Tundra Maintenance Guide
Discussion in 'General Tundra Discussion' started by csuviper, Feb 16, 2014.
  1. Jun 18, 2021 at 10:13 AM
    #61
    grillboy86
    grillboy86 New Member
    Richardson, TX
    2018 Barcelona Red Tundra Platinum CM 4x4
    I have a 2018 Tundra 4x4 and there are no zerks on the propeller (drive) shafts, so they are sealed and cannot be greased. Just crawled under mine with grease gun in hand and couldn't find any. Found another thread in this forum confirming 2019s are also sealed.
    Anyone know what the propeller bolt torque specs are for 2018 Tundra 4x4?
  2. Jun 28, 2021 at 7:01 AM
    #62
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    2021 Tundra DC
    Not sure at this point.
    Truck is currently at 15k and is about to get an oil change at the stealership, should I also be greasing the propeller shafts for a 2021? Going to be checking all the filters as well and see if there are anything that needs to be replaced.
  3. Jul 12, 2021 at 7:11 PM
    #63
    ErSlickEr
    ErSlickEr New Member
    2018 MGM Tundra 4x4 CrewMax 5.7L FFV Limited
    My 2018 did not have an zerk fittings. So I do not think your 2021 may unless toyota went backwards for some reason..lol.
    But this is an assumption. Just crawl under and check the propeller shafts and look for zerk fittings. If you dont have them, you cant grease them.
  4. Jul 12, 2021 at 7:12 PM
    #64
    ErSlickEr
    https://www.tundras.com/threads/tundra-maintenance-guide.315/page-2#post-1827703
  5. Jul 30, 2021 at 7:40 PM
    #65
    Hamster14
    Hamster14 New Member
    Utah
    2014 Tundra Limited
    -46 gallon tank - shell
    Guys quick opinion..
    I just starting using amsoil and amsoil filters
    I change the oil every 5k miles but the filter says it’s good for 15,000 miles.
    I know we are suppose to do lube and filter together but do you guys think it’s ok to change the filter every other change? So it’d be every 10k miles on the filter E6E4E25F-CBA2-47AA-A8F0-34F8B6E5A963.jpg
  6. Jul 30, 2021 at 7:46 PM
    #66
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I personally would do them both at 5k. Cheap insurance for an expensive engine. Just my opinion of course. ;)
    KNABORES and GODZILLA like this.
  7. Jul 30, 2021 at 8:04 PM
    #67
    Hamster14
    Utah
    2014 Tundra Limited
    You’re 100% right. was expecting that response maybe it’s the lazy bug in me wanting to not have to take the plate off
    TILLY[QUOTED] likes this.
  8. Jul 30, 2021 at 8:16 PM
    #68
    TILLY
    Massachusetts
    The shield is definitely a PITA to remove, but it gives you time to lay on your back with a cold one and inspect that beautiful powertrain for any other problems that may arise in the future. :cheers:
    Hamster14[QUOTED] likes this.
  9. Aug 1, 2021 at 3:29 AM
    #69
    Green Thunder
    Green Thunder Smooth in the Cruise
    Washington
    2020 Burnt Green TRD Pro
    Food crumbs and dog fur
    I don’t see a problem. It is no different than going 10k miles on an oil change and lots of people do that all the time. The nice thing with the Toyota design is you can drain the oil from the filter but leave the filter installed.
  10. Sep 10, 2021 at 1:24 PM
    #70
    Spoot
    Spoot New Member
    2018 White CM TRD 5.7L 4x4
    About the missing zerks & propeller shaft maintenance on the newer models...
    From the Maintenance Manual:
    Propeller Shaft
    Lubricate the propeller shaft spiders and slide yokes with lithium-base chassis grease and the double cardan joint with molybdenum-disulfide lithium-base chassis grease, and re-torque the bolt. Only a qualified technician should perform this operation
    Lithium-base chassis grease here:
    Molybdenum-disulfide lithium-base chassis grease on this thing:
    TreeCat likes this.
  11. Sep 10, 2021 at 1:42 PM
    #71
    AndrewSmith
    AndrewSmith New Member
    Thornhill, Ontario
    2021 Sequoia Limited
    Cool, thanks! Is that second one a video you could share too?
  12. Sep 10, 2021 at 2:29 PM
    #72
    Spoot
    Spoot New Member
  13. Sep 20, 2021 at 1:36 PM
    #73
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    I don't get it. How are you supposed to lubricate those areas on a 2018+ if there is no zerk?
  14. Sep 21, 2021 at 5:59 AM
    #74
    Spoot
    Spoot New Member
    I had interpreted the manual as saying, just rub grease onto those exposed areas of the shaft??
    It doesn't seem logical at all, though.
    I also forgot to ask the service team about it when I went in last week to have this service done.
  15. Dec 26, 2021 at 1:33 PM
    #75
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    2021 Tundra DC
    For those with RCI engine/transfer plate, would you be able to change fluids without removing plates?
