Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Jun 22, 2022 at 10:48 AM
    #2791
    Wahayes
    Will
    2017 tundra limited
    Anyone know the details on what's going on with these fenders?? They look sick I want specifics lol
  2. Jun 30, 2022 at 3:30 AM
    #2792
    charge556
    charge556 New Member
    2017 Inferno 4x4
    From factory TRD off road package with 275/65/r18 TRD wheels;
    Stock suspension??any rub etc??
  3. Jun 30, 2022 at 6:53 PM
    #2793
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    Only if you don't want to turn.
  4. Jun 30, 2022 at 8:27 PM
    #2794
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  5. Jun 30, 2022 at 10:04 PM
    #2795
    COTundra23
    COTundra23 New Member
    what wheels are those?
    TFTundra[QUOTED] likes this.
  6. Jul 1, 2022 at 3:23 PM
    #2796
    omer318
    omer318 New Member
    Monroe, LA
    2021 Tundra Crewmax 4WD
    trd front sway bar - trd rear sway bar - trd dual exhaust - trd smoked led headlights - amp research steps - jl stealthbox (two 10" subs) - 17” icon rebounds - 285/75r17 nitto rg’s
    285/75r17 (33.86”) ridge grapplers on 17” icon rebounds, running fox 2.0s for 2” level in front
  7. Jul 2, 2022 at 12:53 PM
    #2797
    TFTundra
    TFTundra New Member
    Method 316
    COTundra23[QUOTED] likes this.
  8. Jul 3, 2022 at 7:39 PM
    #2798
    Skoden
    Skoden New Member
    Jared
    Manitoba Canada
    20 sport premium cm black
    Bilstein 5100’s top setting up front. 1” block in the back. Slight rub on stabilizer bar passenger side at full turn.
  9. Jul 5, 2022 at 2:28 PM
    #2799
    silverbackC
    silverbackC New Member
    Jeff
    2022 Solar Octane Tundra TRD Pro
    In transit : N-Fab rock rail/step and LEER 100XR Cap
    Does anyone know if the Yokohama geolandar M/T 295/70R18 will fit on the stock 2022 TRD pro with or without trimming?
  10. Jul 6, 2022 at 6:18 AM
    #2800
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    For what it's worth, I have a 1794 with the TRD Pro Fox suspension and Cooper Discoverer XLT AT3 295/70 R18s. To eliminate the rubbing, I had to flatten/shape the front most inner liner area with a heat gun/small dead blow hammer and also the mud flaps. I also removed the front small flap and trimmed the "ears" off the stock skid plate. Since then I've replaced with a TRD skid plate, which wouldn't have rubbed or needed trimming. I also have had both 1.25" and now have 1" BORA wheels spacers, so my rubbing might have been a little worse vs. running without spacers. Best.
  11. Jul 6, 2022 at 7:05 AM
    #2801
    king.cong.1119
    king.cong.1119 New Member
    https://iconvehicledynamics.com/wheel/10645/icon-alloys-rebound/1817855557TT/?finishID=1358
    above link is the 17inch wheels ICON rebound. I'd also suggest maybe looking at the rebound pro, one of my buddy has this on his land cruiser and it looks nice.
    For my tundra, I have the icon rebound the exact wheel/tire combo you mentioned and I have not had any problems off-road, on-road, fitment is perfect because I know ICON specifically designed this spec for our tundras.
  12. Jul 6, 2022 at 8:05 AM
    #2802
    silverbackC
    Jeff
    Thanks for the response, I also had a 2016 Tundra TRD pro and the 295s fit with no rubbing after removing the front flaps. The newer tundras seem to have more room since I’m seeing a lot of people running 37s on their builds but I think the trd pro lift is only 1” and when you do the trd suspension on the other models you get a 2.5” lift - correct me if I’m wrong.
    Badknees[QUOTED] likes this.
  13. Jul 6, 2022 at 8:18 AM
    #2803
    Badknees
    Badknees New Member
    I got right at 2" of lift with the TRD Pro front coil-overs. I added CB 0.25" shims to get 2.5" total lift, but did all the rubbing mods before I added the extra 0.5" of lift. I like the looks of 35" OD tires, but didn't want to do any body mount cuts or major mod. stuff to make them fit. 34" OD tires are pretty easy to make fit I think.
    Edit: I've never read anything on this site to make me think the 2020 TRD Pro lifts are 1". I think the Pros provide about 2" over stock, but I'm not the expert on this.
    silverbackC[QUOTED] likes this.
  14. Jul 10, 2022 at 9:07 PM
    #2804
    Salsaverda16'
    Salsaverda16' New Member
    Gaervyn
    2016 Black Tundra 4x4
    @Gobstopper front bilstien 5100 on second clip (1.9”) and 5100 rear shock (stock height). Sorry for the 7 month delay
  15. Jul 10, 2022 at 9:12 PM
    #2805
    silverbackC
    Jeff
    I just ordered the westcott designs preloaded collar lift kit for the 22 trd pro fox suspension, 1.) anyone have experience with it?
    2.) They mention using the oem wheels with 37” tires but I’m not see any 37’s that will fit these wheels? Am I missing something?
  16. Jul 11, 2022 at 8:14 AM
    #2806
    1Tundra5
    1Tundra5 New Member
    Junior
    2015 White SR5
    • P255/70R18 Michelin tires
    • P275/65R18 Michelin tireS
    • I don’t know much of tire sizes so bare with me. I believe that the tire p275 comes standard from the factory, and I see 255 is an option; which will more likely be better than the other one as far as traction and maybe Gas
  17. Jul 20, 2022 at 6:33 PM
    #2807
    Uturn09
    Uturn09 New Member
    Roscoe
    2017 Grey Tundra SR5 TRD
    None to day....that’s why I’m here.
