Any experience with the built in 1 Touch Up & Down for window controls?
Discussion in '2.5 Gen Tundras (2014-2021)' started by brkncly, Apr 28, 2022.
  1. May 22, 2022 at 9:43 AM
    #211
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    It is from the above set of post. Seems to be an earlier version the website is selling for $50 vs the new all auto.
    Single auto up/down $50
    https://cartrimhome.com/LED-Power-Single-Window-Switch-for-Toyota-TUNDRA
    All auto up/down $85
    https://cartrimhome.com/Window-Switch-Automatic-Lift-Function-for-Toyota-TUNDRA-2007-2021
  2. May 22, 2022 at 9:44 AM
    #212
    MaxPower
    MaxPower New Member
    18 Tundra TRD Off road
    The factory
    Those are not auto up down on all switches. This switch was made before the all auto option. The switch you pictured is considered an upgrade as you get auto up and down on the driver vs auto down only. The 2nd improvement is that all switches are lit.
    bulldog93 likes this.
  3. May 22, 2022 at 9:49 AM
    #213
    Badderup
    Badderup New Member
    A.J.
    Utah
    2019 Crew max
    Vent visors Side steps - wife and daughter are short
    Gotcha.:thumbsup:
  4. May 23, 2022 at 6:32 AM
    #214
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I did not swap yet. Probably not going to test anyyime soon as I will probably keep it. Only part that bothers me is if you have the window cracked or half down and use the auto feature it still runs the full 8.5 seconds regardless of starting position.
  5. May 23, 2022 at 8:06 AM
    #215
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    If some of you are hearing the motor well after it is supposed to stop, I am curious if the safety eateries still work. The window is supposed to stop and reverse if it meets resistance. I am concerned because I have dogs and if you have kids I would be concerned
  6. May 23, 2022 at 8:29 AM
    #216
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    '19 SR5 TRD Off-Road
    Fox TRD Pro Shocks BFG KO2’s Dirty Deeds 14” BAMF n-fab nerf bars
    That thought actually crossed my mind last night. I may test later today and will post results.
    Hugemoose likes this.
  7. May 23, 2022 at 9:55 AM
    #217
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
    Thank you for testing this. I've been looking at these, and if it does in fact bypass the safety features I may just buy the auto driver door only one, so just save my money all together.
  8. May 23, 2022 at 10:13 AM
    #218
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    So I tested the auto switches against one OEM switch I still have in the rear.
    I used a baseball and the handle of a baseball bat to test. Both windows appear to stop at the same amount of pressure on both objects. However, the window just stops. It doesn’t back down, etc. after it meets the resistance of something blocking. Not sure if there is supposed to be a safety “reaction”, but the switch appears to behave exactly the same as my OEM.
  9. May 23, 2022 at 10:26 AM
    #219
    2015 Inferno TRD PRO
    2015 Inferno TRD PRO New Member
    Virginia
    2015 Inferno Tundra TRD PRO
    Has anyone tried to install this switch to the crewmax back window?
    Beer Man likes this.
  10. May 23, 2022 at 3:49 PM
    #220
    APalmTree
    APalmTree 4x4 SKEPTIC
    Brandon
    SW Washington
    1 or 2... I lost count
    Pops bit the bullet and try number 2 I now have amber switches (the correct ones :yes:) and pops’ 21 got the blue switches that I had previously installed.
  11. May 23, 2022 at 4:38 PM
    #221
    Beer Man
    Beer Man @cement.tundra
    2021 SR5 XP CrewMax Cement
    That would be sick if it worked. I’m gonna move my switch to the card holder by the shifter soon, 2 birds with 1 stone!
  12. May 23, 2022 at 4:42 PM
    #222
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    I’m gonna try one of these passenger switches for it. I don’t think the plugs are the same but I can wire something up to test with.
    If it works then my kids side rear will have to live without an auto switch. And I’ll see if I can move the plastic rocker top to the new switch.
  13. May 26, 2022 at 8:21 AM
    #223
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Ordered mine the other day. I went with the blue lights.
  14. May 26, 2022 at 10:38 AM
    #224
    MaxPower
    MaxPower New Member
    Nice! You will love them. The blue matches very well on my 18.
    NCTundra18[QUOTED] likes this.
