275/65/20 or 275/60/20 on 3rd Gen
Discussion in '3rd Gen Tundras (2022+)' started by Jack Straw, Apr 2, 2022.
  1. Jul 2, 2022 at 2:30 PM
    JC4x4TRD
    JC4x4TRD New Member
    2022 Tundra TRD Sport
    1.75” level with 275/65/20 Cooper Rugged Trek
    I went with the metric cooper, I was between the 275/60 and the 65. Have read plenty of posts and seen videos where people were claiming 17-18mpg on hwy with these and around 14-15 in city driving. Was curious if anyone on here was seeing that. Mine isn’t broken in, only 120 miles on it and the lie-o-meter is showing about 14 with all city driving. I haven’t accounted for the % difference in tire size at that number.
  2. Jul 9, 2022 at 9:02 PM
    Que2
    Que2 New Member
    Georgia
    2022 Tundra Platinum (MGM)
    Tinted Windshield (50%), OEM Black Exhaust Tip, OEM Tonneau cover, 14" Screen Protector, OEM Bed Extender, Binize Box, Center Console Organizer Tray, OEM Bed Mat
    Hi. I am also looking into the Nitto Recon Grappler in 275/65/20 on the stock wheels with no lift or spacers. Has anyone come across any issues with these tires? Noise, rubbing, poor wet traction, etc? I do not seen many reviews or comments on there tires since they are pretty new.
  3. Jul 12, 2022 at 5:25 AM
    JBASS2
    JBASS2 New Member
    After reading through this thread, I think I am going to put on the nitto recon grapplers in a 275/65/20 size.
    I would like to put on the 275/65R20 116T. Nitto list it as a suv/light truck tire. It weighs 47.5 pounds.
    I am concerned that might be a mistake. They also list LT275/65R20 E 126/123S as an suv/light truck tire, but it weighs 58.60 pounds. I prefer keep the tires as light as possible, but I am concerned I might not be getting the right thing.
    Can anyone clear it up for me?
    Thanks
    surfmc likes this.
  4. Jul 12, 2022 at 5:52 AM
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    Best bet is to find the weight rating for the tires you want, and make sure they can handle equal to or more than your OEM tires...
    There are a few websites where you can plug in both and it'll compare them, but can't remember off the top of my head...
  5. Jul 12, 2022 at 6:36 AM
    CarJon
    CarJon New Member
    2022 CrewMax Blueprint Platinum Tundra 4x4 (5.5 ft bed)
    1.75 in front level / Nitto Recon Grappler A/T - 295/60R20 on stock wheels.
    Here is my setup on a 2022 short bed Gen 3 platinum w1.75 in front level / Nitto Recon Grappler A/T - 295/60R20 on stock wheels. When these wear out, 37" coming...
    oxlsu40 and LukeS like this.
  6. Jul 12, 2022 at 6:57 AM
    roti
    roti New Member
    You'll have no issue whatsoever with this size and tire combo. My discount tire says I can go up to a 285 comfortably with no issue. When they were putting the tires on they let me come out and see it at full lock to make sure there was proper clearance before I made the purchase, which was really nice of them. I'm running Nitto ridges in this size and have had 0 problems. Also not sure if you park in a garage but expect an extra 2 inches of lift from the tires so keep that in mind if you have clearance concerns. Expect to take an MPG hit.
  7. Jul 12, 2022 at 7:24 AM
    Troa
    Troa I blue it again.......
    Nomad
    2022 Blueprint Limited
    My computer reads around 16mpg after running around 50/50 city and 70-80mph highway. With the 275/65r20 tires being 5% larger, the real world mpg would be closer to 17
    Cruising at 60 on the freeway on flat ground I definitely still get over 20mpg. I specifically did not get E load tires to help keep ride and mpgs as close to stock as possible though.
    The 116T will have a thinner sidewall and therefor support less weight than the E rated 126/123s tire. Most tires of this size are meant for larger trucks that are rated to carry heavier loads, so they need thicker tires in order to do so. Our trucks being 1/2 tons don't need the additional load capacity so you can run either one. The thicker tire will be heavier which means more energy to spin (less mpg) and stiffer so they tend to have a more firm ride.
    Personally, I stuck with the thinner tire and am super happy I did. I actually bought this size specifically because it was the largest size I could find in stock without stepping up to an E
    jproy12 likes this.
  8. Jul 12, 2022 at 7:32 AM
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    I'm in about the same boat... I wanted 35x12.50r18 and went with the D rated Toyo AT3 over the F rated... No need for that HD of a tire...
    Troa[QUOTED] likes this.
  9. Jul 12, 2022 at 8:24 AM
    nrm91
    nrm91 New Member
    Boise, ID
    2022 Platinum CrewMax Magnetic Grey
    35/11.5/20 Toyo AT III's
    I am deciding between the Toyo A/T IIIs in 35/11.5/R20 after putting in the front leveling kit, or not doing any leveling kit and getting some 285/60/R20 tires (assuming they'd fit) on my stock Platinum wheels? How much "lift" would I get by just upgrading to those tires without any leveling kit?
  10. Jul 12, 2022 at 8:35 AM
    Troa
    Nomad
    Since the stock tires are 32.5 you are increasing the overall diameter by 2.5" if you go to a 35. That means you are lifting the truck by half of that (1.25")
    285/60r20 is 33.5" so you'd gain 0.5" in height over stock
    Taikowaza likes this.
  11. Jul 12, 2022 at 8:38 AM
    nrm91
    nrm91 New Member
    Boise, ID
    Oh duh, that makes sense. Okay, so 35" will be a nice 1.25" lift then, in addition to my 1.75" lift in the front, I think I'll like that.
