2022 Tundra Fuse Box Locations & Designations
Discussion in '3rd Gen Tundras (2022+)' started by rizico, Apr 5, 2022.
  1. Apr 5, 2022 at 4:40 PM
    rizico
    rizico [OP] New Member
    Johnny-Don
    Luling, Tx
    '22 Capstone 4x4
    Was way too much trouble finding this info, so hopefully this helps someone down the line.
  2. Apr 21, 2022 at 6:51 PM
    whiskey_woo
    whiskey_woo New Member
    Any idea where the fog light relay is?
  3. May 24, 2022 at 9:16 AM
    montera.built
    montera.built New Member
    Jordan
    2022 AG Toyota Tundra TRD Offroad
    Sorry to revive this thread but I also have the same question. Any idea what amp fuse the fog lights run off?
  4. May 24, 2022 at 10:25 AM
    99ways2die
    99ways2die New Member
    Speaking of wiring:
    Does any one know which fuse or wire to tap in order to get a light bar to come on with HIGH BEAMS?
    -99
  5. Jul 29, 2022 at 3:40 PM
    KroppDuster
    KroppDuster Out with the old and in with the...older?
    Here. There. Everywhere.
    Just posting to say say thanks! I'm at working but planning on my Trigger 6-Shooter install as my weekend project. I don't have my truck with me so this is helping me plan out where I might look to run my fuse tap. Time to get the test light out and figure out switched sources under the hood.
    I appreciate it!
  6. Jul 29, 2022 at 7:54 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Do you have premium headlights or regular? If premium search here for canbus- it’s a bit of a headache to dial in.
    My platinum under hood fuses ALL stay on 12v all the time, have tried an add a fuse on all of them for my Baja design lights running lights and they stay on even when the trucks shut off
  7. Jul 31, 2022 at 6:17 PM
    99ways2die
    ...looks like I'm not the one who should do some searching.
    ( i should have updated this thread as well; lost track)
    Take a look here; maybe this will help you out:
    https://www.tundras.com/threads/how...i-low-parking-headlights.110264/#post-2845762
    -99
    DexterL[QUOTED] likes this.
  8. Oct 8, 2022 at 7:50 AM
    plhinds
    plhinds New Member
    PAUL
    22 Trindra 1794
    I have the hybrid model. The location 1 shows a sub batt fuse. When I open the compartment it shows same diagram on bottom of the cover. However the entire column with 6 fuses containing the sun batt does not exist? I can’t find the fuse for the sub batt which is the 12v charging supply to trailer?
    firehawk003 likes this.
  9. Nov 4, 2022 at 7:29 PM
    bongbong
    bongbong New Member
    2023 Tundra Limited
    How did you remove the 3rd fusebox location? I remove a tab at the bottom but scared to yank it out as it could break some tabs.
    Never it was at the bottom, thought it was on the side.
  10. Nov 11, 2022 at 4:02 PM
    Manhusar08
    Manhusar08 New Member
    Manh
    2022 tundra platium
    Here are photos how to access the third fuse box and I included photos to a constant power fuse I use for my 24hr parking motion dash cam.
    Dalunar likes this.
  11. Nov 11, 2022 at 6:12 PM
    bongbong
    bongbong New Member
    2023 Tundra Limited
    Very nice, just make sure you have the fuse facing right way (rookie mistake in my days).
    TheGreenGoblin likes this.
  12. Nov 12, 2022 at 3:19 AM
    Manhusar08
    Manh
    2022 tundra platium
    oh right! thanks for the heads up.
  13. Nov 12, 2022 at 7:55 AM
    DexterL
    DexterL New Member
    passenger side? Do the hybrids have this fuse location? Haven’t even looked!
  14. Nov 12, 2022 at 8:21 AM
    Manhusar08
    Manh
    2022 tundra platium
    yes! It’s on the passenger side. I don’t know about the hybrid set up.
