Mirror tap for radar detector?
Discussion in '3rd Gen Tundras (2022+)' started by Tb2, Sep 15, 2022.
  1. Sep 15, 2022 at 5:03 AM
    Tb2
    Tb2 [OP] New Member
    James
    Does anyone know of a video showing how to tap mirror on new tundra for radar detectors?
  2. Sep 15, 2022 at 5:54 AM
    It there a connector on the back of the mirror? All you need is a power and ground from it.
  3. Sep 15, 2022 at 6:53 AM
    Tb2
    Tb2 [OP] New Member
    James
    Nice build what year is yours ? did you tap into back of mirror? I really would like to see what pins you tapped into.
    If anyone has a picture of the pins used to tap into would be greatly appreciated
  4. Sep 15, 2022 at 8:29 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Just take a multimeter with fine tips and start probing with the vehicle on.
    I'm sure standard wire coloring codes still apply.
    Buy the wire taps off Amazon, just make sure the connector to the radar detector is the same.
    https://smile.amazon.com/Xislet-Det...&sprefix=mirror+wire+tap,aps,131&sr=8-1-spons
  5. Sep 15, 2022 at 8:38 AM
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    There are some posts about this already on the forum with pictures and everything. Do a search and I am sure you will find what you are looking for.
  6. Sep 15, 2022 at 8:39 AM
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    Always use a multimeter! Can’t emphasize that enough.
    These are the pins on my 2020
