Tonneau Cover Buying Guide
Discussion in 'Tonneau Covers, Caps and Shells' started by SantanaRealtruck, May 3, 2022.
  1. May 3, 2022 at 6:51 AM
    SantanaRealtruck
    SantanaRealtruck [OP] New Member Vendor
    Hello all! I've viewed several posts recently with members asking which cover should they buy? While it's impossible to compile every cover and comparison into a single post, I wanted to put together a general guide to assist in making a decision. I'm going to try to lay this out by style of cover, versus individual cover comparisons as much as possible, without endorsing a specific brand or style. Additionally, there are new covers added every year, and brands/styles that we don't sell, I can't speak to. Please feel free to comment below if you're looking more more in depth comparisons, specific cover models, suggestions, etc. I'll try and update this post as new covers and styles release in the future to ensure it remains relevant.
    A tonneau cover, or truck bed cover as they’re sometimes called, attaches to your truck bed and keeps your gear out of direct rain and snow. Depending on the design, they also provide outstanding security and even options for additional accessories. This buying guide should help you learn the differences between all the various tonneau cover designs so you choose the best truck bed cover for your Tundra. The first question I would ask, is how do you intend use the cover? Specific materials and designs are going to be best used, for certain needs and requirements.
    Soft Tonneau Covers
    The most obvious benefit of choosing a soft truck bed cover is affordability. Ranging from $200-$500, soft covers give your cargo ample protection from rain, snow, and other elements at an affordable price. However, not all soft covers are created equal as there are a few different designs to be aware of.
    Soft Rolling Covers
    The most widely sold tonneau cover available today, soft rolling covers offer an an affordable cover that keeps your gear out of the elements and out of sight. Most designs use hook-and-loop (velcro) fasteners to secure the tonneau cover once closed and tension from the header bar keeps the cover taut. Once opened, the cover provides full access to the bed and a fastening system will allow you to keep the cover open when driving. Installation involves clamping a pair of rails to your truck bed and attaching the cover to the rails, a simple process that can usually be done in less than an hour with basic hand tools.
    Within the soft rolling category, you have two primary designs. Top mounts and inside mounts. Top mounts have a reputation for being a little more water resistant due to the design, but have a taller profile at about 1.5" above the bed rails. Inside mount covers are going to provide a more aesthetically pleasing look and have a profile on average of .5" above the bed rails. Additionally, there are several styles of tension controls. The Truxedo Lo Pro, Pro X15, Truxport and Gator SR1 utilize a spring loaded tension mechanism. This design allows the user to close to cover and not have to worry about adjusting the tension. Most other soft roll up covers will use a dial or block tension mechanism, i.e. Access Covers, Gator SRX, Gator SR2, etc.. This style will manually be adjusted, typically at the header bar (front), using a dial. While this design does require manual adjustments periodically, it does allow you to "dial in" the tautness of the cover to your preference.
    Within the soft rolling category, you primarily have two fabric options. Marine grade vinyl is the most common, used by a variety of brands. This material holds up well to the elements, but if you live in an area with heavy sun, I do recommend occasional treatments with a water based UV protectant (303 Protectant or similar) to help protect the vinyl. The second option, would be a fabric, used in the Truxedo Pro X15, Lund Genesis Elite and Rugged Ridge Armis. The benefit of fabric is, it's a matte black finish and can be more heavy duty. Both options will provide similar water resistance.
    Choose a soft rolling tonneau cover if:
    you want an affordable cover that keeps your gear out of sight and out of the rain while providing full bed access when necessary.
    Soft Folding Covers
    This truck bed cover is made of vinyl or canvas material stretched over an aluminum frame in a one-piece design. The clamps that attach the cover to your truck bed are part of the cover as well, and they can usually be installed with no tools required. The biggest selling point for a soft folding cover is the ease of installation: simply line it up on your bed, attach the hand-tightened clamps, and you’re done. To open the cover, simply detach the rear clamps and fold it toward your bed for 2/3 bed access. If you need full bed access, the cover can be quickly removed and reinstalled.
