PCV Valve Replacement Instructions-4.7L
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, Jan 14, 2019.
  1. May 30, 2022 at 2:36 AM
    #61
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    The foam cover appears to be:
    Toyota 12236-50010
    Cover, Ventilation Valve
    DarkMint likes this.
  2. May 30, 2022 at 4:40 AM
    #62
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The FSM for our 04 calls for 20ftlb and rotate as shown below !
  3. Jun 18, 2022 at 7:50 PM
    #63
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Found the foam cover thanks to @w666
    The PCV hoses differ between V8 and V6. Had to do some digging to ensure I got the V8 hose and not the V6.
    For the record, part numbers for a new V8 PCV hose, hose clamps, and foam cover:
    Pnwtundy and shifty` like this.
  4. Jun 19, 2022 at 8:03 AM
    #64
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    I had a feeling that grommet would be a PIA. Had a new PCV installed, the grommet leaks like crazy. Crikey.
  5. Jun 19, 2022 at 8:22 AM
    #65
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    So let's suppose you find a valve cover from a later generation truck that threads in. Could you just swap valve covers to be rid of the grommet?
  6. Jun 19, 2022 at 11:41 AM
    #66
    shifty` Our private little trip to hell
    I don't see why you couldn't if everything lines up.
    Another member on here - @txagg ? - went through the "generational valve cover" swap, I think? I'll see if I can dig and find that. It was someone within the last 6 months, around the same time I did my gaskets. If I can find in the next 3-5 mins I'll update this reply.
  7. Oct 18, 2022 at 4:15 PM
    #67
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    2006 threaded...gunked up but still sounded good. Quick and easy. Let it warm up to go get beer and still a little tough to get loose. Foam was crumbly too but able to put back on.
    Sorry, phone decided to focus on the gloved hand...you get the point. Having issues with it connecting to laptop, looked a little more clear on the handheld computer.
    richsadams, FrenchToasty and shifty` like this.
  8. Mar 2, 2023 at 12:04 PM
    #68
    suley
    suley New Member
    Suleman
    2002 Sequoia Limited 2WD
    Hello Everyone!
    I am new here and would like to ask if there are two PCV valves on the 4.7 V8. I see the one which is being discussed but there seems to be another one on the other bank on a 2002 engine which looks like the threaded valve. Any ideas?
    Thanks!
  9. Mar 2, 2023 at 12:12 PM
    #69
    There's only one on my 4.7, on the driver's side. I've got the VVTi 4.7 that's in the '05-'06. Can you snap a pic of the PCV you're looking at on your truck's 4.7?
    Hi06silver likes this.
  10. Mar 2, 2023 at 12:30 PM
    #70
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    T150 Lover
    richsadams likes this.
  11. Mar 2, 2023 at 1:17 PM
    #71
    Do you know if it's actually valved, or is it just a vent?
  12. Mar 2, 2023 at 1:21 PM
    #72
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    T150 Lover
    On my 04, just a vent thru that 90 deg fitting. Not sure why Toyota Engs felt driver side needed an actual PCV unless it was there way thru throttle body to intake :notsure:
    shifty`[QUOTED] likes this.
  13. Mar 2, 2023 at 2:06 PM
    #73
    Yeah, dunno. I guess I just glanced over it when I did all my gaskets. Mine has it too. Huh. But I'm 90% positive it was just a crankcase vent, not a valve.
  14. Feb 3, 2024 at 8:38 PM
    #74
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Replaced mine today.
    Pretty tight but do-able.
    After removing the hose, I was able to get the closed-end of a 7/8" wrench over the old one to remove it.
    Didn't look bad, but since I already bought a new one & it was cheap, I swapped 'em.
    It's gotta be my imagination . . . but the truck seems to run a tad better . . . felt a little 'crisper', but I can't see how that could be.
  15. Feb 10, 2024 at 1:41 PM
    #75
    bfunke
    bfunke Tundra Curmudgeon
    I don’t recall seeing any schedule to replace on our trucks but back in the day most maufacturers recommended replacement at 30K IIRC.
