Power steering cooler lines?
Discussion in '1st Gen Tundras (2000-2006)' started by HAL69000, Aug 28, 2022.
  1. Aug 28, 2022 at 9:09 PM
    HAL69000
    HAL69000 [OP] New Member
    2004 Double Cab 4WD
    So, did a power steering flush on the interstate today. Anyone know what the part number is for the power steering cooler lines? Mine rusted through (of course).
    Here it is I believe for $275 (wtf) at Advance Auto:
    https://shop.advanceautoparts.com/p...51013-P?searchTerm=power+steering+return+hose
    Here's your now-weekly rusty Tundra gore. What can't duct tape and zip-ties make better?
    Sure am glad I pre-emptively replaced the brake lines in this area on both sides last week. I need a break from stuff breaking.
    edit: think I got the busted line. For others who may find this thread in the future: Edemann 92715 https://www.rockauto.com/en/parts/edelmann,92715,power+steering+return+hose,7324
    Sure would be nice to find whatever line that is below it too though. Rack to Cooler? I guess that would be Gear to Cooler on various parts pages?
  2. Aug 28, 2022 at 10:36 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Confused here as part diagram in 1st pic shows that as 1 hose that makes a loop but the rockauto part shows a bent line but it's a more straight piece. Wrong picture?
  3. Aug 29, 2022 at 6:19 AM
    HAL69000
    2004 Double Cab 4WD
    The loop is the “cooler” and if I recall correctly it is connected to the metal lines I want (circled in red above) by rubber hoses.
    I ordered another set from rockauto that miiiight have what I need, but I’ll take a better look today now that I’m not at a highway gas station.
  4. Aug 29, 2022 at 9:47 AM
    HAL69000
    2004 Double Cab 4WD
    So, uh, the line below the one with the pinhole leak is not connected to anything on either end. It runs to the power steering rack area and is open:
    On the other end, it runs to the power steering cooler loop area and is open.
    There is another line that runs from the rack to the cooler and then from the cooler through the pinholed line to the reservoir. My best guess is that the bottom line had rusted through at some point and was replaced already by a previous owner but they left the original metal run in place.
  5. Sep 1, 2022 at 10:29 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    03 Tundra AC TRD
    Hopefully someone can chime in with the correct part numbers, but it sounds like you're searching in the right direction.
    I would go to PartSouq https://partsouq.com/ and plug in your VIN and it will give you parts diagrams, and numbers.
    HAL69000[OP] likes this.
  6. Sep 1, 2022 at 10:32 AM
    HAL69000
    2004 Double Cab 4WD
    I swapped in the Edemann part yesterday and it was a perfect fit. Haven't checked on the fit of the lower one as I'm sort of fed up with touching the truck for a while and that line is not functional anymore anyway. I don't think these are available from Toyota anymore.
    Now hoping my power steering pump isn't going to go out as a result of the low fluid situation last Sunday. Easy fix but I just don't want to deal with it lol.
  7. Sep 1, 2022 at 11:38 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    03 Tundra AC TRD
    Keep an eye on the fluid level, and listen for any whine and whether or not it gets worse.
  8. Sep 2, 2022 at 6:50 AM
    HAL69000
    2004 Double Cab 4WD
    Oh yeah, for future reference I believe that the "SUNSONG 3402998 Power Steering Return Hose" kit also contains this section, along with the other side of the cooler loop, but not the cooler loop itself. Wish I had noticed that before I used the other one as the whole kit is actually cheaper than the half that is in the Edemann kit.