    Primary differences within the soft folding category will be style of clamps and top material. The Gator SFX, Extang Trifecta 2.0 and Extang ALX use spring loaded rear clamps, which allows constant tension to put put against the bed rails. The majority of other soft tri-folds use tension clamps, which will hold the cover against the bed rails. Typically, the more expensive soft folding covers will have wider frames and beefier hinges, designed for increased use and durability compared to the entry level covers.
    Just as with soft roll up covers, most use marine grade vinyl, however the Advantage Torza Top Premier and the Extang Trifecta Signature will use a canvas fabric.
    Choose a soft folding tonneau cover if: you want to spend minimal time on installation and protect your cargo from the elements.
    Snap Tonneau Covers
    The oldest tonneau cover design, snap covers consist of a tarp and rails with, you guessed it, snaps built in. Installation is similar to a soft rolling cover, but snap covers usually include tailgate and bulkhead rails, which results in a slightly longer installation process. To open it, simply unfasten the snaps and roll the cover toward your bulkhead. Keep in mind that most snap covers use bows that aren’t attached to the tarp, so if you need to haul large items, the bows will have to be removed and stored. That being said, they are water-resistant and relatively simple to operate. They’re also among the most affordable covers available with prices starting at a little over 200 dollars.
    Choose a snap tonneau cover if:
    you need the most affordable cover you can find, or you are looking for a classic style.
    Hard Tonneau Covers
    While soft covers do a great job of keeping the bed dry with gear out of sight, they do lack the security hard tonneau covers provide. Hard covers are water resistant, made out of materials such as aluminum, fiberglass reinforced polymer and thermoplastics. Similar to soft covers, depending how intend to use your bed will determine which style of hard cover to choose, folding or rolling.
    Hard Folding
    Hard folding covers are versatile, relatively easy to install and easy to operate. There are two common designs, top mounts and inside mounts. Just like with soft rolling covers, top mounts are going to traditionally be more water resistant due to their design, and inside mounts, which are flush with the bed rails. Top mount hard folding covers install like a soft folding cover. The cover sits on top of the bed rails and mounts to the lip of the bed, installing in only a few minutes. These covers will fold on top of themselves to provide 2/3 bed access, but do require removal to gain full access. Common models include the Extang Solid Fold 2.0, Rugged Liner Hard Folds and the Advantage Hard Hat. Inside mount covers provide a sleek appearance, sitting flush with the bed rails. Common models such as the Undercover Flex line and BakFlip covers will fold up to the cab to give full bed access, without removing. The Access Lomax line will provide 2/3 access without removal. These covers require rails to be installed on each side of the bed, using clamps, and the cover will sit and fold between the rails.
    Within the hard folding cover line, you also have a variety of materials to choose from:
    Aluminum - Recommended for high UV locations, as aluminum is a more fade resistant material. Available in satin or matte black finishes in top mount or inside mount covers. Found on the Bak MX4, G2, Undercover Flex, ArmorFlex, Extang Xceed, Rugged Liner HC3, etc.
    Fiberglass Reinforced Polymer - Recommend for areas where hail in common, as FRP is more dent and impact resistant. However, this material is more susceptible to fading. Available in satin finishes, only found on the Bak Fibermax and F1.
    TPO - EnduraSheild polymer, a thermoplastic material that does well resisting fading and impact. Found on the Extang Solid 2.0 and Gator Tailback.
    Vinyl - On hard folding covers, vinyl is typically adhered directly to an ABS panel to provide a seamless, one piece look. Found on the Advantage Hard Hat, American Hard Folding, etc.
    Choose a hard-folding tonneau cover if: you need security, water resistance, and the ability to haul large items when necessary.
    Hard Rolling
    While not as well-represented as some other categories, hard rolling tonneau covers have become a popular alternative to folding designs over the last several years. The tonneau itself is made of interlocking aluminum slats, which are covered by a heavy-duty vinyl or canvas material. This results in a truck bed cover with no visible hinges that provides ample shielding for items in the bed. Like a soft rolling tonneau cover, opening one of these is as easy as pulling a latch and rolling it toward the bulkhead.