  15. Dec 7, 2022 at 2:54 PM
    nimblesartorius
    nimblesartorius Scruffy looking nerf herder
    2022 Limited OR in blueprint
    Interestingly enough my 2022 Limited Non hybrid does not have a third fuse box. Trying to figure out where I can tout either a t tap or fuse tap for my backlight dimming on switch pros. The two under hood fuse boxes don’t have anything that I can tell would be dimming, and like I said I can’t find a third fuse box.
  16. Dec 12, 2022 at 12:53 AM
    Tundra009
    Tundra009 New Member
    Concord, CA
    Did you figure out which fuse it is? I'm hooking up my 8 gang Auxbeam and need that for back lighting also.
  17. Dec 12, 2022 at 1:32 AM
    nimblesartorius
    No unfortunately I haven’t had any luck.
  18. Dec 27, 2022 at 5:59 PM
    Tundrasrus
    Tundrasrus New Member
    Hi,
    For anyone that's interested in finding ignition-based power, Toyota has pre-wired a plug and play connector above the headliner (map light) area. There’s a video online on how to access this when installing THEIR dashcam. Easy to get at if you're simply wanting a 12 volt power supply, ground and accessory power.
  19. Dec 27, 2022 at 6:17 PM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    Yep, I covered that in one of the dashcam threads on which pin is which and the part numbers for the connector & the pin with wire.
  20. Dec 28, 2022 at 12:57 AM
    Tundrasrus
    Hi,
    Where can I read that thread ?
    I'm installing an aftermarket dash cam and would like to use a connector to tap into this factory connection.
  21. Dec 28, 2022 at 6:56 AM
    Maharisc
    Maharisc w/Patty
    Karl
  22. Dec 28, 2022 at 8:10 AM
    Tundrasrus
    Hi,
    So there's no connector that plugs into the existing integrated connection under the headliner ?
  23. Dec 28, 2022 at 8:31 AM
    Maharisc
    Maharisc w/Patty
    Karl
  24. Dec 28, 2022 at 9:47 AM
    Tundrasrus
    Hi,
    No. I want 12 volt power. I'm going to install an aftermarket dual dashcam and want 12 volt power while the vehicle is running and while the vehicle is not running.
    I'd rather plug into the connection under the headliner only because it's easier to access.
    I was hoping there was an aftermarket "connector" (with wires coming out of it) that I can attach the dashcam too
  25. Dec 28, 2022 at 10:01 AM
    Maharisc
    Maharisc w/Patty
    Karl
  26. Dec 28, 2022 at 3:38 PM
    Tundrasrus
    Hi,
    No I didn't read that one.
    But still, I was hoping to find (purchase) a connector already made that I can plug into the existing connector. From what you sent me, I looks as if I have to build it.
    I was hoping to avoid that option.
  27. Jan 10, 2023 at 3:17 PM
    Chopemupgood
    Chopemupgood New Member
    Larry
    NC
    23 MGM Tundra Limited
    Tyger Running Boards (So Far)
    So complete dummy when trying to figure out what fuse to connect in box 1 for a powered Tonneau cover. I have the Hybrid and can't access the battery under the back seat without removing half the back seat. Any suggestions?
  28. Feb 2, 2023 at 9:00 AM
    tony22longBed
    tony22longBed New Member
    tony
    2022 lunar rock long Bed
    Thoughts about the placement of this:?
    edit: a few guys wanted to know where I got the 3D print for the auxbeam....reach out to this guy: Mouafm@outlook.com
    Mykeromachine and AND like this.
  29. Feb 2, 2023 at 7:40 PM
    AND
    AND New Member
    Washington, PNW
    Looks good.
  30. Feb 10, 2023 at 2:36 PM
    raylo
    raylo not so new member
    Frederick, MD
    None
    I need to install a hardwire kit for my dashcam and will use a couple of fuse taps in fuse box 3 for switched and unswitched power. A couple of questions:
    1. Hard to tell from the photos but to access that fuse box just remove the one panel belove the glove box by pulling it down? Or is it under the kick panel?
    2. What form factor/size fuses and taps do we need? Micro? Mini? Low profile? Regular profile? What? There are so many sizes these days. :-/
