Best 1st gen leveling kit for on/off road?
Discussion in '1st Gen Tundras (2000-2006)' started by cameron92, Nov 27, 2020.
  1. Nov 27, 2020 at 8:56 AM
    cameron92
    cameron92 [OP] New Member
    PNW (State of Jefferson)
    2005 Phantom Pearl Grey Tundra Limited DC 4WD, 4.7L VVTI, LSD, Tow Package
    2.5in suspension lift (Bilstein 5100's, Icon add-a-leaf, Eibach pro springs, Camburg upper control arms, and kyb replacement tophats.) ARMA Bedliner. Trailer Braking System. Fifth wheel underbed mount plates (frame mounted) W/ through bolts in bed. Yakima Q-Towers W/ 58in Yakima round crossbars and 52in Yakima wind fairing.
    Looking to level my 05 4dr limited. I have all oem suspension and not really feeling the raked look on my truck anymore. Any suggestions for a quality leveling kit that would be great for on/off road use without breaking the bank. All help is appreciated, thank you.
  2. Nov 27, 2020 at 9:10 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Welcome to the forum cameron92 and thank you for your service! I recently installed a kit from Rough Country. Definitely does the job of lifting and leveling. Can't confirm ride quality yet but if you search the interwebs, it has great reviews. Can add 33"s after this lift/leveling kit no problem.
    Of course during the installation I noticed everything else under the yota that was beat to hell. So in addition I upgraded front strut assemblies, swaybar links, UCAs and today I'm replacing LCA's, eccentric bolts, and lower balls.
    Nice spacer kit if you're on a budget though! https://www.roughcountry.com/toyota-suspension-lift-kit-750c.html?find=2005-toyota-tundra-4wd-736517
    cameron92[OP] and Darkness like this.
  3. Nov 27, 2020 at 11:15 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Note- spacer kits are not recommended for off road. They mess with the angles up front and folks have damaged components (such as shocks) when using them offroad. If you do in fact use your truck offroad you will be much happier with a coil over.
    Aerindel and Glock 40 like this.
  4. Nov 27, 2020 at 3:55 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Best or cheapest?
  5. Nov 27, 2020 at 5:22 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    meh... good enough for mild to moderate offroading like hunting and fishing roads. Can't argue with your logic though. More beef if you're offroading as a recreation or going to Moab. I've got a meaty Jeep for the serious stuff.
  6. Nov 27, 2020 at 10:21 PM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    Nice Phantom gray pearl :thumbsup:
  7. Nov 28, 2020 at 1:36 PM
    SouthPaw
    2000 Limited 4x4 AC
    I mean multiple options. Everything from $1000 - $80 spacers. The general consensus is Bilstein 5100’s will do what you want and won’t break the bank. First Gen Offroad is a good source for these and multiple other options. I recently picked up a used set Toytec boss coil overs for a good deal so that’s what I’ll be running.
    Tundra2 and cameron92[OP] like this.
  8. Dec 1, 2020 at 11:54 PM
    chrifishtopher
    chrifishtopher New Member
    Huntington Beach, CA
    04 Tundra DC 4WD
    5100s front and rear on the highest setting will give you a nice level truck and about 2 to 2.5 inches up front and 1 inch in rear. You can get front and rear for about $400, so that's pretty hard to beat. I've got 5100s on mine plus Eibach pro lift springs ($160) and rear Icon rear AAL lift ($215) and it sits just about dead level with my RTT on. Also running 35s and Camburg UCA.
  9. Dec 2, 2020 at 10:27 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    A nice 2.5" coilover for the front with 33's, you'll be happy.
    https://camburg.com/shop/suspension...urg-toyota-tundra-00-fox-performance-2-5-kit/
    aredub likes this.
  10. Dec 6, 2020 at 12:16 PM
    cameron92
    Thank you to everyone, i was originally considering the pro comp spacers but after hearing how crummy they are off road, i am going the coil over route instead now.
