Looking for tow mirrors!!!
Discussion in '1st Gen Tundras (2000-2006)' started by itscoreyc, Jul 12, 2020.
  1. Apr 3, 2022 at 10:22 PM
    #91
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I'm a Dodge.
  2. May 16, 2022 at 2:13 PM
    #92
    Badderup
    Badderup New Member
    A.J.
    Utah
    2019 Crew max
    Vent visors Side steps - wife and daughter are short
    Just bought a new-to-me 2019. Are there different bolt patterns within 07-21? I’ve been looking at a couple mirrors and some say 07-17, while a others have said 09-21. The Boost ones say 07-21. I’m confused.
  3. May 16, 2022 at 2:23 PM
    #93
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
    Welcome to the forums, this thread is specific to the 2000-2006 trucks which are different. Your question better suited for the 2014-2021 forums. https://www.tundras.com/forums/2-5-gen-tundras-2014-2021.27/
    bmf4069 and Badderup[QUOTED] like this.
  4. May 16, 2022 at 2:24 PM
    #94
    Badderup
    Badderup New Member
    A.J.
    Utah
    2019 Crew max
    My bad. I just did a search and didn’t even pay attention to which gen forum I was in.
    Tundra2, bmf4069, 04TundraTRD and 3 others like this.
  5. Jun 12, 2022 at 12:01 PM
    #95
    WestCoast Fl
    WestCoast Fl New Member
    Mick
    2006 Tundra Double Cab
    Bilstien adjustable shocks XD series 17" wheels
    I just started on converting my 2006 Tundra DC xsp over to the Dodge mirrors. I got the passenger side done today. These are the ones I got on ebay 272483986384 they were about $115.00 for the pair delivered. I thought they would be cheap but actually look to be pretty good. Getting the wiring figured out was the hardest part. Is the install perfect? Hardly. Does it work yes. Seems to be pretty solid. I'm showing the way I wired it. And they work as they should (up down left right) The pins were different on the dodge mirrors so I just spliced them together. Took me about 3 hours to do this one side.
    #95
  6. Jun 12, 2022 at 12:51 PM
    #96
    biebs96
    PA
    Those mirrors look like they fit well. Do you have any photos of how they are mounted against the body?
    the mirror size was one of my biggest complaints when I had my 05 years ago.
  7. Jun 12, 2022 at 1:31 PM
    #97
    shifty` Our private little trip to hell
    Better than others I've seen, but then I zoomed in on things, curious about the lower fitment. Probably looks good from 5ft away, definitely looks awesome driving down the road, but I'd be worried about leaks especially on this lower I'm seeing. Still, better fit than half the other stuff I see people rigging onto their rides.
  8. Jun 26, 2022 at 5:15 PM
    #98
    typhoon
    typhoon New Member
    2003 Tundra AC Limited
    Wrapped up install of the Dodge mirror.
    Definitely referenced your wiring pictures here, although the pins in my new mirrors were the same so I just swapped pins over
    #98
    WestCoast Fl[QUOTED] likes this.
  9. Jun 26, 2022 at 5:19 PM
    #99
    typhoon
    typhoon New Member
    Here is some close up shots for the curious.
  10. Jun 26, 2022 at 11:51 PM
    #100
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    What kinda goo did you use on the top and bottom?
  11. Jun 27, 2022 at 5:41 AM
    #101
    WestCoast Fl
    Mick
    I used my Tundra mirror gaskets and will probably follow up with some silicone around the edges. I just pulled my Travel Trailer to a local campground and it was really nice to see whats going on back there. So glad I found this post and everyone's input.
  12. Jun 27, 2022 at 7:33 AM
    #102
    typhoon
    typhoon New Member
    Just some rtv, hopefully seal out some water
    CodyP[QUOTED] likes this.
  13. Sep 23, 2022 at 6:17 PM
    #103
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It may have been asked, or stated, but I didn't see it. These are 2002-2009 Dodge ram tow mirrors? Yes?
  14. Sep 23, 2022 at 8:59 PM
    #104
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I think it’s 99-07 or something but yes
    Tundra2[QUOTED] likes this.
  15. Sep 29, 2022 at 10:00 PM
    #105
    Casper421
    In the woods
    06 DC
    @CodyP Whats the latest on the tow mirrors? Do they still move a ton?
  16. Sep 30, 2022 at 2:22 PM
    #106
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I took mine off as I didn’t like the ‘fit’ and the cheaper non OE mirrors wiggled quite a bit when towing. I just went back to the Cipa slide-ons that fit our mirrors and run those the 2-5 times a year I tow a TT.
    I still need to have my buddy fab up a base adapter to go from 2006 to 2007 and then just use newer Tundra tow mirrors.
    daveeasa and Casper421[QUOTED] like this.
  17. Sep 30, 2022 at 2:58 PM
    #107
    daveeasa
    2nd Gen Tundra tow mirrors would be the one thing I would consider.
    CodyP and Tundra2 like this.
  18. Sep 30, 2022 at 4:01 PM
    #108
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Hmmmm. Sounds interesting.
    I don't tow often but I wouldn't mind the option.