  15. May 26, 2022 at 7:25 PM
    #225
    eick
    eick New Member
    Just got em in too late to test wire the rear window but I’m gonna give it a shot tomorrow.
    mZiggy, sgtfluffy16 and biebs96 like this.
  16. May 26, 2022 at 7:27 PM
    #226
    biebs96
    PA
    keep us posted. I will absolutely order the other door switches. Not sure where it could possibly mount though
  17. May 26, 2022 at 7:30 PM
    #227
    Azblue
    Azblue Beer is Good Ban Moderator
    The Dirty T
    Ordered 11 days ago and no shipping notice yet. Looks like mine are taking the slow boat over from China. :(
  18. May 26, 2022 at 7:37 PM
    #228
    eick
    eick New Member
    This is the inside of one of the passenger door switches. Big resistor on top and couple of relays on the bottom. Microcontroller is a STC8G1K08 so probably not a way to mod the up down time etc
    Electrically should theoretically work for the rear window but looking at it physically I’m not sure how I can make it work. It won’t fit in a small switch opening.
    biebs96 likes this.
  19. May 26, 2022 at 7:43 PM
    #229
    biebs96
    PA
    I am pretty sure @2020Platinum modded his rear window to be automatic.
    I think it was a module and some wiring.
    But if some effort is needed its worth it, since this mod is plug and play.
  20. May 27, 2022 at 5:01 PM
    #230
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Got them installed in amber for my 07 yesterday. Pop two clips with the provided interior panel removal tool, unclip the electrical connector by pressing the button and wiggling, then remove three Phillips head screws. Install in reverse. Under 5 minutes! Everything fits and works great! The amber is a great match to factory 2nd gen dash lights. Very happy so far.
    dp0031, PolishedTRD, Paul B and 4 others like this.
  21. May 28, 2022 at 9:00 AM
    #231
    tundrasportinMA
    tundrasportinMA New Member
    Western Mass
    2019 Tundra Sport DC
    6112/5160 , SCS Ray 10's, Cooper Discover AT3 -295/70/18, Dirty Deeds 8inch, N-Fab Podium
    Finally got around to installing, all worked well on the initial tests.
  22. May 28, 2022 at 9:14 AM
    #232
    NCTundra18
    Jeff
    Candler, NC
    Mine shipped. Delivery date is June 3rn not the 8th.
  23. May 28, 2022 at 10:20 AM
    #233
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    brkncly[OP] likes this.
  24. May 31, 2022 at 3:16 PM
    #234
    TS18
    TS18 Northern CO
    2018 sport
    Ordered mine May 21st. Just installed. 10 mins. Now with the leather steering wheel, driver side grab handle, ajt chrome delete and added storage under rear seat, 3-1 5100s. The truck is exactly how it should have been built!
  25. May 31, 2022 at 3:43 PM
    #235
    TommyTundra
    TommyTundra Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    I ordered mine May 25. Came today. Pretty quick with the holiday weekend. Took ten minutes. All windows work smooth and seem to go down quicker. Seems to be a quality product. We will see how long it lasts.
  26. May 31, 2022 at 4:04 PM
    #236
    biebs96
    PA
    I noticed the change in window speed as well.
  27. May 31, 2022 at 4:50 PM
    #237
    Azblue
    The Dirty T
    Ordered on the 17th, showed up today. Will install tomorrow and report back.
    ToyoMafia likes this.
  28. May 31, 2022 at 5:17 PM
    #238
    sgtfluffy16
    sgtfluffy16 New Member
    Corey
    2019 Super White Tunda TRDPro
    Stock
    I have three questions. Why is the lock emblem different color from the rest of the switch? and why is it illuminated as soon as you turn the key to the on position? None of the other interior lights or switches are illuminated until the parking lights or headlights are on. Third the switch has the window motor activated about 6 seconds after you press the button in either Direction. Whether the window is is up or down. This driver side door switch has the window Motors activated for 6 seconds after the window is completely closed or completely down. Other than the extended length of time window motor being activated. anyone else having these concerns?
  29. May 31, 2022 at 5:19 PM
    #239
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Wait ur name is beer man? I’ve so many other questions to ask.
    biebs96 and Retired...finally like this.
  30. May 31, 2022 at 5:46 PM
    #240
    Beer Man
    Shoot
