2019 4HI & 4Lo Lights Flashing!
Discussion in 'General Tundra Discussion' started by Ronin73, Jul 16, 2019.
  1. Jul 16, 2019 at 5:58 AM
    Ronin73
    Ronin73 [OP] New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Hello!
    My 2019 started having this issue on the way to work this morning. The 4hi and 4lo lights in the dash started to flash simultaneously and won't stop. The truck is not in 4x4 and I have stopped the vehicle, turned it off, and then started it, but the lights still flash. Any ideas?
    I am dropping it off at the dealer this evening. Just thought I'd ask to see if anyone has experienced this before. Thanks.
  2. Jul 16, 2019 at 7:25 AM
    Ronin73
    Update*
    It has been sitting for a couple of hours here at work, so I went and started it and the flashing has stopped. Still concerned, though, so I am going to drop it off at the dealer, but with it no longer flashing, they are probably going to say they can't do anything.
  3. Jul 16, 2019 at 7:34 AM
    bfd300
    bfd300 New Member
    See if you have reverse lights
    Ronin73[OP] likes this.
  4. Jul 16, 2019 at 7:40 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    I was having similar issues with my new 18 within 500 miles. On off on off so i took it in and they were off but I described what was happening and it needed a tune or software update. Maybe that’s all it is. I know not much help
  5. Jul 16, 2019 at 7:43 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    This happened to my 2018. Not sure what the issue was but I had to put the car in neutral shift to 4Lo and drive forward and reverse a few times. Then I shifted to 4Hi drove for 2 minutes until the light stayed constant. Then I turned it to 2Wd and havent had a problem since. It seemed like the car was just confused and took a bit for the computer to figure out what it wanted
    bulldog93 and Ronin73[OP] like this.
  6. Aug 8, 2019 at 7:35 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    It's most likely your brake stroke sensor. Mine does a similar thing when I start the vehicle. If I put it in neutral, then engage and disengage 4 Hi, then put it back in park, it usually stops. A friend of mine is a GM Certified mechanic, and he's replaced a number of these on Tundras that were all doing a similar thing. For some reason, Toyota wants the computer to measure your brake stroke. I promise I'm not making this up. Not sure what the stroke has to do with 4 Hi and Low, but there you have it. Hope this helps.
  7. Aug 9, 2019 at 4:37 AM
    Ronin73
    So, nothing to worry about? Hasn't done it since and everything is working properly.
  8. Aug 9, 2019 at 4:42 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Sounds Like stupid computer BULLSHIT !!
    Got to love technology
    Hope u get it straightened out bud
    Wero94 and Kerch71 like this.
  9. Aug 9, 2019 at 7:42 AM
    Kerch71
    Mechanicsville VA
    I wouldn't worry too much about it. I keep meaning to get the sensor changed just because it's annoying. Mine seems to go through spurts where it will do it everytime I start the truck, then it will stop for a few months. Been meaning to replace the sensor for at least a year. Just lazy but also not that concerned.
    Ronin73[QUOTED][OP] likes this.
  10. Dec 7, 2019 at 6:36 AM
    Ronin73
    Well, after this stopped last time when the vehicle was restarted, I haven't had any issues. It began flashing again on my drive into town yesterday and I immediately took it to the dealer. The ran diagnostics and the following code came back: P17A8. They said this indicated an open circuit in the transfer shift motor drive. They checked it out and said they couldn't find anything loose at all. They cleared the codes and said to come back if it happen again.
    bulldog93 and GODZILLA like this.
  11. Dec 7, 2019 at 6:47 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Could be a bad ground connection on the harness itself. This is for a Taco, but likely similar diagnostics and solutions:
    http://www.ttguide.net/transfer_shift_motor_control_circuit_circuit_open_p17a8_-1481.html
  12. Mar 13, 2020 at 12:49 AM
    mrflyinghigh
    mrflyinghigh New Member
    Jared
    2018 Blazing Blue Tundra Platinum
    I have the same thing. Took it to the dealer, no code cause it stopped flashing, and everything was working as advertised. Happened again a week later, they ended up changing the 4wd actuator. A month later, it’s still happening occasionally. Planning on taking it in soon, but i can’t plan on the lights flashing. It resets once the truck sits off for a while, and who knows when it comes back. Could be the next day, could be months....very frustrating
  13. Jan 20, 2021 at 8:09 AM
    Beef
    Beef New Member
    2020 Tundra 4x4 TSS
    Did any of you folks ever get this figured out? I am having the same issue with my 2020. 4Hi 4Lo lights blinking and a AWD malfunctions notice coming up on my screen on really cold mornings. The blinking and message leaves after 5-6 miles of driving and doesn't come on the rest of the day. Annoying as heck. Took it to the dealer and by the time i get there the codes are off. Left it overnight (of course its only in the 40s). No codes thrown and no history of any faults come up..
  14. Jan 20, 2021 at 8:17 AM
    Yoder18
    Yoder18 Veteran underwater basket weaver
    Mitch
    Front range Colorado
    18 tundra trd off-road
    •Toytec Radflo 3” with 1.5 shackles •+25mm icon rebound wheels matte black. •Prox15 tonneau/Softtopper •315/70r17 ridge grapplers •Wheelers front bumper stops •Spray in bed liner •Vleds floorwell leds front and back and interior led kit •Boss front bumper spacer •First choice fabrication welded sliders •8” ss dirty deeds exhaust •Tech12volts remote start with carlink •Vleds front turn signals leds •AFE pro dry s air filter •Baja xl sport amber fogs •Victory 4x4 strike bumper w hoop •Ajt designs chrome delete for vent rings and cup holder/gear shifter (black) •Wet okole seat covers •Husky floor liners •RCI skid plate and transmission skid •Jomax SpEed sensor guards •Rear diff breather location mod
    Mine is an 18 and has done this since I drove it off the lot but only really happens during the summer/fall time. If I take it to the car wash it trips something and sends the 4hi/lo lights after which I can’t engage 4wd and just have to let it sit or drive w it on for a while. It’s annoying as hell but the dealership didn’t know what to do about it either.
