I need information on a 3/2 leveling kit
Discussion in '2nd Gen Tundras (2007-2013)' started by Itchy-butt-2020, May 15, 2022.
  1. May 15, 2022 at 11:49 AM
    Itchy-butt-2020
    Itchy-butt-2020 [OP] New Member
    Gioan
    2010 crewmax
    Head lights Taillights
  2. May 15, 2022 at 12:08 PM
    $100 for spacers? Ur uppers will be a a bit more as 3”+ really should install uppers IMO
    It’s going to be a rough ride.
  3. May 15, 2022 at 12:25 PM
    Itchy-butt-2020
    Gioan
    2010 crewmax
    Really fast reply
    Thanks
    So is that upper control arms?
    Not sure what exactly uppers are?
  4. May 15, 2022 at 1:21 PM
    Sorry, yes. Uppers- upper control arms. Will you be taking it off road or just pavement? You can still get proper alignment with stock UCA, but nowhere near as good. Maybe a diff drop as well, but really at this point just get adjustable coil overs over spacers
    BravoDeltaRomeo likes this.
  5. May 15, 2022 at 2:23 PM
    Itchy-butt-2020
    Gioan
    2010 crewmax
    No off road stuff
    Not 4x4
    Only pavement hauling a trailer
    So if I went with the spacer
    You would recommend an upper arm spacer?
    Would there be a benefit from changing the lower control arm along with
  6. May 15, 2022 at 2:32 PM
    Good upper control arms are going to start around $700. SPC arms are popular and many of us have them. IMO, spending that kind of money on UCA's for a leveling kit is a waste of money. As @T-Rex266 said, get some coilovers. It will ride alot better and you will be happier. With lifting the rear, you will need some ABS brake line extension brackets.
    T-Rex266 and BravoDeltaRomeo like this.
  7. May 15, 2022 at 2:47 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Do you really trust or think a $100 lift/level is going to serve your truck well or even ride half decent?
    In my opinion, you are better off keeping it stock and/or saving up to do it right.
    Save your money.
    Saltyhero13, Piki and T-Rex266 like this.
  8. May 16, 2022 at 3:53 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    While a spacer lift is certainly not the most elegant or quality choice, they do work and I suppose have a place with trucks not intended for offroad use. My neighbor has a spacer lift and 34s on his gen 2.5 and seems more than happy with his truck.
    I think the tough part is regarding the 3" increase up front. That is the point where suspension arm and CV angles (4x4) are on the outside edge of their happy zone, and one has to start considering upper control arms, diff drops, center support mount drops, subframe drops etc. This obviously starts to add up, especially considering you started out wanting a lift that only costs $100
    This is why you are receiving the good advice/responses to start out with a higher quality set-up if it's just going to snowball into $1000 anyway.
    Many here on the site go the route of replacemetnt shocks with adjustable spring perch (Bilstein 5100's) to achieve a lift between 1-3" up front.
    I went with the Eibach stage 2 as it comes with complete coilovers for up front and matching rear shock absorbers (no lift). They have a threaded spring perch to dial in exactly the lift you desire, and include new springs, top mount, and really beefy lower shock mounts, all assembled and ready to install. I didn't even have to break out my spring compressors.
    I only lifted the front of my truck around 2", so I only needed an alignment to bring things back into spec. No UCAs, no drop brackets, and a little more piece of mind that I'm not putting too much extra stress on my truck.
  9. May 16, 2022 at 4:05 AM
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    If you’re only hauling a trailer on pavement I’d skip the 3/2 spacer lift and look at 5100s up front for 1-2” lift max and then an add-leaf plus maybe some airbags in the rear. New Coil overs upfront would certainly improve your ride but if you’re trying to save some $$ the 5100s will serve you just fine.
    that 3/2 setup is just gonna be brutal.
    Btw, how large/heavy of a trailer?
  10. Jun 14, 2022 at 12:30 PM
    Itchy-butt-2020
    Gioan
    2010 crewmax
    Update
    I had the 3-2 Leveling kit and upper control arms installed by a custom shop
    Parts cost 250
    Paid the shop 550
    Got the truck and it lasted 4 days
    The power steering went out
    Had it towed back to the shop
    They said the rack and pinion went out on it
    It will cost me 2500 to get it fixed
    I feel that they did not connect the lines properly
    And that they are at fault
    Of course they did not take responsibility
    They blame it on being an older truck 2010
    And manufacturing defect
    My question for you guys is
    In order to install 3-2 level kit and upper arm controls
    Do you need to disconnect and reconnect the power steering lines?
  11. Jun 15, 2022 at 4:41 AM
    COTundie
    Trey
    Pretty things
    One does not have to mess with ANY of the PS system to install spacers and UCAs.
    This is one of the reasons people install subframe/differential/mount drops when lifting over 2" up front. The extreme angles put extra stress on components, and can lead to premature failure.
    I would also take the time to look at your rear brake lines to make sure they have enough slack. I have not lifted the rear of my truck, so I don't know WHEN it becomes a problem, just that one needs extensions at a certain point.
    Definitely sorry to hear of your misfortune, but unless you see physical damage done to your PS components, I would not assume the shop did anything but install what you asked them to.
    If you have any pictures of evidence, post them up!
  12. Nov 28, 2022 at 2:57 PM
    Itchy-butt-2020
    Gioan
    2010 crewmax
    Update
    The rack and pinion was replaced
    The shop that installed it assured me it was just because it's an older truck
    Has been running smoothly since then
    Chrslefty likes this.
  13. Nov 28, 2022 at 2:58 PM
    Itchy-butt-2020
    Gioan
    2010 crewmax
    Thanks for all the responses
