Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Aug 16, 2022 at 5:26 PM
    #2671
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Normal behavior. :thumbsup:
  2. Aug 17, 2022 at 4:32 PM
    #2672
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Awesome, thanks... Never seen it move before.. I mean I've seen it go higher.
    Wynnded[QUOTED] likes this.
  3. Aug 23, 2022 at 6:27 AM
    #2673
    Svengalicanada
    Svengalicanada New Member
    2010 rcsb 4x4 4.6l
    Yotalife..
    Hey how did you ever make out with this? I've been going through the same thing for three years or more. As soon as the electric fan starts up it stops..might be the fans clutch slipping
    I put some copper tubing on a lube spray bottle so I I could spray in behind the electric fan and it seemed to stop it for a few months ..
  4. Sep 7, 2022 at 9:06 AM
    #2674
    Airpower
    Airpower New Member
    2011 Toyota Sequoia Limited 4X4
    TSS rims, N-Fab step bars
    Need some advice please.
    I have a 2011 5.7L Limited 4X4 Sequoia. I had an issue with intermittent rough idles, sluggishness on the highway, and one instance where the truck would not start and then miraculously started and ran for a couple more months.
    This weekend it wouldn't start again, I had been suspecting a failing fuel pump due to the above symptoms so I went ahead and replaced it with a FFV Delphi assembly.
    It started fine, runs well, but now after sitting for too long it has a longer than normal crank time. It's not terrible, only a couple of seconds longer than it should be, but there's clearly something wrong.
    I assume the fuel pump has a check valve on it somewhere, and my assumption is the fuel is draining back into the tank after it sits.
    I'm guessing the best way to test this theory is to hook up a pressure gauge on the rail, pressurize the system, then let it sit and monitor the pressure.
    Does anyone have any other suggestions? If it turns out to be a check valve, I am assuming it's on the pump assembly and I will have to remove the tank and swap it out again?
    If I do have to drop the tank again, is there any easier way to access the top of the fuel tank to disconnect the the fuel lines? When I pulled it this weekend getting the lines back on was rather difficult, especially because one line is very short.
    Thanks for the help.
    Best,
    AP
  5. Sep 7, 2022 at 9:55 AM
    #2675
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    Lots of things could cause that, but honestly with it being that new a dealership may be your best bet. For better troubleshooting more info might be helpful. Size of the trailer, general temp outside, speed you were towing at, tow haul engaged, gear used, etc.
    If you're just wanting to know about the fluid swap; you'll never hurt it doing a drain and fill. I know on the previous gen you would definitely want to change the fluid after the overheat light because of how high that threshold is set. Not sure where the 3rd gen threshold is and how much fluid degradation may have occurred.
  6. Sep 7, 2022 at 10:45 AM
    #2676
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    How heavy were you towing
  7. Sep 22, 2022 at 4:11 PM
    #2677
    Kappaisa
    Kappaisa New Member
    Hey everyone I tried searching through the thread with the search option looking for something like what I’m dealing with.
    i’ll keep it short
    2010 tundra base 4.6
    I got a misfire on cylinder five and cylinder six within one minute of start up
    Occasional misfire on cylinder four and cylinder seven.
    I have swapped coils around misfire doesn’t move
    I have swapped spark plugs around misfire doesn’t move
    I have swapped injectors around misfire doesn’t move
    I have checked compression and compression is between 170 and 185 on all cylinders (conveniently the 172 compression is on cylinder five)
    The truck had the catalytic converters stolen so I had a new full exhaust including Cats put on by the dealer. Hasn’t even been 12 miles since then and I’ve got for sure misfire cylinder five and six occasional misfire four and seven.
    none of the vacuum lines look corroded brittle or cracked. What am I missing? Something Toyota specific?
    valve covers are leaking a little bit of oil so I ordered valve cover gaskets and a new intake manifold gasket. They should arrive tomorrow
    $10 to whoever points me in the direction that solves my problem.
    FrostyTundra22 likes this.
  8. Sep 22, 2022 at 8:17 PM
    #2678
    FrostyTundra22
    FrostyTundra22 No longer new member
    2020 Toyota Tundra 1794 Crewmax
    if you swapped coil and spark plugs and issue remains, Might be cables.
  9. Sep 22, 2022 at 11:42 PM
    #2679
    Kappaisa
    Kappaisa New Member
    Play cables you mean the harness connector and associated wires?
    Honestly that’s not something that came to mind but it is something I will check. I’ll report back with what I find
  10. Sep 23, 2022 at 7:52 AM
    #2680
    FrostyTundra22
    yes, that’s exactly right. Sometimes those could be the culprit.
  11. Sep 23, 2022 at 7:58 AM
    #2681
    e30cabrio
    West Valley, Phoenix, Az.
    2010 Crewmax, 2013 Sequoia Limited
    Sequoia LED Headlights! D.T. L.T. headers, dual exh., BDX, S&B intake, 2018 seat skins.
    2013 Sequoia condenser fan sporadic failure when sitting for long periods causing the AC to blow warm.
    I have replaced the fan, can I fix the old one for a spare?
  12. Sep 28, 2022 at 10:57 AM
    #2682
    HewittTech01
    HewittTech01 Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    As I am sure you have found in your research the P0418 – SAIS Circuit/Relay ‘A’ Circuit Malfunction Bank 1. This is related to the Secondary Air Injection System and unfortunately an inevitable issue on Tundras. Below I have include a few recent threads about this failure prone system. Please do not hesitate to contact us if you have any questions.
