T100 Brake Booster Upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by Thrussn, Mar 31, 2021.
  1. Jun 1, 2022 at 9:10 AM
    #121
    des2mtn
    des2mtn Third Member
    Where my wheels stop rolling
    2004 Black DC Limited 4x4
    Tonto cover
    I think I documented this in a few previous posts. I had to adjust the length of my push rod to stop my brakes from locking up.
    BubbaW and FirstGenVol like this.
  2. Jun 1, 2022 at 9:22 AM
    #122
    Casper421
    In the woods
    06 DC
    I have the same issue as you. Maybe the rod isn’t traveling far enough on the first push but builds up enough pressure to feel firm on the second. Maybe adjusting the rod out will provide more pressure on the first push. I’ll give it a shot next free time.
    FirstGenVol[QUOTED] and des2mtn like this.
  3. Jun 1, 2022 at 9:25 AM
    #123
    des2mtn
    Tonto cover
    I don't know if you have the OEM-style push-rod, but it might be worthwhile playing around with it, or possibly replace it with an adjustable one and play with that one. You can separate the MC from the booster without needing to bleed the brakes or do anything special. Not too difficult to mess with.
  4. Jun 1, 2022 at 3:06 PM
    #124
    Dave8699
    Dave8699 Trackrat
    NJ
    04 tundra AC
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    So I pulled the trigger and ordered 14wa calipers which I had them shipped to the machine shop to get milled. Also ordered crown performance SS brake lines. Now trying to get a hold of EBC rotors and orange pads nobody has them in stock.
  5. Jun 2, 2022 at 5:39 PM
    #125
    Dave8699
    Dave8699 Trackrat
    NJ
    04 tundra AC
    So a little update my brakes feel great now after I adjusted the push rod. But snice my caliper where super hit and sticking a little going to upgrade to the GX460 calipers. EBC rotors are all back ordered for months so I'll get oem 4runner rotors with ebc orange pads.
    AR 02 TUNDRA likes this.
  6. Sep 19, 2022 at 6:15 PM
    #126
    Dave8699
    Dave8699 Trackrat
    NJ
    04 tundra AC
    Ok so bringing this thread back up from the dead, update on the upgrade of the M/C and booster. It's working great better then stock and better then some newer brake systems. I am noticing some very low squealing noise from the brakes. Not sure exactly what it could be or if it's comes from the rear or front. It's not loud just has a high pitched squel. Any suggestions would be appreciated.
  7. Sep 19, 2022 at 6:17 PM
    #127
    shifty` Our private little trip to hell
    I actually have this on my truck naturally. I just assumed it's the pads. They're definitely not worn on mine, but it's done this all the years I've had the truck.
  8. Sep 19, 2022 at 6:18 PM
    #128
    Dave8699
    Dave8699 Trackrat
    NJ
    04 tundra AC
    That's what I was thinking also I'm using EBC orange pads of front and oem shoes on the rear.
  9. Sep 19, 2022 at 6:22 PM
    #129
    I'm not 100% positive what pads the PO put on mine, but they were virtually new when I bought the truck. Same with the shoes.
    I've always had a faint squeaky squeal, usually at slow speeds, like when braking as I'm backing out of the garage, etc. Definitely stock rotors. I thought it was the squealers signaling the brake pads were getting low, until I took the wheels off and inspected, brake pads are virtually new. Dunno.
    Anyway, I haven't done the upgrade, my truck already has WLs, maybe it's just a typical thing? Or is possibly a symptom of aftermarket pads?
    Dave8699[QUOTED] likes this.
  10. Sep 19, 2022 at 7:19 PM
    #130
    daveeasa
    Mine are quiet.
  11. Sep 20, 2022 at 2:21 AM
    #131
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Mine absolutely scream when I'm backing up after sitting overnight. Does it the whole way down the driveway. Did it before and after I changed pads, rotors, and hardware. I'm sure the neighbors hate it. If I go less than 1 mile per hour it doesn't do it but that's it.
    shifty`[QUOTED] likes this.