    Primary comparisons within this category are between the rail designs and the vinyl type. Bak Revolver series rotational locking rails, in which the cover slats recess into the rail, and a metal latch rotates to cover the slats when locked. This prevents you from being able to lift the cover along the rails at any point. The Truxedo Sentry and Gator HR1 use velcro rails to keep the cover secure, with a latch located in the middle of the rail to prevent unwanted access.
    Vinyl options include a traditional satin marine grade vinyl, found on the X2, HR1 and Sentry, or a matte black, canvas fabric, found on the X4s, Sentry CT and Armis.
    Choose a hard-rolling tonneau cover if:
    you like soft cover looks but need hard cover security
    Retractable
    Not to be confused with rolling or roll-up covers, a retractable tonneau consists of a hard cover made of aluminum or composite material, which retracts into a canister mounted at the bulkhead when bed access is needed. Depending on which retractable truck bed cover you choose, you may be able to lock it in position anywhere between open and closed. Other designs use set, intermittent locking points. You can even get an electric retractable tonneau cover that opens via a push-button key fob. Just keep in mind that you’ll lose approximately 10 to 12 inches of overall bed length due to the canister. As mentioned, there are a few differences between models, including locking positions, rails, blanket material and locking mechanism.
    Retrax and GatorTrax covers utilize sealed ball bearings and a springless canister with the intention of being maintenance free. You don't need to wax the rails, ever replace springs, etc. Most other brands such as Pace Edwards and Truck Covers USA, utilize a spring in the canister to assist with retracting the cover. Where on the Retrax, you have to "walk the cover back" to the canister, you can simply stand at the tailgate and the cover will self retract. Great if you're on a lifted truck and walking down the length of the bed is vertically challenging. Additionally, these covers tend to have smaller canisters then the Retrax/GatorTrax line.
    Another key difference, will be the blanket material, the actual cover itself. GatorTrax and Retrax both offer a lighter duty polycarbonate blanket and a heavy duty double walled aluminum. Similarly, Pace Edwards offers a lighter duty aluminum with ArmorTek vinyl, and a heavy duty double walled aluminum. You'll find across all three brands, the lighter duty weight capacities are lower 200-250 pounds distributed on top, whereas the heavy duty is 500 pounds. Truck Covers USA only offers a double walled aluminum, they do not make an entry level version.
    The final, most notable difference is how they lock. While all retractable covers for modern trucks rely on a closed and locked tailgate, certain brands add an exterior lock. Retrax, GatorTrax, Truck Covers USA, and Pace Edwards (Excluding the Bedlocker and UltraGroove series) have an exterior lock, allowing you to operate the tailgate and cover independently from each other. The Gator Recoil, Pace Edwards UltraGroove and Switchblade series do not have an exterior lock, so to open, you will have to open the tailgate first.
    Choose a retractable tonneau cover if:
    you don’t mind sacrificing a little bed space for convenient operation, particularly on highly lifted trucks.
    Painted
    So far, we’ve categorized tonneau covers according to what they’re made of and how they’re operated. So why do painted covers get their own mention? Well, the vast majority of painted tonneau covers also use a one-piece hinged design, which we haven’t discussed yet. Rather than folding or rolling open, this design lifts open, often with the assistance of lift supports or scissor hinges. Available with composite or fiberglass construction, the painted tonneau cover is prized for its unparalleled security and weather resistance, a direct result over its overlapping design. Of course, having the cover painted to match your truck’s OEM paint code also results in an unbeatable look. The one drawback to this design is bed access. To haul large items, you’ll probably have to remove the tonneau cover first. This often requires two people due to the weight and size of the cover.
    Ranch and Patriot painted covers, will be made of fiberglass. While this material is very heavy duty, it's rather heavy, typically weighing over 100 pounds. The Undercover Elite LX and Lux are made out of a composite, which is about half the weight, yet a little more expensive. Keep in mind, all painted covers typically ship freight. So their build and ship times, can be longer then other tops.
    Choose a painted tonneau cover if:
    you need maximum rain and theft resistance, a color-matching finish, and you don’t plan on hauling large items on a regular basis.
