Tire pressure light
Discussion in 'Wheels & Tires' started by Local46er, Jul 5, 2017.
  1. Jul 5, 2017 at 4:28 PM
    Local46er
    Local46er [OP] New Member
    Neil
    Ontario Canada
    2016 Tundra SR5 TRD double cab
    Asking for a friend who just bought a tundra. The truck got aftermarket wheels on it and the pressure sensors are not installed nor do he have the original. I see some post on here regarding the wiring and if you cut this or splice that it will work, then some people saying it won't. Without him spending the money to get sensors and tires broken down, is there any other solution that works.
    Thanks.
  2. Jul 5, 2017 at 4:44 PM
    Aurora CO
    Tell your friend to totally ignore the stupid light like I do. I don't even notice it any more. And buy a decent ARB air pressure gauge from ToyTec. . IMHO
    Local46er[OP] and gosolo like this.
  3. Jul 5, 2017 at 4:49 PM
    Local46er
    Neil
    Ontario Canada
    I also do the same thing and don't notice it anymore.
  4. Jul 5, 2017 at 4:54 PM
    Aurora CO
    I've seen folks to try to do the wire bypass not only for TPMS, but also for annoying seat belt chime with decent mod instructions and still find a way to f¥¥k it up causing a worse "real" problem.
  5. Jul 5, 2017 at 5:38 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Throw the tpms's into the spare tire and set it and forget it
    Black Wolf and kenomouth64 like this.
  6. Jul 5, 2017 at 5:59 PM
    Aurora CO
    Great idea if you still have any. If you don't have any I'd check with Discount Tires and get 4 and free programming which they will do. Or ignore the stupid light and use your money to buy flowers and dinner for the kids/wifey.
  7. Jul 5, 2017 at 7:49 PM
    DrasticDelima
    DrasticDelima New Member
    2016 Black Tundra CrewMax 4x4 Heavily Customized
    7" Lift Kit HID Light and LED Tailight Upfit Custom Venom Bumpers TRD Pro Grill Custom Armor Skid Plate LED Flood Lamps (Hideaway) - Front and Integrated Rear Bumper
    The TPMS system is wireless and there are several components to it. Likely the easiest way to fix this would be to grab 4 and sync them to the system then just reset the pressure using the reset switch (See image and steps below) and in theory it should stop complaining (I've never done this so its just a theory). You shouldn't even have to do anything with the existing tires. Here is a breakdown of the system and a few highlights regarding when it works or not. Not sure what year your friends is but this is for the 3rd Gen. Hope it helps!
    Screenshot 2017-07-05 at 20.32.19.jpg Screenshot 2017-07-05 at 20.34.57.jpg Screenshot 2017-07-05 at 20.36.07.jpg
    ColoradoTJ and DVYota like this.
  8. Jul 5, 2017 at 8:11 PM
    Aurora CO
    I actually consided that. @LOTSOFTOYS would be the best bet on that.
  9. Jul 5, 2017 at 9:28 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Here's what I did.
    ColoradoTJ likes this.