  16. Mar 17, 2022 at 9:45 PM
    #76
    ErSlickEr
    There are no zerk fittings so you cannot lubricate it. By adding lubrication on the surface, you will just attract dirt and make a mess. This parts are sealed and internally lubricated. Hence we do not have the zerk fittings.
  17. Mar 17, 2022 at 9:55 PM
    #77
    AndrewSmith
    Thornhill, Ontario
    Does anyone have experience with such "lubricated for life" things? I am planning to do half a million kilometers in this truck. Am I going to have to replace the driveshaft at some point because of this?
  18. Mar 18, 2022 at 1:44 PM
    #78
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    While I can't answer weather or not you'll have to replace the driveshaft, I do have thoughts on the subject.
    When I first started driving cars, they were 60's vintage autos. In those times virtually every joint in the front end of the vehicle, ball joints, tie rod ends, idler arms, pitman arms, etc. all had grease zerks. Part of the oil change ritual was greasing all those parts.... a real pita!
    Then at some point (don't really recall the time frame) auto manufacturers started producing front ends with no means to lubricate the individual parts. Well we all thought "what a stupid thing to do" now we'll have to be replacing parts all the time. Didn't turn out that way, I think the sealed parts lasted just as well as the greaseable parts did. In many instances the sealed parts lasted much longer simply because the non sealed parts didn't receive the lubrication they needed often enough.
    Just something to think about, good luck with your driveshaft.
    NUDRAT and jtwags like this.
  19. May 4, 2022 at 4:26 AM
    #79
    BGoodiE
    BGoodiE New Member
    Ben
    19 TRD SR5 OR
    NONE! Lasted about a month, Firestone bags, Decked system, ARE CX HD, WeatherTech mats/rainguards, TRD RSB...
    30k mile service??
    Feel like I got raked through the coals. '19 Tundra went in for inspection and left with 30k mile service, $500 later and no inspection. Lebanon Bennett Toyota is awful.
    My question is, does anyone know what the air ind serv is? I told them to leave the filters alone I can handle that. So why $200 for an air ind serv and fuel inj cleaning?
    I hate not having a lift in my garage.
  20. Dec 30, 2022 at 7:04 PM
    #80
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
  21. Aug 18, 2023 at 12:17 PM
    #81
    Skold
    Skold New Member
    Our 2015 Tundra 5.7 has 130000 miles. I've changed the brake pads and oil so far but that's about it. What is a list of must do maintenance items now and what are some should do's? Thanks!
  22. Aug 18, 2023 at 1:08 PM
    #82
    shifty` Our private little trip to hell
  23. Sep 11, 2023 at 6:28 PM
    #83
    BeardedTundra
    BeardedTundra Shr3k
    Justin
    2006 Sequoia
    As of 2023, 74k miles Big mods coming soon...
    Good info for 1st gen Sequoia owners also. Thank you.
  24. Sep 11, 2023 at 6:34 PM
    #84
    BeardedTundra[QUOTED] likes this.
  25. Sep 11, 2023 at 6:47 PM
    #85
    BeardedTundra
    BeardedTundra Shr3k
    Justin
    2006 Sequoia
  26. Dec 23, 2023 at 8:06 AM
    #86
    noserider
    noserider New Member
    2010 Tundra SR5 5.7
    I need a shop/repair manual. This thread has links but when I go there it's a $14.95 download. Just wanted to make sure the link is not directing me to a scam site. Thanks
  27. Dec 26, 2023 at 8:09 PM
    #87
    AndrewSmith
    Thornhill, Ontario
    I didn't have to pay anything when I donwloaded them using the 2016 links. But that was years ago.
    noserider likes this.
  28. Mar 20, 2024 at 11:04 AM
    #88
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Good thread.
    My 2021 now has 60k miles, bought new. I drive 30k miles/year with some towing so I tend to hit the 'recommended' milestones rather quickly.
    Here's my plan:
    - Oil always changed every 5k miles, IMO this is the single most important item
    - Engine air filter: Did not change at 30k since it looked brand new. Will check and replace now if it's dirty.
    - Cabin filter: As with engine air filter
    - Brakes: Will swap pads when they're worn, and will replace fluid at the same time
    - Transmission: Will drain & fill now (Only replace the amount I took out, will with hose from above. Not messing with the "check at correct temperature" approach)
    - Rear diff: will replace fluid now
    - Front diff: at 100k miles (very seldom use 4x4)
    - Transfer case: at 100k miles
    - Plugs: at 120k miles
    - Engine coolant: Likely never. Still looks clean & pink.
    I have a hunch I could easily delay virtually everything to 100k, the Tundra wouldn't care. The only corner I won't cut is oil changes.
  29. Mar 20, 2024 at 2:23 PM
    #89
    AndrewSmith
    Thornhill, Ontario
    From personal experience: I'd worry about the transmission being overfilled at the factory. After a couple of years and a lot of towing mine started making whining noises, which continued after I replaced the transmission fluid, but almost completely stopped after I did the temperature stuff and drained quite a bit of extra.