    What Does the Secondary Air Injection System Do?
    https://www.tundras.com/threads/what-does-the-secondary-air-injection-system-do.113683/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tundras.com/threads/what-do-my-secondary-air-injection-error-codes-mean.113686/
    How to Fix Secondary Air Injection System?
    https://www.tundras.com/threads/how-do-you-fix-the-secondary-air-injection-system.113688/
  13. Sep 28, 2022 at 11:00 AM
    #2683
    HewittTech01
    Lexington, SC
    @Ruggybuggy Spot on! I recently post a new thread going into a little more detail about the SAIS. I hope this adds value to anyone looking to learn more.
    French Avocado and Wynnded like this.
  14. Oct 6, 2022 at 8:05 AM
    #2684
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    After installing the Stillen Stage 2 Intake, I'm getting a high pitched whine in the cabin coming from the center console area. TBH it sounds like when you have a bad ground on a sound system and can hear the RPMs high pitched whine through something in the cabin. No idea on this one since I don't see how the INTAKE affected it, but it wasn't there before, and is there after.
  15. Oct 6, 2022 at 8:06 AM
    #2685
    Wyoming
    Air intakes are noise generators on these trucks, so my guess is that it's working as intended.
  16. Oct 6, 2022 at 8:46 AM
    #2686
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Remove it to see if it disappears. If it does, reinstall. If it returns, then you'll know.
    M3Tundra-JK[QUOTED] likes this.
  17. Oct 6, 2022 at 10:55 AM
    #2687
    jpat
    jpat New Member
    2018 Double Cab TRD OR
    I have a 2018 Tundra 5.7L Flex Fuel SR5 with tow package. I am trying to do ATF level check following the "FLUID TEMPERATURE CHECK" procedure. According to the procedure, "It is necessary to change to temperature detection mode in order to idle the vehicle appropriately."
    After inserting a jumper in OBD2 port pins 4 and 13 and starting the engine, the indicator lights on the combination meter are normal (not blinking). So I am unable to get the vehicle into temperature detection mode.
    Any thoughts how to proceed?
  18. Oct 6, 2022 at 6:14 PM
    #2688
    blackdemon_tt
    Quick question. My black key no longer locks my door lock, but it does unlock it. I thought that it was a lubrication issue, but my spare/valet key locks and unlocks my door.
    I know, first world problems... I've used the key fob, but lately I've been using the key to unlock, or the door lock button by the window switch to lock it... Any suggestions on what the issue is?
    Randy Morton likes this.
  19. Oct 6, 2022 at 6:38 PM
    #2689
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab, Beta Variant (I call it my Land Yacht)
    Probably a dirty contact in the key. Hopefully it's not worn out. The buttons should click, and I believe there's a light that lights up when you press a button. If the button doesn't light up, you'll need to take the key apart and clean the contacts. It's not difficult if you take your time and are gentle with the parts. If possible, use DeOxit D5 to protect them after you clean them.
  20. Oct 6, 2022 at 6:40 PM
    #2690
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It's likely wearing out. The cut on the valet key is probably a lot fresher. Does your black key see a lot more use than the valet key?
    blackdemon_tt[QUOTED] likes this.
  21. Oct 6, 2022 at 8:44 PM
    #2691
    blackdemon_tt
    Keyfob works fine, but when I turn to lock it jams up like its not the correct key, but unlocks just fine.
    Randy Morton[QUOTED] likes this.
  22. Oct 6, 2022 at 8:45 PM
    #2692
    blackdemon_tt
    I'm thinking its worn down.. Honestly, I just found my spare/valet key last week, so its technically new...
  23. Oct 6, 2022 at 9:21 PM
    #2693
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm surprised that the ignition hasn't given you the occasional problem too, but maybe they're just wearing together. If you don't have a heavy key ring, that helps as well.
  24. Oct 6, 2022 at 9:34 PM
    #2694
    blackdemon_tt
    Sure don't, just the fob, the house key and truck key. The ignition occassionally gives me an issue, like it locks up for a second, but I tug on the steering wheel and it turns with no issues.
  25. Oct 7, 2022 at 5:33 AM
    #2695
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Edit: Wrong tag
  26. Oct 7, 2022 at 5:36 AM
    #2696
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    @blackdemon_tt If you have the key code you can have the dealer cut a new key exactly as supplied when the truck was sold new.
    I'm assuming Toyota is the same as domestics I've owned with key codes.
    NewImprovedRon and blackdemon_tt like this.
  27. Oct 7, 2022 at 5:36 AM
    #2697
    COTundie
    Trey
    Pretty things
    I removed the K&N, drop-in filter the previous owner had installed, and replaced with a standard paper filter inorder to get rid of the "baby turbo/bov" sounds that you are experiencing.
    Wanna say I remember reading that some remove the "waffle", which I believe protects the MAF, to rid themselves of the whistle while retaining their fancy intake.
  28. Oct 7, 2022 at 6:13 AM
    #2698
    blackdemon_tt
    I will look into this... Thank you
  29. Oct 7, 2022 at 9:35 AM
    #2699
    Randy Morton
    Randy
    Sorry, I misread the problem. Hold the two keys up to the light with the valet key behind the problem key. You should be able to see the difference. A good locksmith can code cut a new key by measuring the valet key.
  30. Oct 7, 2022 at 10:21 AM
    #2700
    blackdemon_tt
    Cool, will inquire into that.
