Wiring for Pop and Lock on 2015?
Discussion in 'General Tundra Discussion' started by joonbug, Aug 25, 2016.
  1. Aug 25, 2016 at 3:55 PM
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Just received my Pop and Lock for the tailgate. Has anyone installed on a 2015? I saw a youtube video for a 2013 and another one for a 2014 and the guy on the '14 said the wires to splice into, in the cab, were different from the '13? Any advice or tips appreciated.
  2. Aug 25, 2016 at 4:00 PM
    eledobleu
    eledobleu retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    I installed mine right before 4th of July. The wiring is slightly different. I watched the video of the guy explaining that about the 14. Overall it's the same install, just the wires in the passenger kick panel is slightly different. I will check which wires you need to splice into once I get a chance.
    GNTundra, JC303 and NewImprovedRon like this.
  3. Aug 26, 2016 at 5:16 AM
    15whtrd
    15whtrd Mr. Blonde
    The instructions I got with mine were up-to-date and it wired perfectly. Passenger side kick panel. Just make your connections, and before you put everything back to make sure that it is locking and unlocking in the correct order with the key fob. I had heard everything was correct except for what wires were connected to which color. I have basically heard that they had it backwards. But that was not the case with my instructions it worked fine. Good luck good!
  4. Aug 26, 2016 at 9:26 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Thanks guys, I'm going to try this weekend. Oh, and did you guys route the wire under the truck and into the engine bay? The video didn't really show how he got to the engine bay.
    JC303 likes this.
  5. Aug 26, 2016 at 10:29 AM
    FumundaTundra
    FumundaTundra Director of civil unrest
    Wayne
    Central WA.
    2009 5.7 Tundra Double cab
    Many to come.
    I like that. I may have to install one on my DC.
  6. Sep 16, 2016 at 6:52 PM
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2024 Tundra Limited 4X4 Nightshade Blueprint
    BAK MX4, window tint, TRD skid plate
    Did mine Labor Day weekend. Routed it under the driver side and into a grommet near the rear passenger door. This takes the wire into the door plate channel on the passenger side. Ran it to the kick panel and wired it up. All done. Works great.
    JC303 likes this.
  7. Sep 16, 2016 at 7:53 PM
    IslandHui
    IslandHui New Member
    Del
    Oahu, Hawaii
    2016 White DC TRD
    2.5 Kings, Deaver k37, TC A-arms, trd pro grille
    I just did mine yesterday on a '16 DC. I routed the wire along the passenger side into the engine bay to the passenger side kick panel. I wired the green wire to blue/silver stripe. Then blue wire to white/silver stripe. It works fine.
    ChucklesToy likes this.
  8. Sep 17, 2016 at 4:45 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Anyone have a link to this kit? Looking at doing this ASAP
  9. Sep 17, 2016 at 6:26 AM
    iHacker
    iHacker SW TRD PRO
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
  10. Sep 17, 2016 at 7:08 AM
    ChucklesToy
    Chuck
    Round Rock, TX
  11. Sep 17, 2016 at 8:24 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    I can't believe I manually locked and unlocked the tailgate for an entire year. Should have done this way sooner. If Toyota made this a standard feature and put it on every Tundra, they could probably do it for under $20 a truck.
    15whtrd and ChucklesToy like this.
  12. Jun 13, 2017 at 7:24 PM
    lehminh
    lehminh New Member
    2016 Tundra SR5 CrewMax 5.7L 2WD Front Bench Seats
    How long did it take you guys to install? Just received mine, Trying to see if I should wait for the weekend or can I finish in 1-2 hours after work since its Summer?
  13. Jun 13, 2017 at 7:47 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I'd say an hour if your fast. 2 if your sipping beers
    JC303 and Eclipsed & Floating like this.
  14. Jun 13, 2017 at 7:48 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  15. Jun 13, 2017 at 8:11 PM
    15whtrd
    15whtrd Mr. Blonde
    I could've thrown it in there in about an hour. But it took me over two hours because I'm very particular and wanted the perfect routing and the install to be very clean.
    JC303 likes this.
  16. Jun 13, 2017 at 8:57 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Definitely under 2 hours. Only problem I had was my wire was short. Someone else said theirs was too. So instead of making the connection between the two wires inside the tailgate, I made the connection under the bed to give it enough slack.
    Taco-Blender and JC303 like this.
  17. Jun 15, 2017 at 9:36 PM
    lehminh
    lehminh New Member
    I'm terrible! Took me 3 hrs and I wasn't sipping beers either! Lol
    Got it done after work today. Weird thing was I followed the wiring instructions but polarity was backwards: locking doors unlocked tailgate and vice versa. So I just reversed the wiring for the actuator: green to blue and vice versa. Now it's aligned. Glad I did this. No worries about lock/unlock tailgate anymore. Also it's only loud when you are near the tailgate. I can't really tell difference while in the car or not close to tailgate.
    BlueBottle and NewImprovedRon like this.
  18. Jun 16, 2017 at 2:22 AM
    Fishin1981
    Fishin1981 New Member
    2015 tundra limited crewmax
    Pop and lock, esp storage, access lorado, front tints
    Easy install, even I was able to do it. Make sure you learn from my mistake and tighten all screws. I had a screw pop off the handle assembly and the screw and spring dropped into the tailgate. Thank got I was able to slip my hand in and open my access cover or I would have been screwed.
    GNTundra and BlueBottle like this.
  19. Jun 16, 2017 at 4:04 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yup. I mentioned that the wiring was backwards on my write up. Glad you got it working. It's such a convenience having it.
  20. Jun 16, 2017 at 10:42 PM
    lehminh
    lehminh New Member
    I must've missed that on your post. Yeah, super convenient mod. Was putting it off cuz I didn't know if I could do it, glad I did it! Thanks all.
  21. Jun 18, 2017 at 8:05 AM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    I am about to get the pop & lock, when you unlock it does the tailgate open and drop down ? Or does it just unlock / lock ?
  22. Jun 18, 2017 at 8:24 AM
    ChucklesToy
    Chuck
    Round Rock, TX
    It just unlocks...my doors are set to unlock just the driver's door on first click and all doors plus tailgate on second click. And then it locks the tailgate when all doors lock.
    Scpringle likes this.
  23. Jun 18, 2017 at 10:19 AM
    lehminh
    lehminh New Member
    There's an additional mod to release tailgate. YouTube it
  24. Jun 18, 2017 at 11:54 AM
    lehminh
    lehminh New Member
  25. Jun 18, 2017 at 11:57 AM
    lehminh
    lehminh New Member
  26. Oct 28, 2020 at 6:02 AM
    QaQa
    QaQa New Member
    2015 tundra TRD CM
    Does any one have a wiring diagram for this mod(automatic tailgate)? There is one in this link but when you enlarge it to be able to read it is too blurry. Any help would be great.
