Rear charging and connectivity for passengers??
Discussion in '3rd Gen Tundras (2022+)' started by Henry2019, Mar 21, 2022.
  1. Mar 21, 2022 at 8:41 PM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60/R20 Falken Wildpeak A/T3W
    Anyone found a way on how to add charging and connectivity to the rear of the center console for passengers yet?? Pretty damn sad that it’s not something standard on SR5 or Limited trims for a truck in the year of 2022..
  2. Mar 21, 2022 at 10:14 PM
    Shadowfax1
    Shadowfax1 New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    There’s a couple threads in the 2.5 gen forum for this. I don’t know how much the 3rd gen changed the center console, but it isn’t terribly difficult in the 2.5s. I think I’m shocked…beyond shocked…they didn’t fix this shit in the 3rd gen/2022s. Seriously absurd.
    Acedude and LarryDangerfield like this.
  3. Mar 21, 2022 at 10:25 PM
    Troyboy84
    Troyboy84 New Member
    BC Canada
    2022 SR5 TRD Offroad
    i haven’t figured it out yet, but I did manage to open it up, there is some wiring in there, just not sure whether it’s for the usb or the AC120V and where to get the oem parts
    Henry2019[QUOTED][OP] likes this.
  4. Mar 21, 2022 at 10:27 PM
    Troyboy84
    BC Canada
    A4D08462-1E71-4452-B134-17AD72A8AA86.jpg A1DB639C-E639-48FA-9AFC-351CA4D73752.jpg 7AD6348A-AC0C-45C8-A8D8-C2EE20D82F91.jpg
  5. Mar 21, 2022 at 10:57 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Odd that it has 3 leads.
    Might be a switch plug for an accessory.
    Bust that DMM out and get to testing..:D
    The middle one is ground.
    What are the other 2, ACC, BAT, or nothing?
    Medic343 and Henry2019[OP] like this.
  6. Mar 22, 2022 at 12:12 AM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    couldn’t have been said it any better!
    Shadowfax1[QUOTED] likes this.
  7. Mar 22, 2022 at 12:14 AM
    Henry2019
    Henry2019 [OP] N/A
    Houston, Texas
    It would be nice if it’s already pre wired and all you need is the USB port or 120v outlet!
  8. Mar 22, 2022 at 3:48 AM
    AustinTexas
    AustinTexas New Member
    My limited does have ports in the rear
    1 USB. and 1 USB-c
    Not sure how its wired, I wonder if you tie into the wiring for the charger inside the center arm rest.
  9. Mar 22, 2022 at 8:08 AM
    TundraTun
    TundraTun New Member
    looks like that’s possible…I’m going to look at my SR5
  10. Mar 22, 2022 at 8:08 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Is there still a USB port in the console on the 2022?
    You could tap into that circuit and power some USB plugs in the rear..
    Or even a 12volt plug in the dash if they still have them.
    Many on Amazon of different sizes and configurations.
  11. Mar 22, 2022 at 8:11 AM
    Troyboy84
    BC Canada
    sorry, no context for my pictures, mine is a SR5 off road, Canadian truck. I’m hoping to be able to get oem ports and plug and play. I think this picture is from a limited F02431AF-484E-46FD-9C06-72E357B9D29E.jpg
  12. Mar 22, 2022 at 8:42 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    I’ve pulled apart the rear of console. Pretty easy. Just pull up on rear cup holder and the rear panel just pull back. All held on by clips.
    I wanted to see if there is the harness there for the USB plug but there is none unfortunately for us SR5 owners. I just have the 400W plug.
    I did find the part number for the USB ports and connector part number. Also the wiring diagram for it. Possible a small project I may do later. It just splices into the harness of the USB port inside the console with 2 wires.
    No. 2 USB Charger Socket is the rear USB port.
    Connector plug for the USB charger part#. Terminal 1 is power, terminal 2 is ground.
    Wire part# that plug into the connector to create a little pigtail connector.
    Then just got to splice into the harness of the USB port inside the console.
  13. Mar 22, 2022 at 11:14 AM
    Tumbler
    Tumbler New Member
    2023 CrewMax Limited HV in MGM
    Add one more thing to the list of items that got deleted from the previous gen 2.5. My 2020 had way more content for less money. To bad it was stolen. :(
  14. Apr 22, 2022 at 3:44 PM
    Buellride
    Buellride New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    So did you ever get around to doing this? Curious because it is something I am considering as well.
    Medic343 likes this.
