Can’t get my wheels off
Discussion in '2nd Gen Tundras (2007-2013)' started by Thumper_6119, May 15, 2022.
  1. May 15, 2022 at 3:25 PM
    Thumper_6119
    Thumper_6119 [OP] New Member
    2011 Toyota Tundra SR5 Texas Edition (Crewmax)
    I have a 2011 Texas Edition with 20” BBS wheels. I went to rotate my tires today, and I couldn’t get the lugs off. I sprayed some WD-40 on them and let them sit. I finally got the lugs off of the driver’s side front wheel with a cheater bar on the 4-way tire tool, but the wheel wouldn’t budge. It was like it was welded on there. I put the lugs back on, and tried the passenger’s side front. My 4-way broke at the wrench end on the last bolt as the lugs were almost impossible to remove. I used the tire tool in the factory jack set to finish getting it off, but the wheel wouldn’t budge. Like they were welded on. I didn’t get too aggressive in my efforts to move the wheels because I was concerned that I would mess up my wheels. I’ve had the wheels off about 6 months ago to check the brake pads, and I didn’t have this problem. And I know I didn’t tighten the lugs down like that. (I don’t use air tools. Only hand tools).
    I’m not sure what to do at this point besides biting the bullet and taking it to a shop. Any advice?
  2. May 15, 2022 at 3:29 PM
    Casper421
    In the woods
    06 DC
    Hit the tires with a sledge.
  3. May 15, 2022 at 3:34 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 AC TRD
    Bassani cat-back
    A buddies f150 that was used at a boat ramp had the wheels stuck on, and a sledge wouldnt budge em. Ended up using a small bottle jack and the stock scissor jack between the frame and the tire. Then the sledge worked fine.
  4. May 15, 2022 at 3:56 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    When my tires wont come off I give them a curb stomp heel kick on the bottom of the tire and usually that pops them off.
  5. May 15, 2022 at 4:06 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    Yeah bud. You acting like my 15 year old 6'4'' man child lol. I literally did this today. He's like it's not coming off. I was like hold back.
    I'd hit that wheel with good front kick at 12-3-9 O' clock...the black rubber part, it should come. It might fall off. If not take a sledge to it. But I am sure it will come off using this trick. Btw I learnt this when I was dumbfounded like Jr. Lol
    Also if up it in a rust belt clean the inner rotor with a steel wire. And coat the inner rotor with anti-rust paste.
    MS22, Darkness and Thumper_6119[OP] like this.
  6. May 15, 2022 at 4:10 PM
    Retired...finally
    Beating the tires is a good way to eat a sledgehammer sandwich. You really need to hit the rim to get the shock wave to break it loose. Unfortunately that's not good for the rims.
    What I would do is to use a bottle jack and 4x4. Jack up one corner slightly and apply jackstands. Remove lugs on that wheel. Cut the 4x4 post the distance between the inside of the two rims on either axle minus the jack height collapsed and 4". Let's say the distance you measured from inside of drivers side rear rim to inside of pass side rear rim is 72" and your bottle jack is 8" collapsed. Add 4" and cut the 4x4 post 60 inches long. Now, one end of the post gets placed against the inside of rim opposite the loosened wheel. You may need to find something to hold it up off the floor like a box, soup can etc. Now take the rest of the 4x4 post and place it on the floor inside the loose wheel so it's 90* from the other 4x4. Place the bottle jack between the two 4x4s and pump. Apply pressure and using a piece of plywood or other lumber protect the top outside of the rim and give it a good smack with a good sized hammer. Caution: the hand holding the buffer block might get a hurtful shock so use gloves and of course eye protection.
    Once that wheel is off, clean the corrosion with scotchbrite and use no ox grease before putting the wheels back one. Then use that wheel to hold the 4x4 to push off the opposing one.
    Thumper_6119[OP] likes this.
