Best way to remove spare tire guide tabs?
Discussion in 'Wheels & Tires' started by silverhack, Jun 17, 2020.
  1. May 4, 2022 at 10:18 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    Ive finally came to this point where i needed to remove my tabs to fit 35 under and read up on what the internet had to offer. When I poked my head up in the wheel well I thought to myself, why are you guys making this so difficult?
    1) reciprocating saw
    2) 3 lb hammer
    sliced the rivet off from the top flush with the bracket. used hammer on the bracket and popped it right off. took less than 30 mins from looking, grabbing my tools and battery and putting in the work.
  2. May 4, 2022 at 10:29 AM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    I’m not a fan of using angle grinders at odd angles, limited space…I’d go dremel, reciprocating saw, or just drill out the rivets. Chance of shrapnel from a broken cutoff wheel at the high speed/power of an angle grinder while lying under the truck is a risk I prefer to avoid.
    Ace96 likes this.
  3. May 4, 2022 at 10:50 AM
    W3agle
    W3agle New Member
    San Diego, CA
    2016 White Tundra SR5 TRD Off-Road
    Hmm I recently bought a used TRD OR wheel with a 295/70/R18 tire to match the tires currently on the truck. I'm planning to start rotating the spare in when I get new tires in ~15k miles. My current 295 spare is old and and I'm getting ready to replace soon, so I didn't really get too invested in the fit. The tire seemed to fit up in the space fine without cutting off this bracket. I guess I need to take a second look before I put a brand new one up there. I take it these brackets are probably rubbing my tire in a bad way.
  4. May 21, 2022 at 6:24 AM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    Went through the work of drilling out the rivets, getting a couple blisters from the hot metal falling down, only to find out my 35 won’t fit with my dual exhaust… :facepalm:
    texasrho83 likes this.
  5. May 21, 2022 at 6:28 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    That sucks. I'm just gonna leave the space open for a train horn or air compressor
    SpyderRC[QUOTED] likes this.
  6. May 21, 2022 at 6:33 AM
    SpyderRC
    SpyderRC New Member
    You must be running 35’s with dual exhaust? Not sure what I’m going to do yet. Take off my borla exhaust sell it and get something different, or just leave my spare at home and throw it in the back of another vehicle if I ever get a flat and need it.
  7. May 21, 2022 at 6:42 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah but moving up to 37s on the next set. I carry my spare in the bed and use it as weight for traction :p
  8. May 21, 2022 at 9:11 AM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    What exhaust do you have that the 35” spare wouldn’t fit after removing the tire guides?
    Just saw further down…it’s the borla exhaust? Is that routed different than the TRD dual exhaust?
  9. May 21, 2022 at 10:26 AM
    SpyderRC
    SpyderRC New Member
    Yes, it’s a borla exhaust. Mine is routed out the back where (correct me if I’m wrong) the trd exits out the sides?
  10. May 21, 2022 at 10:56 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    i wasnt aware of any dual exhaust would work? its quite tight and an inch away or so from oem single exhaust. i can push it away only so much before raising it up into place.
  11. May 21, 2022 at 11:31 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What about axle dumps? Would the tire fit then?
  12. May 21, 2022 at 4:13 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    yeah the TRD exits on the sides behind the rear tires…didn’t realize the borla exits at the rear. I’ll post back fitment in about a week when my spare comes in…putting up a 295/60R20…says it’s 34.8” on the website for actual height
  13. May 21, 2022 at 4:54 PM
    SpyderRC
    SpyderRC New Member
    Not sure, will have to check next tune get a chance.
    Borla offers both rear and side exits. I’ll be curious to see how yours comes out.
    1P7R9O4[QUOTED] likes this.
  14. May 22, 2022 at 1:07 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    After waiting a year for a matching wheel to come back in stock to have a matching spare (black rhino dugger in 20x9 +10 still showing the perpetual 6-8 weeks out everywhere), I gave up and ordered a different wheel. My newly ordered black rhino stadium in 20x8.5 +10 arrived today, and the tire should be in tomorrow. Good news is that the wheel and tire I purchased will come in for the cost of just the wheel after recent price hikes. Figure it’s close enough, and likely won’t see much, if any, use anyways. Hoping it all fits with the tab removal and TRD dual exhaust.