    Heavy Duty
    Trucks primarily used for daily driving will greatly benefit from any of the previously mentioned tonneau covers. However, some trucks just work harder or play harder than others. Whether it’s construction work or extended off-road trips, a heavy-duty tonneau cover is the best choice when utility is everything. These bed covers run the gamut of design an operation, with some folding open and others using a one-piece hinged design similar to painted covers. What they share is high weight ratings and the ability to be accessorized with tie downs, cargo bars, headache racks, and other must-have items for the most demanding truck owners. All of these covers are made of a hard material, so you’ll get hard cover security in addition to tons of customization options.​
    Choose a heavy-duty tonneau cover if: your truck serves as a mobile work station or an overlanding vehicle.
    Tool Box
    First off, let’s clear up some potential confusion. Tool box tonneau covers do not come with a tool box (with the exception of certain retractable covers from Truck Covers USA). Rather, the cover is cut short so it can fit on a truck bed equipped with a standard profile, 20-inch tool box. They can run the whole gamut of tonneau cover designs including soft, hard, folding, and rolling. Do keep in mind, these will not fit low profile tool boxes, as the cover bulkhead rail interferes with the latches.​
    Choose a tool box tonneau cover if: your truck is equipped with a standard 20-inch tool box.
    Tundra Deck Rail
    For the Tundra's you will see "with deck rail system" or "without deck rail system" as a drop down option on almost all of our covers. That is asking if you have the factory track system installed by Tundra. If you do have the deck rail system and select "with deck rail" that will ensure you get the correct clamps for your cover. We have two main clamp system's we use for that track system. The first will be an aluminum bracket that slides into the factory deck rail and creates a hook for the tonneau clamp. The second will ask you to remove the factory deck rail, install the tonneau rail, and then reinstall the factory track with the tonneau brackets. This will lower your factory deck rail system a few inches.
    Hopefully this content is helpful! If there is an audience, I would be happy to go into further detail on specific models, comparison between styles/covers, rack and cover fitment, etc. Just let me know what information would be helpful to y'all!
  2. May 3, 2022 at 7:30 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Thanks for this writeup. One question that I have had a LOT of trouble finding answers to, is which hard covers allow you to still use the tie down cleats on the bed rails when they are folded back? My current Undercover Armor tonneau does NOT allow me to use the rails at all because the mounting overlaps the rails. A cover I had on my old truck was a quad fold and I still had full access to my rails and tie downs when needed without completely removing the cover.
    la Moose likes this.
  3. May 3, 2022 at 7:53 AM
    SantanaRealtruck
    For hard folding covers we would recommend the BAK MX4, G2, Fibermax and F1, Gator FX and FX3 and the Extang Xceed. In those models you will reinstall the factory track a little lower so that you can still use your tie downs. I attached a copy of what that install looks like that may be helpful!
  4. May 3, 2022 at 8:56 AM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    Soft roll-up style for reference purposes.
    North mountain branded, uses blocks at the rear for tension adjustment. Think it runs about $200
  5. Nov 11, 2022 at 8:01 AM
    CKOPIX
    CKOPIX New Member
    Curt
    2022 SR5 TRD Lunar Rock
    BAKFlip MX4 Tonneau Cover & Truxedo Elevate FS Rack with T-Slot Runner
    Wish I would have seen this before I installed, I made my own brackets, basically the same thing. The folks at Realtruck had no clue on how to help.
    Soflo likes this.
  6. Nov 17, 2022 at 9:36 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Thanks OP, this was helpful.
    Any chance you can tell me if the TruXedo Lo Pro and/or Deuce mount with the deck rail system in the factory position or do they require the down brackets to shift the deck rail lower?
  7. Nov 28, 2022 at 9:14 PM
    PA452
    PA452 New Member
    Ended up buying a Deuce. In case anyone is ever looking for the same answer, it uses the factory position of the deck rail, because it actually mounts into the deck rail system if you have one.
