the front, give yourself about 50'. It's killer on the eyes when someone has HID or LEDs in a reflector bowl. =(
    So uh, I'll be selling my Spyders in a week or so.. totally unrelated. ;)
    MotoTundra[QUOTED] likes this.
  10. Jul 20, 2017 at 5:25 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    If you get pulled over with those, you'll likely get tagged, regardless of the aim. Ohio is the worst.
  11. Jul 20, 2017 at 6:30 PM
    Buildn
    Medina, Ohio
    Will see this fall when it gets darker. I might just dial down them from zero to two
  12. Jul 20, 2017 at 6:35 PM
    Buildn
    Medina, Ohio
    Well I gotta do something since the roads around me are not lighted. I'm out in the farm country suburb of Cleveland
  13. Jul 20, 2017 at 7:08 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Retrofit! Do it, do it!
    HUTCHJ and 1UPPER like this.
  14. Jul 20, 2017 at 8:19 PM
    Buildn
    Medina, Ohio
  15. Jul 20, 2017 at 8:22 PM
    HUTCHJ
    HUTCHJ I can ride my bike with no handlebars
    J
    It's because you put HIDs in the wrong type of headlight. Take them out.
  16. Jul 20, 2017 at 8:24 PM
    HUTCHJ
    J
    This is what it looks like when you do a retrofit.
    BlueBottle and MotoTundra like this.
  17. Jul 20, 2017 at 8:24 PM
    Buildn
    Medina, Ohio
    Na I got em in my last Tundra an 08. I hot it figured out thanks
  18. Jul 20, 2017 at 8:26 PM
    HUTCHJ
    J
    Sorry man, I hate to be rude to a fellow tundra owner but you should take them out. Seriously. You might not "think" you're blinding people, but you are.
  19. Jul 21, 2017 at 10:20 AM
    Buildn
    Medina, Ohio
    I'm not hitting them in there eyes, the light is still staying within the stock reflectors. I was just behind smaller cars that were in my light line. Would have happened if I had projectors. I just did a wall test from 25' away and I'm within criteria according to state guidelines. Checked with TRS and I'm still legal just light pattern isn't as clean as projectors would be.
    Thanks for reply :)
  20. Jul 21, 2017 at 12:09 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    I'm running LED and mine are running like yours, nice crisp line and so much better than that nasty yellow light.
    HUTCHJ[QUOTED] likes this.
  21. Jul 21, 2017 at 1:26 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    HIDs in reflectors DO cause glare for other drivers, because science. Have a friend drive toward you in your truck while you're in another car. I think you'll be surprised as it is not a judgement that can be made from the driver's seat.
  22. Jul 21, 2017 at 1:35 PM
    Backslider
    Tooele, UT
  23. Jul 21, 2017 at 3:30 PM
    Buildn
    Medina, Ohio
    All I'm saying is that there not aimed at eyes of oncoming drivers. I had same set up in 08 Tundra. I just wanted to make sure that my lights were not aimed at on coming drivers. Projectors give you a more controlled beam. If the hid's were an issue they would be banned
  24. Jul 21, 2017 at 4:59 PM
    HUTCHJ
    J
    They are illegal in your application... so technically they are banned...
  25. Jul 21, 2017 at 6:12 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Ok, well. You have been doused in the wisdom of the board. What you choose to do with it is of course up to you. cheers.