  15. Jun 5, 2022 at 9:08 AM
    Croaker
    Croaker New Member
    Ken
    2016 Ford F-150 Lariat
    I have 35's on my truck and the spare fits. I have the TRD Pro. I have it on there without the brackets removed. it hangs a bit lower but fits. I'm still planning on removing the brackets so it goes all the way up. But no issues so far.
  16. Jun 9, 2022 at 6:38 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    35x11.5R20 Yokohama Geolandar M/T installed after removing tabs. Used a carbide thick metal 6” sawzall blade to cut the rivets from the top, then had to still drill them out from the bottom. Fits with my TRD dual exhaust.
    CaptRussia253 and TunaDr like this.
  17. Jun 10, 2022 at 8:31 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    did it not cut flush? if you cut it flush a few good wacks on the bracket pops out the remaining rivet wedged in the frame.
  18. Jun 10, 2022 at 9:06 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    pretty flush…it was difficult with the angle to get the blade flat without it wanting to gouge the top of the cross brace. I’d say 1 of 2 was completely flush on each side, the other had maybe a 1/16” high spot at one end. You can see where I beat the bracket that’s still attached with a sledgehammer, but it wasn’t breaking loose, just bending. It did make for less material to have to drill through from the bottom of the rivets…with hot metal shavings raining down on me:notsure:
  19. Jun 10, 2022 at 9:13 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    yeah the drilling part did not sound fun to me at all...well i hope others have better luck sawing it flush then.
  20. Jun 10, 2022 at 9:18 PM
    #50
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    yeah, me too…seemed like the best approach. I felt more comfortable using the sawzall and carbide blade than trying to use an angle grinder. It came out clean, just more work than I initially anticipated … I did spray some flat black paint in the holes afterwards, even though it’s only a small circle of exposed metal.
  21. Jun 13, 2022 at 7:32 AM
    #51
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Washington
    I’ll be doing this soon. Getting 35x12.50 Yokohamas installed today and would like a matching spare.
  22. Jun 13, 2022 at 7:55 AM
    #52
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Congrats on the new tires…post back with pictures when you get them on. Yeah, I felt more comfortable going to the full size matching spare; it’s worth a little bit of time and effort to get it done, but will appreciate the peace of mind should the need to use it arises when out beyond the city.
  23. Jun 13, 2022 at 8:17 AM
    #53
    CaptRussia253
    Ruslan
    Washington
    Agreed. I always try and run a full-size spare because we travel with our two kids. Peace of mind is worth the extra money.
    Tires getting installed as we speak.
    SAGE63, Hotwire and 1P7R9O4 like this.
  24. Jun 13, 2022 at 1:35 PM
    #54
    CaptRussia253
    Ruslan
    Washington
    Yokohamas installed! Looks amazing. Slight rub on the corner of the body mount when fully locked in reverse but that was expected. Getting an alignment now to get max caster. Buddy is going to do my BMC regardless.
    Hotwire likes this.
  25. Jun 13, 2022 at 1:54 PM
    #55
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Looks good! If the alignment takes care of slight rub at full lock, I wouldn’t even mess with cutting up your truck.
  26. Jun 13, 2022 at 3:10 PM
    #56
    CaptRussia253
    Ruslan
    Washington
    But 37s in the future… haha
  27. Jul 30, 2022 at 3:56 PM
    #57
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    I'm thinking of removing the guide tabs tomorrow in preparation to try and fit a larger tire. However, I took some measurements and only getting 32 inches between the coachbuilder shackles and 32 inches from the hitch to the DirtyDeeds resonator.
    Anybody have any ideas what a lower PSI 285/75/18 tire would be height wise? I was looking at the Yokohama Geolander A/T which is a 34.7" tire.
    DZ_ likes this.
  28. Aug 6, 2022 at 9:46 AM
    #58
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    I used a cutting wheel to remove the bulk of the rivets then air chiseled them out.
    worked out great!
    CaptRussia253 likes this.
  29. Aug 13, 2022 at 5:35 AM
    #59
    Okierunner
    Okierunner New Member
    2020 TRD Offroad Crewmax
    Icon UCA Bilstein 6112/5100 Method 17s Ridge Grappler 35x12.50 Trd Dual exhaust
    I drilled the bolts out of mine. A good step bit will buzz them out a lot quicker, much cleaner to remove the whole thing.
    Hotwire likes this.
  30. Aug 13, 2022 at 6:45 AM
    #60
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD Praux
    Did you get into this? Looking at doing the same, but with OE shackles and TRD PRO (dual) exhaust.