  8. Nov 28, 2022 at 9:34 PM
    Scruffy_Nerf
    Scruffy_Nerf New Member
    2022 Toyota Tundra SR5
    Soft tri-fold for reference. Gator SFX. Runs around $250.
  9. Nov 29, 2022 at 12:37 AM
    PA452
    PA452 New Member
    Don't have pics, but my initial impressions of the Deuce:
    It fits great on my truck. Has a good, non-cheap feel to it for sure. Instructions that came with it were a little cartoonish and parts were hard to read. Fortunately there's pretty good videos online. Looks great.
    I am a little torn now on the idea if maybe I should have gone with the PRO x15. This is my first tonneau and I'd expect few if any rollups keep all water out, but I am seeing a little water coming into the bed at the hinge point of the front folding panel. There's a spot on that hinge where there's a couple small gaps in the rubber seals that are letting water in. It's not a huge deal, but I imagine I wouldn't have that issue with the PRO X15. That said, being able to flip open that front panel to access the front of the bed without rolling the whole thing up is pretty nice, and makes the bed much more useful in my opinion. So I guess it comes down to priorities, keeping the bed more bone dry vs having easy access to the front of the bed. I might see if I can find a way to reinforce the seal at that pivot point a little.
  10. Jan 14, 2023 at 9:12 AM
    Cory0130
    Cory0130 New Member
    23 tundra limited
    Hello everyone….I am in the market for a cover and was curious if anyone has trouble using there automatic tailgate. I’ve read reviews on some covers, and some people complain that they have trouble opening and closing their tailgates. These reviews are not specific to tundras. Any help or explanations would be helpful.
  11. Apr 11, 2023 at 8:55 AM
    Preskit
    Preskit New Member
    2018 TUndra TRD OffRoad
    I am actually looking at the LOMAX covers. They are built in North Dakota, USA! They offer different surfaces and finishes and use aluminum panels. I checked with my Toyota dealer and Toyota covers are available but are apparently outsourced, and cost about the same as the LOMAX. LOMAX did come out with a carbon fiber cover but it was waaaay out of my price range. The LOMAX covers are made by www.agricover.com. They are the best that I have found yet in a hard surface, tri-fold tonneau cover. And no, I am not being paid by them!
    BTW, buying directly provides a 15% discount on price.
  12. Apr 11, 2023 at 8:02 PM
    Dunes
    Dunes New Member
    JJ
    2023 Grey CrewCab 6.5 TUN 4x4
    I have ROLL-N-LOCK on my 8 footer TUN-2008. Still in mood to get the same for my 2023 TUN 6.5. i feel its little pricey but I get so used to this one and easy to load my camper on either one with this option.. any one say otherwise. Just looking for a rolling one that folds inside and our of site, as i do travel a lot, and not fan of tri folds.
  13. Apr 12, 2023 at 7:23 AM
    Preskit
    Preskit New Member
    The roll up retractable covers are very cool, my concern for where I live is the weather fouling it up. I live in western NY and they use a ton of salt in the winter months. Have you had any trouble with the puter vinyl breaking down?
  14. Apr 12, 2023 at 11:06 AM
    centex
    centex New Member
    I had a roll up on my last truck and the vinyl was tearing after 5-6yrs of the Texas sun baking it.
  15. Apr 14, 2023 at 8:15 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    The rollups I have had held up fine but the major annoyance from them was even though they supposedly had tensioning systems the velcro would give a little and let them sag and I'd periodically have to pull them tight again. This was 10-plus years ago that I used them but even now I'll occasionally be walking down the street and see one with little sags and wrinkles that I know are caused by that. Used to drive me nuts.
  16. Aug 5, 2023 at 9:04 AM
    Murdock03
    Murdock03 New Member
    I know this is an old post, but I have the same question for retractable covers, anyway you could shed some light?
    Having a quick reference sheet on the features and pros/cons of each would be very useful. As it is, it's difficult to really determine which will work best because they all are pretty similar (and at different price points)
  17. Aug 7, 2023 at 10:18 AM
    SantanaRealtruck
    We do not have a reference sheet across all retractable cover brands but that is a great idea! I will get it in the works.
    DoubleEnTundra likes this.