  11. Dec 6, 2020 at 12:20 PM
    GIN•OKUMA
    Fish
    26.57°
    And like that the group successfully spent someone’s money. :D
  12. Dec 9, 2020 at 9:35 PM
    dropindeuces
    dropindeuces New Member
    What kind of tires do you have on your truck? They look like the K02's
  13. Dec 16, 2020 at 11:40 PM
    chrifishtopher
    04 Tundra DC 4WD
    Kenda Klever RT 35X10.5R17 in that pic. Profile pic i have KO2s on.
  14. Dec 17, 2020 at 12:21 AM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    @cameron92 my recommendation would be to keep it simple for the sake of reliability. After some research, I opted to install Bilstein 5100s which allows one to increase the front ride height by adjusting the snap-rings while still utilizing the factory coils. I felt this was the best option for me after reading about other's experiences using spacers and aftermarket control arms etc. The installation instructions will say what position to use for the desired increase in ride height. I used the second position from the bottom to achieve a level front and rear ride height. Rent the coil strut spring compression tool from your local automotive store and you can have the job done in a couple of hours. If you do opt to go with the Bilstein 5100s consider applying a clear coat of spray paint on them to keep them from oxidizing and will remain looking like new for longer. Keep us posted whichever direction you decide to go!
    @chrifishtopher - do you have any pics posted of your ditch light installation? I ordered brackets and lights but have yet to install them. Interested to see how others have installed theirs.
  15. Dec 17, 2020 at 12:37 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I wish I'd though the clear coat spray paint idea.
    2nd, 3rd, or 4th vote for Bilstein 5100s
    Bilsteing 5100, front and rear. I ordered my front coilovers from firstgenoffroad as @SouthPaw said in post #7. I paid them extra to assemble them because I didn't want to deal with spring compressors.
    Alcan rear leaf packs
  16. Oct 18, 2022 at 5:02 PM
    cameron92
    Sorry for the late posting but i got the suspension figured out, i went Bilstien 5100's, new eibach pro lift springs, new tie rods, camburg uca's, kyb strut plates and icon add a leaf with some 5100's in the rear. Came out perfect, just had to wait for all the parts to show up.
    Vr0ck, Sunnier and FrenchToasty like this.
  17. Oct 18, 2022 at 5:08 PM
    shifty` Is the Gila Copter a love machine?
    Don't leave us hanging, we need pics! And also, do you have the (A) model# of the pro lift springs and whether they're 650 or 700, and (B) what circlip did you use on the strut, (C) anything for lift out back?
    cameron92[QUOTED][OP] and Vr0ck like this.
  18. Oct 18, 2022 at 7:36 PM
    cameron92
    A) I used the MPN#: E30-82-066-04-20 eibach pro springs, distrubuter i bought them from didnt have the 650 or 700 in the description. B) i used the given circlip that came with the 5100's. the 5100 circlip is super strong, its the 6100's circlip thats having the failing issues from bilstien from what i could find out in my research. C) The shocks lifted the rear end 2 inches and the add a leafs are advertised as a 1.5 inch lift but thats if you dont install taller/bigger shocks in the rear. Its about 2.5in in the front and 2in in the rear. Ill post pics tomorrow when the sun is out, its a bit to dark out right now
    itsWarrior, Vr0ck and Sunnier like this.
  19. Oct 18, 2022 at 7:39 PM
    Right, I take it you went with the bottom-most notch? There are (5, IIRC) notches you can circlip into.
    Stoked to see pics. Congrats on getting it done!
  20. Oct 18, 2022 at 7:41 PM
    cameron92
    I went on the highest notch i can for the double cab which is the 3rd or 4th i believe.
  21. Oct 18, 2022 at 7:54 PM
    Ride isn't too harsh or stiff?
    Only reason I'm asking is, with stock springs you're right, Bilstein reco is maximum 4th clip on 4WD DC, but there's no limit on 2WD.
    I think those Eibach sport springs may be offering lift, not stock, and I think the reco for lifted springs (at least Dobinsons and OME) is bottom notch. Depending on spring height (in mm) for that Eibach spring, you may be able to eek out 2nd or 3rd or maybe evne 4th notch.