  15. Jan 20, 2021 at 9:08 AM
    Beef
    Beef New Member
    2020 Tundra 4x4 TSS
    Thanks for the reply but that is some bullcrap from Toyota right there. Mine has been only when it drops below 35.
  16. Jan 20, 2021 at 12:05 PM
    Ronin73
    After my visit to the dealer, it has never happened again.
  17. Jan 20, 2021 at 12:14 PM
    Beef
    Beef New Member
    2020 Tundra 4x4 TSS
    Well they are clearing codes for mine now so hopefully it does the same. Thanks for the reply
  18. Jan 28, 2021 at 12:39 PM
    JFever
    JFever New Member
    Jon
    2019 TRD PRO Tundra black.
    I AM WAY BEYOND FRUSTRATED WITH THIS PROBLEM ON MY TUNDRA! I have 4hi 4low flashing plus every other warning light illuminated. 4WD will not engage. Just got 20" of snow this week. Need to be able to get my girlfriend to her cancer treatments. More snow coming tonight. Bought a quality code diagnostic tool and reset everything. Then it immediately lights up with warnings again. Took it to the dealer and they don't know anything. Said its because of me altering the truck with a lift kit and larger tires. Tried the zero calibration reset and followed all instructions per posts showing the paperclip method. Super stressed.
  19. Jan 28, 2021 at 1:34 PM
    timsp8
    NY
    This might help. Or not. Just 4 hi and 4 lo flashing means 4wd switch between positions or unknown cause.
    Not my chart.
    bokch0y likes this.
  20. Jan 28, 2021 at 3:57 PM
    Beef
    Beef New Member
    2020 Tundra 4x4 TSS
    Unknown cause?.....that's some world class BS right there..
    They told me I had a loose connection an actuator. They tightened but it still lights up. Its gone much quicker now but it still does it. Gonna take it back into them when it real cold and let them keep it over night.
  21. Jan 30, 2021 at 9:56 AM
    Yoder18
    Mitch
    Strange mine will only do it when it’s hot out wtf
  22. Mar 28, 2021 at 5:39 PM
    LA184
    LA184 Living the Dream
    2014 4x4, 4.6L Radiant Red Tundra
    4 in lift, 35s, Black Rhino Armory Wheels, Custom Rock Sliders, SDHQ ABS Guards, Warn Winch Bumper, Warn Evo VR 12-S Winch, 4.88 Re-Gear, Rear E-Locker.
    I now have this issue, too. It's only happened when my 4Hi is engaged, and it clears up within an hour. I was having some issues engaging 4wd beforehand, but now it works. However, the flashing 4hi/4lo began today when out on the dirt, randomly.
  23. Jul 23, 2021 at 4:19 AM
    Flash_Outdoors
    Flash_Outdoors New Member
    Jordan
    2019 Tundra 4x4 Sport
    Has anyone found a fix for this? Lights flashed on me a month ago on the way yo work. Stopped and haven’t done it since. Jumped in the truck this morning, threw the truck in reverse, and boom, both lights flashing. They stopped by the time I got out of the neighborhood. Drove 1 mile and they started flashing again. Pulled into the gas station, put it in park and the lights went off. Sitting here idling now, no lights. Truck has 109,700 miles so I’m assuming Toyota will tell me to get bent.
  24. Jul 24, 2021 at 1:33 PM
    Beef
    Beef New Member
    2020 Tundra 4x4 TSS
    After many tries of fixing connections and rerouting wires, the dealership replaced the whole actuator and I've been 4 months blinking light free
  25. Aug 7, 2021 at 6:01 PM
    Beef
    Beef New Member
    2020 Tundra 4x4 TSS
    the post above you did…
  26. Sep 13, 2022 at 11:24 AM
    2015sr5tundra
    2015sr5tundra New Member
    2015 tundrasr5
    Soooooo, I just ran into this thread searching for the same solution to the blinking 4hi and 4lo , did anyone ever change the brake stroke sensor ? Or is it just a myth on weather it fixes the issue or not. My 2015 crewmax sr5 does the same thing and it seems as if it only does it in hot days , not sure what to do and wouldn't want to replace the actuator if it isn't broken.
  27. Sep 13, 2022 at 11:26 AM
    Yoder18
    Mitch
    My 2018 still does it on hot/muggy days upon startup as well as when I go through the car wash. Annoying as hell. They replaced some sensor, I’ll look when I get in the truck and let you know but it still does it regardless. They scratch their heads and just stare at me. Still trying to find a fix for mine too
  28. Sep 13, 2022 at 12:44 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I had this problem when I went wheeling. It turned out to be a loose connector/connection on the front diff ADD unit. Used a zip tie to keep it clamped down.
  29. Sep 14, 2022 at 7:30 AM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder TRD Pro kit +3, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    maybe try checking the abs sensors:monocle:
  30. Nov 18, 2022 at 7:46 PM
    Superbsdad
    Superbsdad New Member
    Josh
    Ohio
    2016 SR5 TRD OR
    I have ran into this same issue. It started after I had my pads and rotors replaced. Is there a sensor that may have been damaged during the brake job?