  12. Sep 20, 2022 at 4:17 AM
    #132
    bmf4069 Yup, that's car parts in a dishwasher
    Mine squeal in reverse too. Always have, even after brand new WL swap. I'm pretty sure a lot of ours do.
  13. Sep 20, 2022 at 5:17 AM
    #133
    @Dave8699 this is not to say there's not something wrong with yours, but apparently you're not alone, nor am I...
  14. Sep 20, 2022 at 1:09 PM
    #134
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Mine as well, until warmed up.
  15. Sep 20, 2022 at 1:11 PM
    #135
    des2mtn
    Tonto cover
    Mine used to squeal in reverse at start up too. Haven't noticed it lately though.
  16. Sep 20, 2022 at 1:44 PM
    #136
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Every toyota I've ever seen, had, or driven has always had squeaky brakes on the first drive of the day or in reverse.
    YMMV
  17. Sep 20, 2022 at 1:50 PM
    #137
    Casper421
    In the woods
    06 DC
    No squeak here, forward or reverse. It might be covered up by my horrendous lca bushing squeak though!
    bmf4069 and FrenchToasty like this.
  18. Sep 20, 2022 at 1:50 PM
    #138
    FrenchToasty The Desert rat, 6 lug enthusiast
    The SoAz
    None
    Same, even the rear discs on the 4runner do it
    des2mtn and Tundra2[QUOTED] like this.
  19. Sep 20, 2022 at 3:41 PM
    #139
    Dave8699
    Dave8699 Trackrat
    NJ
    04 tundra AC
    Wow ok so I'm guessing it's normal, now does the squeak go away once driving?
  20. Sep 20, 2022 at 5:34 PM
    #140
    Mine tends to. Sometimes I hear it when I'm creeping coming up to a light. I don't hear it during normal-speed braking.
  21. Sep 20, 2022 at 5:39 PM
    #141
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Possibly not enough grease on the back of the pads or pins?
  22. Sep 20, 2022 at 5:41 PM
    #142
    alb1k
    Left Coast
    It's good
    I'm guessing you didn't use copper anti-seize on those solos - neither did I. I should have read the directions better. But I fixed it.
    EDIT; Copper anti seize sucks. I added zerks and grease them now and then...
  23. Sep 20, 2022 at 6:57 PM
    #143
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Y'all tried these out yet?
    Jack McCarthy, bmf4069 and shifty` like this.
  24. Sep 20, 2022 at 6:57 PM
    #144
    alb1k
    Left Coast
    It's good
    Nokia mod? I hear it rips.
  25. Sep 20, 2022 at 7:32 PM
    #145
    NickB_01TRD
    KY
    I want to state again that mine only squeal backing up. Forward driving zero noise.
    Tundra2 likes this.
  26. Sep 20, 2022 at 7:33 PM
    #146
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    How do you normally park? Nose in towards house forcing you to back up first or???
  27. Sep 20, 2022 at 9:36 PM
    #147
    NickB_01TRD
    KY
    I face forward in the driveway. Admittedly to keep the water from leaking in from that roof weather stripping piece that I need to pull the topper back and redo/clean. If it wasn't for that I would back in.
  28. Nov 10, 2022 at 6:49 PM
    #148
    belcher92
    belcher92 New Member
    Josh
    2004 tundra 4x4 ac
    Curious on this part, I did the swap to the t100 parts and my brake pedal is super stiff. How do you adjust the push rod?
  29. Nov 10, 2022 at 7:29 PM
    #149
    Dave8699
    Dave8699 Trackrat
    NJ
    04 tundra AC
    It's pretty simple to adjust the push rod. In my case I had to adjust it all the way in. The hardest part is releasing the lock nut on the rod. The booster has pushrod that has the rounded nut and the luck nut. I used needle nose to hold the luck nut. Also if possible measure the distance on the M/C to see how much the push rod goes inside.
  30. Nov 27, 2022 at 12:51 PM
    #150
    Casper421
    In the woods
    06 DC
    @Thrussn Where you been man?! We need some updates. I’m about to Frankenstein the hell out of my truck!
    Thrussn[QUOTED][OP] likes this.