  15. Apr 22, 2022 at 6:24 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    No. Haven't done it yet as I don't really need it yet. More of a want, so will be a future project. Currently waiting for my wheels and suspension stuff to do first.
    It looks real simple to me since I'm pretty good with wiring and I have access to the instruction on how to take apart the console to do it.
    Buellride[QUOTED] likes this.
  16. May 7, 2022 at 8:36 AM
    Rtn2022
    Rtn2022 New Member
    I purchased the 120v/100w plug and it goes right into the plug 1lowlife plugged in. It doesn’t power on. I was wondering if I need to get the switch installed in the dash along with an additional fuse? From what I can gather this far I need the 80 amp INV fuse?
    I got an SR5 Cremax with the Sr5 premium package.
    I just want the 100 watts to work so I don’t have to run usb cables from the front to the back for the kids games. Traded in a gladiator and the abundance of plugs is the main thing I miss at the moment.
  17. May 8, 2022 at 1:04 PM
    newdles
    newdles New Member
    brandon
    Red 2022 tundra
    My wife has a 21 telluride with third row. Each seat has a USB port accessible at a short reach on the seat in front of them. This would be nice on the tundra but since it’s the kids and not me, I don’t sweat it much :)
    bulldog93 likes this.
  18. May 8, 2022 at 1:11 PM
    Rtn2022
    Rtn2022 New Member
    It’s not really an issue, if I would have cared too much more I could have held out for an allocation. I just got lucky and got one pretty much same day I decided I wanted one. The main reason for the trade was to tow and longer trips. Plus running a long cable to the back is not that hard lol i was mostly hoping for an easy add lol
  19. May 8, 2022 at 1:16 PM
    xc_tc
    xc_tc New Member
    You need an inverter to convert 12V DC to 120V AC. Definitely wouldn’t be included in the wiring.
    X42069, FI460 and 22PlatWCP like this.
  20. May 17, 2022 at 6:46 PM
    WildBillThe2nd
    WildBillThe2nd New Member
    2022 Tundra, SR5, TRD-OR, Advanced Tech
  21. May 17, 2022 at 7:03 PM
    Laffingas
    Laffingas New Member
    '22 Tundra Limited - Army Green
    I’m not sure if it was standard or an option, but this is in the backseat of my Limited.
    N_Crawler likes this.
  22. May 17, 2022 at 7:27 PM
    WildBillThe2nd
    The limited has 5 USB ports total, 3 up front and 2 in the rear. SR5 only has the 3 up front.
    So I'm trying to figure out how to mount some in back without spending $175 at the Toyota parts department.
  23. May 18, 2022 at 2:48 PM
    WildBillThe2nd
    It looks like all of those Amazon USB assemblies are 32x22mm. The Tundra needs 44x22mm.
    I guess I should have gone looking online for the 85532-08040 assembly. You can get them on ebay for $20.
    Get the 90980-12D25 connector and the 82998-24290 wire and you are all set.
    I just need to do exactly like it's spelled out in post 12.
    For everything it was $60 shipped.
  24. May 23, 2022 at 4:25 PM
    MRQZTNDR93
    MRQZTNDR93 New Member
    San Diego CA
    2022 TUNDRA SR5 TRD OFF ROAD
    is there a relay or fuse we need to add up front ?
  25. May 24, 2022 at 10:36 AM
    Buellride
    Olympia
    THE BOULDER
    I just got the connector reference in the diagram above....question I have is: " Is that light grey cover on the connector something that needs to come off before installing into the aux jack?"
  26. May 24, 2022 at 4:37 PM
    ByeF150HelloTundra
    ByeF150HelloTundra New Member
    DFW
    2022 Tundra SR5
    My cheap solution. Wired straight to the battery and apparently good for up to 500W. 0292B2F7-1162-45C6-9829-9A1316F2A61E.jpg
    Acedude likes this.
  27. May 24, 2022 at 4:52 PM
    Buellride
    Olympia
    THE BOULDER
    Answering my own post.....the gray cover is the lock for the wire and connector once installed
  28. May 27, 2022 at 12:07 PM
    Buellride
    Olympia
    THE BOULDER
    OK, crap ton of photos here, my apologies in advance but I wanted to be exact with the installation.
    If you are wondering what the part numbers are, they are above in the thread already.