    Old setup: stock everything either 275/70r18 cooper discover xlt (no rubbing)
    6112 at 1.9”, vision 17x9 12mm offset with 315/70r17 Cooper discover xlt (plastic removed, no bmc or skid altering needed)
  18. Jul 21, 2022 at 6:09 AM
    #2808
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, 6112/5160, MR 701's, TOYO R/T Trails 285/75/17
    Very nice. I wonder if they'll fit with 0 offset?
  19. Jul 21, 2022 at 6:17 AM
    #2809
    Uturn09
    Uturn09 New Member
    Roscoe
    I don’t see why not
  20. Jul 28, 2022 at 11:13 AM
    #2810
    king.cong.1119
    Some more wheels/tires shots from a trip this past weekend.
    Photo Jul 27, 9 52 23 AM.jpg Photo Jul 24, 3 50 16 PM.jpg Photo Jul 24, 1 00 30 PM.jpg
  21. Jul 28, 2022 at 1:57 PM
    #2811
    Millwood21
    Millwood21 New Member
    Jade
    2017 Platinum
    Just finished this up yesterday.
    37x13.5 bfg km3
    Scs sr8 18” +25 offset
  22. Jul 28, 2022 at 2:24 PM
    #2812
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Massive.
  23. Jul 28, 2022 at 2:35 PM
    #2813
    Uturn09
    Uturn09 New Member
    Roscoe
    That’s what she said!
    Millwood21 and FISHN43[QUOTED] like this.
  24. Jul 28, 2022 at 6:57 PM
    #2814
    Retroboy1989
    Northern Utah
    2012 DC 4x4 5.7 SR5 TRD OR Barcelona
    Snug top 20" TRD Sport wheels 275/60R20 Tires Additional Trans Cooler
    Looks like you got featured.
  25. Jul 29, 2022 at 11:34 AM
    #2815
    Retroboy1989
    Northern Utah
    TRD OR wheels
    275/70r18 Michelin AT2s
    No lift, no spacers
    Tundra Dude 45 likes this.
  26. Jul 29, 2022 at 11:42 AM
    #2816
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    17x8.5 RRW 7-H in matte bronze wrapped in 37x12.50 Mickey T Baja Boss M/T
  27. Aug 1, 2022 at 8:03 AM
    #2817
    dchansen
    dchansen New Member
    Dale
    2017 Tundra Platinum
    3/1 SST Leveling Kit and Roadmaster Active Suspension XD778 MONSTER 18x9 wheels with +18mm offset and Falken WILDPEAK A/T3W 275/65R18 tires
    New member here. I've had my 2017 for 5+ years and I finally decided to upgrade the wheels/ tires/ suspension. After getting some great advice from this forum, here is what I installed:
    • 3/1 SST Leveling Kit
    • Roadmaster Active Suspension enhancement on rear leaf springs
    • XD778 MONSTER 18x9 wheels with +18mm offset
    • Falken WILDPEAK A/T3W 275/65R18 tires
    Did everything myself (with some help from my son-in-law)...the front leveling kit install was a major PIA! Followed online tutorials, but man, I was regretting my decision about 4 hours in.
    I am really happy with how it turned out! The front wheels rubbed slightly when backing up and turning, so I ended up removing the small mud flap on the front end of the wheel well.
    What did y'all do with your OEM wheels/ tires? Is there a market for selling them?
    Cheers!
    NueveTundra likes this.
  28. Aug 1, 2022 at 12:35 PM
    #2818
    Lambeau
    Lambeau New Member
    2019 Black Tundra Platinum 4x4
    XP Package, 20” Rockstar, 295/60/R20 Nitto G2, Line-X Bedliner, Undercover Elite LX Tonneau Cover, Remote Start, NSV Hood Bulge Light Bar, Predator Running Boards, TacoTunes SQ1 Sound System, Toytec Boss front coilovers, Toytec Boss rear shocks, Coachbuilder +2 rear shackles
    So I was involved in a hit and run that damaged the front passenger wheel and tire. The jerk slammed into me and drove off. It was XD Rockstar 50mm offset. It was discontinued so no replacement available. Same with the Nitto tire. Picked up these Fuel Sledge wheels 20mm offset with Nitto Recon Grapplers 295/60/20.
    The 20mm offset is perfect. The pictures show how they fit both with the fender flare and without. The fender flare is on back order so waiting for the shop to get it in. Just thought it was a good time to show the comparison with fender flares.
  29. Aug 3, 2022 at 6:18 AM
    #2819
    DocHusker
    DocHusker New Member
    2020 White TRD Pro
    Please forgive my dumb newbie question. From what I understand my 2020 TRD Pro already has a 2” lift from the factory. I’d like to upgrade to an 11-12” wide 35” tire. Do I need to be considering any more lift? My plans for the truck are mainly Overlanding BLM and forestry roads pulling my tent trailer. I don’t envision any major rock crawling.
    Thanks.
  30. Aug 3, 2022 at 7:02 AM
    #2820
    Uturn09
    Uturn09 New Member
    Roscoe
    You will have to get bumper spacers or remove plastic fender liner in front of the wheel and the mud flap behind the wheel. Also will need rims or spacers that are 25mm or less to clear UCA’s.