    DBamaC likes this.
  12. Jul 19, 2022 at 10:39 AM
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    Did you ever get these installed?
  13. Jul 19, 2022 at 12:00 PM
    JBASS2
    JBASS2 New Member
    TRD sport edition.
    No, and it is a bit of a long story. The dealer did not want to do the 275/65/r20, and they explained to me that there would be zero warranty issues if I went with what they could get approved for toyota specs. I went back and forth for days, and everntually it made sense to me not to take a chance in compromising any part of the warranty.
    I went with Bridgestone Revo A/T3 that was a P275/60/R20 and a 1.75 inch front level. It weighed only 4 pounds more (41 pounds) than what came on from the factory, and it is 4/10 of an inch bigger in diameter. Here is the only pic i have right now. The tires are being reversed so its all black on the outside. One day i might go a size larger, but for right now this should take care of everything I will do with it.
    TDUBS and benca1 like this.
  14. Jul 20, 2022 at 9:24 AM
    Will816
    Will816 New Member
    Will
    Idaho
    2022 Limited iForce Max TRD Off Road
    They were okay with the level but not 275/65R20 tires? Seems odd...
    Slimdusty and Henry1jg like this.
  15. Jul 20, 2022 at 10:00 AM
    bcj001
    bcj001 New Member
    Brad
    Oregon
    22' Tundra Limited
    running non metric version... 35x11.5R20 Recon Grapplers on the factory TRD wheels, with mudflaps... zero rubbing issues, very quiet, no traction concerns that I have noticed... =) Overall I would do it again, and have zero regrets... I found the "non metric" versions to be cheaper at the time as well...
  16. Jul 20, 2022 at 10:04 AM
    nrm91
    nrm91 New Member
    Boise, ID
    Any reason you chose these tires? I am considering them and the Toyo A/T IIIs
  17. Jul 20, 2022 at 10:24 AM
    bcj001
    bcj001 New Member
    Brad
    Oregon
    22' Tundra Limited
    Honestly, I was looking at the Coopers, Toyo, and Nitto's... It really came down to price, and "look"... I found the Nitto's for under $400/ tire + install.. couldn't get close to that on the others... not sure if I caught a sale at discount tire, but they were ~$1630 out the door (end of April)
  18. Jul 20, 2022 at 10:29 AM
    nrm91
    nrm91 New Member
    Boise, ID
    Yeah that makes sense. Looks like I can get the Nitto Recons for $1747, or Toyos for $1760 so it's negligible
  19. Jul 20, 2022 at 12:11 PM
    Troa
    Nomad
    Henry1jg likes this.
  20. Jul 20, 2022 at 12:58 PM
    #50
    nrm91
    nrm91 New Member
    Boise, ID
    How are those? The only knock I have I guess is the size isn't as big as what I was hoping for. But maybe with the front leveling kit and these, the "lift" would be enough?
  21. Jul 20, 2022 at 3:18 PM
    #51
    Troa
    Nomad
    If you check out my build thread in my signature you can see them on my truck.
    I love them! Really fill out the wheel wells without sacrificing ride quality or much MPG
  22. Jul 20, 2022 at 6:26 PM
    #52
    benca1
    benca1 New Member
    one thing to note to everyone running these tires such as a 35x11.50 or 295/65/20 or equivalents is the stock wheels are 20x8 on platinum, limited , 1794 but the black TRD 6 spoke wheels are 8.5"
    did u level yours? You have pics with tires but before level/lift?
  23. Jul 21, 2022 at 4:41 AM
    #53
    Troa
    Nomad
    I haven't touched the suspension yet. You can find pics in my build thread. Link in my sig
    benca1[QUOTED] likes this.
  24. Jul 29, 2022 at 8:50 PM
    #54
    ELiDirtTundra
    ELiDirtTundra New Member
    WA
    2022 Tundra Limited
  25. Sep 6, 2022 at 3:56 PM
    #55
    crowdedstr
    crowdedstr New Member
    Northern WI
    Do you have any updated side view photos of your truck? I'm scheduled to get 275/60/20 with a 2" level. Similarly, the dealer told me anything bigger would not fit (which is obviously not true) but also a little worried the 2" level might be too much esp with smaller tires than I'd planned.
    Do you wish you'd done anything differently?
    Thanks!!
  26. Sep 6, 2022 at 4:02 PM
    #56
    crowdedstr
    Northern WI
    any chance you have a full side view of this?
  27. Sep 6, 2022 at 5:09 PM
    #57
    benca1
    benca1 New Member
    275/60/20 will look way to small with any sort of lift or level. I have 295/60/20 on stock suspension
  28. Sep 6, 2022 at 8:52 PM
    #58
    crowdedstr
    Northern WI
    thanks for the feedback, sort of what I figured. They ordered the tires already but I’ll probably let them know it was based on their bad advice and see if they’ll let me switch to something bigger.
    If you have a chance can you post a pic of yours? I’ve seen the black one on here similarly configured.
  29. Sep 7, 2022 at 3:17 AM
    #59
    benca1
    benca1 New Member
  30. Sep 8, 2022 at 7:42 AM
    #60
    JBASS2
    JBASS2 New Member
    I do have pictures, and i would not do anything different. I personally don't think they look too small. If my math is correct, the 295/60 is 12 millimeters taller than the 275/60.
    There is an independent shop that does all the leveling for 2 local toyota dealers. They put a 1.75 on the front of almost 30 tundras a month, and they recommended not doing anything other than that. I went with it, and I have no regrets. I think a 2 would have been too much, but I think what would have really happened is they would have done 3 in the front and 1 in the back.
    I average 18mpg with a little bit of hwy driving. 80 percent is in the city.