    If you're 2WD it's potentially negligible when using stock, but I doubt it's the case with a lifted spring. I'm not seeing if you're 4WD or 2WD, but tossing out the info all the same.
    Vr0ck likes this.
  22. Oct 19, 2022 at 11:29 PM
    cameron92
    shifty` likes this.
  23. Oct 19, 2022 at 11:38 PM
    cameron92
    With the eibach springs Im on the 4th notch with no problems. My truck is a 4wd so the 5th notch is off limits for me. The ride isnt to stiff but stiff enough to prevent some of that body roll i use to get with the stock suspension. I still have a slight rake on the stance but once i but a camper shell with crossbars and a basket on top it will help level the rake out a little, but i still use the truck as a truck so the rake is nice when the bed is full with logs or gravel.
    shifty`[QUOTED] likes this.
  24. Oct 20, 2022 at 6:11 AM
    Yes, 4th notch is off-limits when using stock spring height w/OEM 4WD springs which are more stout than OEM 2WD springs (to compensate for weight, no doubt).
    Per Eibach, springs you bought provide 2.5"+ lift, so even taller/beefier than 4WD stock. Keep your eyes out for issues, you may be setting yourself up for premature fatigue. At least two vendors I found online won't even pre-assemble on anything except the 1st clip if using taller springs -- you're achieving lift via the springs in that case, not the notch setting. Did you try using 1st notch or 2nd notch to see where it lands you, or just jump straight to 4th notch?
    cameron92[QUOTED][OP] likes this.
  25. Oct 20, 2022 at 6:52 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Congrats on the new suspension! As others have mentioned, the 5100 recommendations you’re seeing are for factory spring, you may need to adjust accordingly since you have the Eibachs on there. The rear shocks do not add any lift to the rear. They are able to extend further than the stock ones and could accommodate 2” of lift from new leafs or a block or whatever. So the lift in the back is only from the new leafs. You could take the rear shocks off and the truck would sit the same. They merely dampen the movement.
  26. Feb 1, 2023 at 11:23 PM
    cameron92
    I went straight to the 4th notch to be honest. I'm the 2nd owner of my tundra and the previous owner had already replaced the stock springs with some super stiff performance springs, so I had no clue if those were even stock spring hieght but they were way past due in terms of replacing weather I lifted the truck or kept it at stock ride hieght.
    I also had limited time at the shop I did the suspension on as it wasn't my shop and i had two days with the lift to get it done as this truck is also my daily driver, so I had no real time to play with the notches.
    So far ive had no issues fatigue wise in the front end. I take my truck into a trusted shop for routine and scheduled maintence, and they do a full truck inspection every time I take it in. So if something comes up, I'll definently post it here.
    Also just updated my info on my profile for the finer details on the truck for less confusion in the future.
  27. Feb 2, 2023 at 9:28 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If you jack your truck up off the ground does the suspension decompress at all before the tire comes off the ground? With a 2 inch lifted coil on the 4th notch sounds like it'd be rough af.
    shifty` likes this.
  28. Feb 3, 2023 at 5:39 AM
    Problem is, "rough af" is subjective. Some people like it rough, some like it gentle, some like it stiff, some like it soft. I've talked to people who swear rough and stiff is "sportier" feeling and they don't GAF what collateral damage it may cause. I've ridden in cars that were so gentle and soft stuff would freely slide around in the vehicle and it felt like you were floating in a cloud and can't help but wonder what the bushings look like a few dozen-k miles down the road.
    This disparity between personal preferences is why it's always best to follow the manufacturer's recommendation. They're the ones who've tested this, or at least done the calculations on the geometry/limitations of vehicles to say what's acceptable and what's not. But at the end of the day ... your truck, your choice.
  29. Feb 3, 2023 at 7:50 AM
    cameron92
    Ill have to play around with the jack and some stop blocks the next weekend I have free and let ya know. To me it hasn't been that rough of a ride at all. Ive taken the truck offroad and obviously on public roads as well, but havnt felt any real harshness or anything like that when cruising, turning, or hitting some bumps and such. Ive had "rougher" rides like in my old 89 toyota pickup and 95 4runner.