  7. May 15, 2022 at 4:17 PM
    baraynavab
    Atlanta
    Oh also before you ask... If you got aluminum wheels you need to torque this wheels to 97lbs
    Of you got steelies/steel. 150lbs iirc.
  8. May 15, 2022 at 4:32 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Have had the same problem with all my alloy wheels when I have lived in salty parts of the country. 4lb sledge on a wood block against the inside edge of the rim has always worked for me. Wire brush the contact surfaces between hub and rim and coat with whatever bearing grease you have laying around.
    Aluminum alloy rims and steel hubs don’t agree with one another once you throw road salt in the mix. I’ve never had trouble getting the lug nuts off, luckily.
  9. May 15, 2022 at 4:35 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    One wheel at a time, loosen all the lug nuts a few turns and slowly drive a few feet back and forth.
    For real stubborn wheels, you may have to slowly turn some corners.
    Greg
  10. May 15, 2022 at 4:42 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Spice it up with some dirty talk, tell those wheels who daddy is. They should get off easy.
    aelarson, dittothat, Hbjeff and 6 others like this.
  11. May 15, 2022 at 4:42 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've used the handle of my 2' breaker bar like a tire thumper from the inside many times. Whack it on the tire a few times and spin the wheel as you do it. Pops right off.
  12. May 15, 2022 at 4:43 PM
    Retired...finally
    Always works for me.:thumbsup:
  13. May 15, 2022 at 4:46 PM
    Saltyhero13
    Wait til I show you Tirerack.com....
  14. May 15, 2022 at 5:45 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    Spartan kick the tire a few times and it'll pop off. Anti seize, grease, etc. On the mating surfaces. Tundra seems especially bad about galvanic corrosion between the aluminum wheel and steel rotor.
  15. May 15, 2022 at 8:31 PM
    baraynavab
    Atlanta
    ooh here's another decent way.. from youtube.. like there brothers showed.. I think this would work as well.
  16. May 15, 2022 at 10:26 PM
    Thumper_6119
    Thanks, y’all! Lots of great info here. I’ll take another stab at it next weekend.
  17. May 15, 2022 at 10:26 PM
    dittothat
    dittothat New Member
    SD
    2016 MGM Platinum
    If you’re looking for a new 4 way I might suggest this one. Had mine for over ten year with zero issues. To give you some perspective of how much torque it can handle: with my old f150 I’d have to slip a 50” cheater pipe over it and pull down with all 200+ lbs of me. Eventually learned to put a pad on the floor for my ass to land on. Never had an issue with it, though. Not sure if it’s still made in the USA, but it’s very stout and well made. Doesn’t fold but will fit in a 20” wide toolbox.
    Ken-Tool 35657 4-Way Lug Wrench, 23 in. https://www.amazon.com/dp/B000GPB3CI
    My F150 wheel lugs would be seized solid. If You get a flat, might as well forget about changing it out if you don’t have a cheater bar. Better off just driving on the rim. Here is where I first found out about the issue ~35 miles into the north Maine woods without a soul in sight
  18. May 15, 2022 at 10:32 PM
    Thumper_6119
    I saved that on my Amazon wishlist! Thank you!
    I keep a 4-way behind my seat, and it was the one that I broke. I picked up a more substantial replacement for from Advanced for around $25. That Ken-Tools 4-way looks to be even better. I’ll order one next payday.
    dittothat likes this.
  19. May 17, 2022 at 10:25 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    PB blaster and a louisville slugger
    dittothat and Retired...finally like this.
  20. May 18, 2022 at 6:09 AM
    PayItOff428
    PayItOff428 New Member
    Jake
    The United State of Texas
    2012 SR5 Double Cab 4X4
    I see a soul right behind you!
  21. May 18, 2022 at 7:32 AM
    dittothat
    SD
    2016 MGM Platinum
    Haha he was the only one. Didn’t see a single logging truck the whole time. Were up by Caucomgomoc Lake