    Pic 1: About to remove the back part of the center console
    ZwJTVNPGdTtf2Y-VP7pDw0WWXFp4thR9f99a1GjM_13e9d5c6dcd51c984baabc6178653377f08ee27a.jpg
    Pic 2: Super easy to pop all the clips, especially if you have trim tool set
    50EeymWe_0UGnCc6NZydqxQPFrVKX2bQZ6-7tLiU_b0f18dd9a15bb623f6723e46d1c8c19e8f8513ec.jpg
    Pic 3: Console rear disassembled
    pLT1Ua-F3x-4p5rtkwhLjxitACR2weDfiHJr1UTT_96fba26387fb6060612c3d3e171d695bd7d47649.jpg
    Pic 4-6: Remove the side panels and toggle switch bar. There is a YT video for how to do this https://youtu.be/YIQKJ8wqjmw It is pretty good.
    aUl2vh9VZso4NbjBL79Q5bx9y-ZZznj78utd6RHj_70a6a6f06eb6c61eeedc9c9d40bd96b3000aeb8a.jpg
    WA_ItYN2QE3C6qrJ5dP3IhpUJv8NTDTvYjB0JVHi_3010a4b58c9bbb82ff6ba25e75ad3285d9105926.jpg
    9DUMKpNvHzMQIU6x9Wwm0983JJqEFzgGo67ApAdm_e968d32eba77938ce4d0b998a3a7aad04de34c92.jpg
    Pic 7: Removal of the shifter knob...what a pain in the arse...the "cotter pin" is alot further in the knob assembly that you think
    YTlcxl3Ur0SLGnRHsJWki8y5HKfV6Bv3wIseNYLu_b093507aca22f7b0ebcef5539165ff09b7250125.jpg
    Pic 8: Removal of the center console primary panel. There is no real need to disconnect the wires under this panel (you do for the toggle switches).
    sWq2TjBxYBeXcN02df8tU1PWfVC4J4-MRmgmRu5W_2c324f63fb256f0fe1209800fdae52e592e2295b.jpg
    Pic 9-11: USB port unplugged (the one inside of the center console)
    yJoXRWRJzInwdZVle1zuDs1TUGuhPveRkxNsd6sk_d6dad6a034a3693be9732a77aa9940a6692d935b.jpg
    Wire taps applied (I think they are the 14 AWG or 20 AWG connectors). The green stripped wire is the "hot"/power wire.
    _yO-dy3auI9dq4hucX5v955VO75gCqUMCwhbY0F3_9fafaff0a309887cfadf69fa90cf1586c5734081.jpg
    New USB plug wires connected and tested before "fishing" to the back of the console.
    XQ4lbLJashwVPTAegpANt5UWYhdponixr96LYXoD_7c23aebb9d0c14ec69fd38429e9a1538c3640825.jpg
    Pic 12: Wires fished through to the back of the console, connected to the OEM plug and wires ($15 total) that I purchased from Ebay and the wire connector I purchased from the dealer ($3.50)
    wpD2FdxG-0du-PJRVy1Nz9OvY6AeeLO_KmVB1pMi_47ef2845855063a20c91ee36f45531997526bc6f.jpg
    Pic 13-14: Rear connected and put back together
    usB8GT3X1DBVbmPlkisOAVV0Idb495y9YJ5Xcc1W_79fd815ad83d151b118bcd08ead3d6fa06d809a0.jpg
    x4yyx9sssWU_h0IlO9_Xcsa5cK1tBoPIyW5-S3Py_766b3224985452b34e72473fb10c959afeafd95b.jpg
    Since I had the entire center console disconnected, etc. I took the opportunity to more properly route my wireless charging pad through the center console vice having the cable "shoe-horned" between the access panels. Drilled a very small horizontal entry port into the inside of the center console to run the connector to the USB plug.
    oY3zoEceW84M-AgG_BXZjBwwokJ3BxufTfN-SHs0_a74f542259ceda95b93a7561970f92e08d01ac36.jpg
    Hope all these pics are helpful for those that want to route a USB plug to the rear of the vehicle. Works like a charm, only cost me about $25 in parts and some soldering/shrink tubing, etc.
    AC_IN_IT, Henry1jg, mayan and 17 others like this.
  29. May 27, 2022 at 1:04 PM
    TSS Army Green
    TSS Army Green New Member
    Do you have the part number for the OEM plug and wire that is mention in pic 12?
  30. May 27, 2022 at 1:18 PM
    Buellride
    Olympia
    THE BOULDER
    Killing me....I mentioned that the part numbers are all in this thread.....but because it is Friday before Memorial Day (and I am a vet), the part numbers are on Post #12 AND 23
    vegask, Eric_1980, 1lowlife and 3 others like this.
